out with the old in with the new mg v8 build has begun
madman Avatar
madman Rich c
Edg, FL, USA   USA
love working with that bedliner stuff, so versatile, looks good clearcoated kinda like powder coating but way better......as long as you like black.
madman Avatar
madman Rich c
Edg, FL, USA   USA
valve train is in but needs to be adjusted, spent some time painting parts, cleaning parts so its already for final assembly. my body is shot really need a day off. some fotos to see and a mock up of my color combo.
IMG_2199.JPG    63.5 KB
IMG_2201.JPG    45.4 KB
IMG_2203.JPG    55 KB
IMG_2205.JPG    37.2 KB
theonlyiceman53 Avatar
theonlyiceman53 Bill Russell
FL, USA   USA
1974 MG MGB "Frankenstien"
1977 MG MGB "Wicked"
Looks great! It should run as good as it looks!
I look forward to reading about your progress and it's always the first blog I look at!
Bill
madman Avatar
madman Rich c
Edg, FL, USA   USA
thank you Bill I think the color combo on the engine suits the theme of the car.....does take a little getting used to, but it does pop. the trick will be getting it all into the car and keeping it all pretty, gonna get some help wen the time comes. been doin some experimentin with hammertone paint, me like. it does not show well in fotos but its makes certain things look good, like the water pump and crank pullys [fotos to follow]. a little creativity with paint goes a long way wen you work on a budget, besides........chrome only looks good on a motorbike, in my opinion, and paint does not rust like chrome does.
NOHOME P P
O, ON, Canada   CAN
billymgb1000 Avatar
billymgb1000 Silver Member william gaulin
harrisville, harrisville RI, USA   USA
1974 MG MGB V8 Conversion "Sweet Thing"
Love it " Floats like a butterfly stings like a V8 MGB "
madman Avatar
madman Rich c
Edg, FL, USA   USA
heres a few hammer tone fotos, alittle hard to see but youll get it
IMG_2206.JPG    49.2 KB
IMG_2209.JPG    41.8 KB
IMG_2211.JPG    50.3 KB
IMG_2207.JPG    57.4 KB
rficalora Avatar
rficalora Rob rficalora
Cypress, TX, USA   USA
They came out nice; appear powder coated.
madman Avatar
madman Rich c
Edg, FL, USA   USA
valves are adjusted, engine is oil primed [60 psi @ 1200 rpm drill speed],distributor is in and set up to start. intake is on, valve covers etc. the motor is DONE!!!!! some fotos to see.
IMG_2213.JPG    59.4 KB
IMG_2214.JPG    61 KB
IMG_2215.JPG    59.7 KB
IMG_2216.JPG    56.5 KB
madman Avatar
madman Rich c
Edg, FL, USA   USA
next to come is some creative plumming on the intake manifold so the rear two cylinders get better cooling, ill explain later........thanks for watching.
FL, USA   USA
Looks Awesome!!!!!
mjoeb Avatar
mjoeb joe doornenbal
scio, OR, USA   USA
1967 MG MGB
That sure looks like the SBC that I have in my 95 caprice wagon, it maybe going into an MGB or MGA someday. joe
FL, USA   USA
You can't go wrong with a SBC. They're easy to put in and they run like a scalded dog. The first one I put in I just used a BFH and a welder to get it in. Absolutely nothing fancy. It was a blast to drive even though it was a little 283. 350/383 are tough to beat. I went crazy and put a BBC in one but it wasn't that much fun to drive. It's a lot better with a little 350. I'm still putting together the new 454 to replace the blown up one and I'll not be in a hurry to replace that 350 that's in there now. That engine bay looks gigantic with that little 350 in it.
Bill
madman Avatar
madman Rich c
Edg, FL, USA   USA
thanks guys, but now onto explaining my intake modification.........these early vortec motors run hot for emission reasons. how this is accomplished is by a few things, smaller water holes in the head gaskets and there is no rear water crossover from the back of the heads to the water pump. so wut I did was.........opened the holes in the head gaskets to a concervitive 7/16 and drilled and tapped the rear of the intake manifold [newer intakes have these holes] and ran a water line to the front water passage directly feedinding the water pump. this mod I'm geusstimating will let the motor run at least 20* cooler, ill find out soon enough. heres fotos of my modification.
IMG_2221.JPG    48.1 KB
IMG_2222.JPG    38.7 KB
IMG_2223.JPG    56 KB
IMG_2227.JPG    46.3 KB
madman Avatar
madman Rich c
Edg, FL, USA   USA
the old motor ran at 190-200* so I have a way to compare if this all works, no matter wut the 2 rear cylindres are definatly gonna run cooler
IMG_2226.JPG    48.3 KB
IMG_2220.JPG    49.2 KB
