Exhaust problem
Posted by sjboyer
sjboyer Avatar
Scott Boyer
Illinois, USA   usa
I would like to use a band adapter for the collector to the pipe elbow but the coated collector is slightly bigger that the expanded end of the elbow. With some help, I have gotten through the engine, trans, drive shaft, alternator, distributor, etc. but I admit I am a bit intimidated by the exhaust challenge.
Maybe because I am getting so close to firing up this puppy.
Any help greatly appreciated.
Scott
1977 B Roadster
Ford 306 roller, T5Z trans Limey's fuse box and relays, Clark and Clark hood struts, Wade Keene's swivel axles, Custom leather interior w/speaker pods, Poly bushings front & rear, Wasper's seat belt holder, Hap's VTO 15x6 wheels
Bob in Vancouver Avatar
Bob Elwin
Vancouver BC, Canada   can
1968 MG MGC
1969 MG MGC GT
Scott, Most muffler shops have a tube expander - just take both items down there and have the elbow expanded just slightly for a tight sliding fit. Good luck, Bob
G W
Evansville, Indiana, USA   usa
The first time I had to take mine apart I changed them to a 3-bolt connection. When I made new headers there was no question I wanted the same:
sjboyer Avatar
Scott Boyer
Illinois, USA   usa
In reply to # 2063411 by Bob in Vancouver Scott, Most muffler shops have a tube expander - just take both items down there and have the elbow expanded just slightly for a tight sliding fit. Good luck, Bob
Great Idea Bob. Thanks.
sjboyer Avatar
Scott Boyer
Illinois, USA   usa
In reply to # 2063448 by gow589 The first time I had to take mine apart I changed them to a 3-bolt connection. When I made new headers there was no question I wanted the same:
G W how did you connect them the first time and what was the problem with it?
G W
The first time I put them on I had a slip fit. After running the car I had to beat them off with a deadblow hammer.
kerbau53 Avatar
Geoff Morton
Naples, Florida, USA   usa
I used V-band clamps
v band clamp.jpg (3 KB) –
MGB 211.jpg (58.2 KB) –
john austin
ruidoso,nm, USA   usa
Scott,in the photo it sure looks like the brake line is very close to your header. How close is it and are you concerned at all about heat being transmitted to the brake fluid?
sjboyer Avatar
Scott Boyer
Illinois, USA   usa
In reply to # 2063951 by turbostar Scott,in the photo it sure looks like the brake line is very close to your header. How close is it and are you concerned at all about heat being transmitted to the brake fluid?
It's about a 1/4" behind the collector and 1/2" to the right. I have put an insulating sleeve over the tubing where it's the closest.
djdavies Avatar
David D
Ca, USA   usa
In reply to # 2063976 by sjboyer
Hmm, I'd be more considered that MY HEADER IS IN MY FREAKING WHEEL WELL!!!!smiling bouncing smiley
kerbau53 Avatar
Geoff Morton
Quote: MY HEADER IS IN MY FREAKING WHEEL WELL!!!!smiling bouncing smiley
I suppose we could have run them out the top of the fender. Like a semi.
john austin
ruidoso,nm, USA   usa
I hope it does not become a problem for you,but if my brake line was 1/4 in away from my header,I would be concerned.
sjboyer Avatar
Scott Boyer
Illinois, USA   usa
OK I give. How have others handle the the front brake lines when using the exhaust into the wheel well?
