T-5 WC or non-WC
Posted by thomaslea1
thomaslea1 Avatar
Tom Lea
Central Illinois, USA   usa
1968 MG MGB
How much do I really lose by having a non-WC transmission?
I'm having a lot of trouble locating a T-5 WC from a GM V-8. I'm finding enough non-WC in the $650 price range, but no WC's. I've run car-part.com and Hollander (myparts.com) dry with no results. Folks won't look for the tag, the tag is gone, or they can't read it are answers I get.
How much or what do I sacrifice by using a non-WC box?
TIA
Tom
mgv8glen Avatar
Glenn Towery
Dover De., USA   usa
Run what you can find! You can not get enough tire under the B to hurt the non W/C trans. I would get the tag #s or I would leave it, not the right gear ratio it is not worth a thing. I would rather have the tag # than it being the W/C. I have 3 T-5s with the tags & only one is W/C. & no worry at all, will use them all.
mowog1 Avatar
Rick Ingram
Saint Joseph, Illinois, USA   usa
Have you contacted D&D Fabrications?
1968 MGC - 1969 MGC - 1972 MGB - 1974&1/2 MGB/GT V8 conversion - 1978 MGB
mowog1@aol.com
Pieces Of Eight: Struts For Your MG Pieces of Eight! has provided gas-charged strut kits for the MGB bonnet, MGB and MGC bootlid, and MGB/GT or MGC/GT hatch since 1996. Contact Rick at: mowog1@aol.com
Miket Avatar
Michael Trainor
Beaconsfield, Canada   can
I agree with Rick. The non-WC are designed to push cars(and trucks) much heavier than an MGB.
Mike
BMC Avatar
BMC Gold Member
Brian Mc Cullough
Minneapolis, Minnesota, USA   usa
Run what you find.
A NWC is a nice box. A WC is barely differentiated in feel and we are pushing no weight and your not racing for top place in a really competitive class and and and............
-BMC.
BMC British Automobile   – Minneapolis, MN USA BMC British Automobile is a Restoration and Repair shop north of Minneapolis, Minnesota. Our time is spent solely on British vehicles and British Conversions. MG and Austin are our specialties.
dtownsend Avatar
David Townsend
Rutland, Vermont USA, USA   usa
Can't speak to the power you're putting to the Chevy version of the T-5 but I've run both WC and non-WC T-5s in back of several SBFs and unless you're really gear slamming, I think you'll be hard pressed to break one. That said, the u-joints are another question. Now, those I've broken.
BMC Avatar
BMC Gold Member
Brian Mc Cullough
We build new shafts with larger Universal joints than stock for any T5 to GM rear axle combo. Tested, we have found you will most likely break the rear axle before the propshaft. winking smiley
Jim Nichols
Sequim,WA, USA   usa
Also the NWC has a poor reputation undeservedly. If you get one that has a lot of endplay you can shim up the front bearing. Lots have the wrong lube in them(ATF instead of 70wt). The WC use ATF. NWC uses solid bushings,WC use roller bearings. I couldn't find 70wt so used to mix 2 qts 90wt Redline synthetic with 1 qt synthetic ATF. Worked fine. Later I used 1qt Redline synthetic 90wt and 2 qt Syncromesh. Again worked fine. The most important thing to me is having stops for the shifter so you don't bend the shift forks. Also the steel front bearing retainer.
Edited 2 time(s). Last edit at 04/23/2012 11:32PM by 260mgb.
1744 Avatar
Bill Guzman
California, USA   usa
1973 MG MGB GT "Green GT"
1974 MG MGB "Punking"
As per Glenn T.
Keep in mind that the MGB is much lighter than a Camaro. A NWC are cheap and a good choice for a swap.
Yes if you find a good WC trans go for it, also the WC trans is a bit more expensive to rebuild.
I have a NWC trans in my B, the trans had over 150k miles and still shifting good after 7 years.
I did shim the input shaft bearing to take out the end play and re-seal the trans with new front and rear seal.
mark w
lost angy, USA   usa
You should be able to find 4 cylinder ford boxes for way less than $650 used...rebuild kits are around 200 and thats with all the parts, if memory serves me correctly the WC boxes has needle bearings in many places instead of bonze bearings. Main difference externally between ford and GM boxes is shifter location. But there are a few companies that make shifter relocation kits for em. Easy box to build, rebuild and upgrade
Mark
Jim Nichols
Sequim,WA, USA   usa
4 cylinder Ford has a longer input and lower first gear ratio. Newer Mustang V6 WC (still fairly common) has better ratios and D&D has the spacer for longer input. Ford pattern was used on 3.4 bellhousing. I think the V6 has same spline count as Ford V8. You would need smaller Turbo4 clutch disc. Chevy front bearing retainer and throwout bearing for small GM V6. Ford trans yoke.
