MG-2013 is only 59 days away! · Corvallis, OR · July 17–21, 2013 · Visit MG-2013.com or the MG-2013 Forum for more info
Aftermarket gauges
Posted by 89325iturbo
Dusty A
CT, USA   usa
Im gonna buy an aftermarket wiring harness, and a set of gauges. What should I go with electric or mechanical? I want a clean look in the engine bay. I dont want wires going across places. But I imagine electric are easier to install.
BMC Avatar
BMC Gold Member
Brian Mc Cullough
Minneapolis, Minnesota, USA   usa
Dusty,
The key word was aftermarket.
As soon as we know you don't need a standard appearance, the VSS wire is far easier to hide and far more tunable for less money.
Do nothing with a cable.
-BMC.
BMC British Automobile   – Minneapolis, MN USA BMC British Automobile is a Restoration and Repair shop north of Minneapolis, Minnesota. Our time is spent solely on British vehicles and British Conversions. MG and Austin are our specialties.
Dusty A
CT, USA   usa
Well I should say its going on a carbed 302. So I was gonna use a basic 10-12 circuit harness. I just want easy clean install of gauges.
sjboyer Avatar
Scott Boyer
Illinois, USA   usa
Check the gauges from Speedhut https://www.speedhut.com .
Clarksville, Tenn., USA   usa
VDO gauges - doesn't get much easier.
http://www.egauges.com/vdo_mult3.asp?Type=6_G_Set&Series=Vision&Units=E
smileys with beer
Mickey
'73 MGB
'69 MGB GT/V6 Conversion
1744 Avatar
Bill Guzman
California, USA   usa
1973 MG MGB GT "Green GT"
1974 MG MGB "Punking"
TPI Gauges offer lots for the price.
http://www.tpigauges.com/
TKMad Avatar
Tyler Madia
Thousand Oaks, USA   usa
In reply to # 1998087 by sjboyer Check the gauges from Speedhut https://www.speedhut.com .
I'm itchin to try the GPS speedo from Speed Hut. Next project will definitely have their gauges.
1744 Avatar
Bill Guzman
California, USA   usa
Tyler, there is a much better deal and cheaper.
Classic Instruments Gauges have a GPS unit that will work with an electronic speedo for $190 for 40 or 60 pulse.
There is a good article on the latest Street Rodder magazine.http://www.classicinstruments.com/index.aspx?documentID=newproducts
I am going to order mine, I just need a bit more info.
danmas Avatar
Dan Masters
Alcoa, Tennessee, USA   usa
1974 MG MGB GT "Powered By Ford"
I have Classic Instruments in my GT, with the convex glass lens - I think the curved lens adds a bit of classic panache to the gauges.
1744 Avatar
Bill Guzman
California, USA   usa
I agree Dan. I was a good customer of Classic Instruments until they went up in price.
I had the original gear selector auto trans gauge. The gauge had the letters-# P-D-1-2 and the sensor was a crude (by today standards) magnet in the trans selector lever with 6 or 8 wires.
They were the first to offer the convex glass. Now VDO and Auto-Meter and others offer the convex glass.
Also the first to offer the classic look gauge with white or gray background.
Like your dash Dan, it looks better from the passenger seat.
Dusty A
CT, USA   usa
I was looking at ezwiring 12 circuit harness, and there dolphin gauge set. The dolphin gauges look very similar to the tpi gauges.
But what should I get electric or mechanical?
danmas Avatar
Dan Masters
Dusty,
In your original post, you said you wanted a clean engine bay. With electrical gauges, you'll have a couple of wires to hide - with mechanical gauges, you'll have tubing to hide. Hiding electrical wiring is easier. Many consider mechanical gauges to be more accurate. I don't know if that's true or not, but the electrical gauges are accurate enough.
As for wiring, have you considered the kit from Advance Auto-wire?
http://www.advanceautowire.com/
danmas Avatar
Dan Masters
In reply to # 1998771 by 1744 Like your dash Dan, it looks better from the passenger seat.
I'll have to admit, it does look pretty good from the passenger side, as I found out last week as Nico ripped around the foothills of the Smokies. Kinda nerve racking for an old grandpa, but he did very well. He does take after his grandpa in that he has a bit of a lead foot.
rficalora Avatar
Rob rficalora
Cypress, TX, USA   usa
Agree with Dan. With electric gauges all you need in the engine bay (for the gauges) are three wires. One for the temp sender, one for the oil pressure sender, and one for the tach. With mechanical you'll have capilary tubes for the temp and oil pressure (harder to route/hide). Fuel sender is electric either way as is tach. Speedo wire or mechanical cable doesn't need to go thru engine bay. Benefit of electric Speedo is most can be re-calibrated without changing Speedo drive gears if you change tire size or rear axle gears down the road.
G W
Evansville, Indiana, USA   usa
I run VDO. My temp gauge (just behind steering wheel on right) has a real small switch on bottom of dash. Very subtle and not noticeable. The dash switches between coolant and oil temp sender. Nice to have both.
Behind the radio delete plate I put an O2 ad MP gauge. I set up the radio delete plate to be held on with super magnets. I really did not want to look at or see them all the time in the dash:
460Jag Avatar
Ken Nicks
Jonesville, NC, USA   usa
Dusty, I bought an EZ Wire harness for my MGB-GT. The wiring is ok but the directions and wiring diagrams were terrible. IMHO - look elsewhere for a harness !!
Ken Nicks
1744 Avatar
Bill Guzman
California, USA   usa
Agree with you Ken, But...there is no need for instructions as the wires tells you were they go. Wires are level every 2"
Left head light, right turn signal, horn etc etc...
What I do not like about EZ wire is that they only use two relays. Need to add fuel pump, cooling fan, head lights etc. relays.
I like their 21 circuit kit, it has power windows, AC, fuel pump, electric choke, power door locks, power windows etc.
460Jag Avatar
Ken Nicks
Bill, the whole problem was the wires weren't labeled.
Ken
danmas Avatar
Dan Masters
Quote: Dusty, I bought an EZ Wire harness for my MGB-GT. The wiring is ok but the directions and wiring diagrams were terrible. IMHO - look elsewhere for a harness !!
Two of the benefits of the Advance Auto-Wire kits are the instructions and the diagrams - they are made specifically for the MGB, and the wiring is color coded per the MGB standard. You can download a copy of the instruction manual before buying to see if it's something you'd want.
Quote: What I do not like about EZ wire is that they only use two relays.
The AAW kits have 7 relays.
Disclaimer: Although I have no financial interest in the company, I was the founder so I'm a bit biased.
rficalora Avatar
Rob rficalora
In reply to # 1999323 by 460Jag Bill, the whole problem was the wires weren't labeled.
Ken
Doesn't sound like the "EZ Wiring" harness Ken. I used them & like Bill noted, they're labeled every few inches. I needed a 21 circuit harness due to all the modifications (electric windows, mirrors, shaved door poppers, stereo, A/C, plans for heated seat pads & cruise, + a few other accessories) and didn't really have any problems. But:
* The wire coloring is GM, not MG so I pretty much had to draw my own wiring diagrams
* Doesn't come with any connectors. Took a while to find quality connectors
and they're not cheap - factor the cost & time in. I soldered; takes a lot of time.
* Like Bill mentioned, only 2 relays - horn & ?? can't remember the 2nd. I know I added several.
* quality of wiring is good; quality of Advance Autowire is better. My bet is same is true of the fuse panel
itself too.
If you just need a 12 circuit harness, I'd highly recommend Advance AutoWire. By the time you factor in the connectors & relays the cost differential isn't that much & it's a better quality harness with support that understands the car, connectors, etc.
