Anyone trying a 4 cylinder conversion?
Niels Niels Christian Nielsen
Trondheim, Sør-Trøndelag, Norway   NOR
1967 TVR Vixen "Little Thunder"
2004 MG ZT
Isn't the EcoBoost the same engine as the Ford and Mazda Duratec engines? If so there is a MGB GT in the UK with a 2.3 in it atleast smiling smiley
Niels
Safety Fast
jlozinsk Avatar
jlozinsk John Lozinski
Sofia, Center, Bulgaria   BGR
Yes it is a Ford 2015 till now turbo motor that is 310 HP
John
Hemidavey Dave Rudziensky
Grosse Isle, Michigan, USA   USA
if you are referring to the old Ford 2.3 Pinto and Ranger engines, check on the weight, I think they are very heavy. An aluminum head is available from Eislinger which helps a lot! Also look at height and length. If you want to go this way I can give you dimensions, we have one on display here. As far as durability, they are hard to beat. I've had old ones apart and the mains look almost new. Also its easy to make 200 HP and 300 HP plus is easy with turbos. They are plentiful and cheap.
I used the Mazda Twin cam because it looks cool and is my tribute to the original . The Mazda engine/trans combo is 105 pounds lighter than the original. I weighted both drive trains with our hanging scale, included ALL acessories, intake and exhaust. After weigh in I saved a few more pounds by drilling lightening holes in the engine mount brackets, cut off some around the outside edges and installed an aluminum radiator. Some of the rusty parts are falling off so it get a little lighter each time I drive it...
2004 MG ZT
In reply to # 3591150 by Hemidavey if you are referring to the old Ford 2.3 Pinto and Ranger engines, check on the weight, I think they are very heavy. An aluminum head is available from Eislinger which helps a lot! Also look at height and length. If you want to go this way I can give you dimensions, we have one on display here. As far as durability, they are hard to beat. I've had old ones apart and the mains look almost new. Also its easy to make 200 HP and 300 HP plus is easy with turbos. They are plentiful and cheap.
This is the engine-family I was refering to
https://en.wikipedia.org/wiki/Ford_Duratec_engine
Niels
Safety Fast
