Anyone trying a 4 cylinder conversion?
scotabbott Avatar
scotabbott Scot Abbott
Pittsburgh, Pa 15216, USA   USA
1974 MG MGB "Bee"
One of the things which pushes folks to convert to a newer motor is the cost of a rebuild and the modest performance inherent in the old B motor. While the various conversions sure bring plenty of power, they mostly bring plenty of cost. For a lot of B owners, the cost of a typical conversion is prohibitive, and the reward isn't valued enough to do. Some of the conversions are a lot of work and some need a shoe horn or scoop or cutting torch to make happen, and a lot of guys look at a scoop and similar mods as butcher work.
I've done a few conversions, and the 60 degree V6 is almost worth doing in the right situation. These fit in pretty easily and the resulting setup works quite well. Nonetheless, even with a good donor car and making some of the parts, a conversion burns through $2000 and a lot of DIY time at the very least. An expenditure of $4000 or so is more common. These rwd motors aren't so new anymore, either.
I've been pondering what might be another alternative which is a newer, more compact motor with 150 or more HP in RWD format for our cars. GM had put out a nice 4 banger 2.2 and 2.4 which looks to have plenty of pop for use in a B, and it looks quite compact. Probably drop in pretty readily. Anyone doing this one?
moreso74 Avatar
moreso74 David Maples
Augusta, Georgia, USA   USA
A little something different:
I was watching a friend pull apart his Mercruiser stern drive engine. After the water jacket and exhaust crap was out of the way, there sat a tidy little 4 cylinder. A few quick measurements and it seems like it would fit an MGB engine bay. The engine is basically half of a 460 Ford engine. New 460 pistons can be used. The head is iron but the block is aluminum. I asked an old hot-rod buddy about this engine and he said they used to put them in street rods hooked up to GM transmissions. The mount bolts/holes were already there. He said to stay away from the GM 4 cylinder versions of this in-line sterndrive engine and to use the Ford versions. GM parts were/are harder to get.
You can find these in marinas everywhere. Use caution if the engines were in saltwater service. You are safer if they were used only in freshwater areas.
A few specs:
Displacement - 3.7 L
HP - 170, 185, 188, 190 (no torque figures available) HP dependant on carb and exhaust
Bore/stroke - 4.36/3.75"
Compression - 8.8:1
Two model types (early MCM470 MCM485 MCM488) (late 165/170/180/190 MR)
I imagine the torque would be very good with that bore/stroke ratio.
David
Norm73B Avatar
Norm73B Norm Peacey
Woodlawn, Ontario, Canada   CAN
1952 MG TD "Eileen"
Interesting as Scott's numbers are pretty close to what I will have spent for my 3.1. I have seen that BMC is now advertising a less expensive conversion using a GM 4 cylinder, so there must be interest. BMC's states their conversion uses the B exhaust system, rad etc and of course the proven T5 bolts right up. No tach conversion either.
Ryan Reis Avatar
Beatrice, NE, USA   USA
1968 MG MGB
I remember Dann Wade was pondering a 2.2 swap awhile back. I wonder if he ever went ahead with it.
http://www.mgexperience.net/phorum/read.php?40,834311,page=1
Ryan
wersh Avatar
wersh Jesse Wershing
Barnesville Ohio, USA   USA
1976 MG MGB
Scott you mentioned in his first post an option with at least 150 horsepower. I think that the reason we do not see more 4 cylinder conversions is that in carborated form they rarely make 150 hp. The 3.7 liter Dave mentioned is an exception and a honkin big 4 banger to boot. On the other hand fuel injected four cylinders can easily make 150 hp or more. But if I look at conversions that have been done in the past I see more that are carburated that fuel injected. I wonder if it is that most converters are not that comfortable with wiring fuel injection that the 4 cylinder conversions are not that common.
Then again it could be that someone thinks: Well if I am going to go through the work of a conversion I might as well go to a larger motor anyhow.
RobertEdgeworth Robert Edgeworth
Richmond, USA   USA
Someone should grab hold of a K20 honda engine(they easily making 220whp+ with bolt ons) and mate it to a f series transmission -- then fit it into a B'.
Unfortunately K-series motors are a good 3-4k.
I personally don't have the time nor money to complete this swap but I think it would be neat.
t.lay Avatar
t.lay Tom Lay
Grayslake, IL, USA   USA
Probably not what you were thinking of: http://www.mgexperience.net/phorum/read.php?40,1071050
New, modern, compact may be a little at odds with cheap. Seen a few posts about S2000 conversions and with bigger motors, LS lumps for newer options. Just the ECU for the S2000 is over a grand. Not sure what it would take to put together an electric one that charges off a hydrogen fuel cell (if you really want to think modern).
1744 Avatar
1744 Gold Member Bill Guzman
California, USA   USA
1974 MG MGB "Renegade"
4 cylinder with posibilities of 200 hp and up, CCE is working on an engine kit for such engine, it takes time and testing to properly design such kit. There are other projects ahead for the MGB that I have in the works and need closure before I finish the engine kit.
The idea is to have a choice, 4 cylinder, 6 or 8 which I am also working on a simple V8 mount kit, no cross member, just mounts.
carlheideman carlheideman
USA   USA
I've got a 1.8 Miata engine and gearbox in my 1973 MGB/GT. I wrote a three-part series of stories about it for Grassroots Motorsports magazine about 18 months ago. There are some buildup pictures on my website, too. It's a nice swap.
--Carl
http://www.eclecticmotorworks.com/
Norm73B Avatar
Norm73B Norm Peacey
1952 MG TD "Eileen"
Aren't Honda engine reverse rotation from everyone else? I love Honda motors and have had a number, they are quiet, quick and easily modified. As for me I get itchy scratchy around stuff like ECMs so I am staying with carb on my 3.1 although I have kept the complete MFI intake system in case.
Just out of curiosity, Carl, does the BGT hood close on the Miata engine?
mg man 75 Avatar
mg man 75 maurice sallee
Campbellsville, Central Kentucky, USA   USA
Doing a 2.3 ford turbo. Stock Hp is 195. I started with a turbo motor. But this can be done with a 2.3 Mustang Ranger motor, Garrett turbo, standalone ignition system and some forged pistons. Some modification of stock head will be necessary to prevent detonation. But some in Turboford are pushing 500+ and more. But not me.
http://s177.photobucket.com/albums/w224/mgman75/mgb%20project/?start=60
Niels Niels Christian Nielsen
Trondheim, Sør-Trøndelag, Norway   NOR
1967 TVR Vixen "Little Thunder"
2004 MG ZT
There are a few of us doing the I4 Ford Zetec swap. I'm going to run a 2 liter blacktop Zetec with twin Weber DCOE45s and Megajolt ingintion, ford type9 gearbox, CCE 4 link rear suspesnion and Hoyle front suspension in my MKI GT.
Hoping to have it ready for next summer
Niels
Safety Fast
Wilbur Avatar
Wilbur Wilbur Engelsma
Broomfield, CO, USA   USA
I'm installing a 2.0 liter 4 cylinder NISSAN motor (SR20DET). In theory, this should be great: approximately the same weight distribution and 250HP. This is not for the weak of heart however. Lots of custom fabrication, and I still haven't worked all the bugs out. And, I'm at three years and counting- I hope to have all the modifications and metal work done and ready for the paint shop this coming winter (said that last winter as well). Here is my progress:
http://www.mgexperience.net/member/Wilbur
FTD in an MGB Avatar
FTD in an MGB Ed Sweeney
Reading, Pennsylvania, USA   USA
I like this f20c swap photo posted years ago, but have no more information:
mabie1978 Avatar
mabie1978 Michelle Pierce
Elyria, OH, USA   USA
1978 MG MGB "Mabie"
1995 GMC Suburban "The "Burb"
1999 Porsche 911
2007 Saturn Aura
We thought about one of the new engines GM has in the cobalt, the eco-tech but since they were FWD it made the change a bit tougher. So now I am watching for a classic mini that would like to try the eco-tech type engine.
