Fuse panel location
cliffcox Clifford Cox
Auburn, Alabama, USA   USA
For those of you that have re-wired you cars with a modern system. Where did you place the fuse box inside/ outside of the car?
sailadams Avatar
sailadams Silver Member Larry Adams
Brookhaven, GA, USA   USA
1966 Chevrolet Corvair
1967 Buick Special
1967 MG MGB GT "Jose The GT"
1976 MG MGB
I inherited one located just to the left of and under the steering wheel (just like my 1997 Dakota and my wife's 2003 Cadillac). Very modern but kind of close to the floor for easy visibility in an MGB. I don't know what would be better, all considered, however. Definitely not in the engine bay!
When you get to a fork in the road, take it.
jimbb88 Jim Stuart
USA   USA
Passenger footwell, inside.
302V8 Avatar
302V8 Pete Mantell
Sidney, IL, USA   USA
1958 MG Magnette ZB
1969 MG MGB V8 Conversion "Xenia"
1969 MG MGC GT
1969 MG MGC GT "Foxy"    & more
cliffcox Wrote:
Quote: For those of you that have re-wired you cars with a modern system. Where did you place the fuse box inside/ outside of the car?
Hi Cliff,
I have installed many aftermarket wiring kit's into customer B's & my B's/C's.
Each have different size fuse block/panels.
Advance Autowire is a great set up, see link. Because of the size I usually install as Jim mentioned passenger side footwell.
http://www.mantellmotorsport.com/_images/customer/wb1973/wbruce017.jpg
This one is a 18 Circuit Painless.
http://www.mantellmotorsport.com/_images/customer/dsleeth/dsleeth108.jpg
Once installed, modify the map pocket and you'll have a great cover.
The Painless & Summit micro harnesses have a tiny fuseblock with separate relay's, this one can be installed tucked away and hidden above the footwell.
Another great place is in the engine bay passenger side above the footwell, in the small recess, behind the washer bottle on late model B's.
Things to consider.
Accessability, make sure you can reach the fuses easily. Especially when at night, when it's cold and raining...........
Future upgrades, i.e. will an AC unit fit now that I've filled the space with the fuse block etc.
Good luck!
Cheers
Pete
69 B 302 V8 - 78 B 215 V8 - 80 B 302 V8 - 58 ZB Magnette - 69 CGT 9004 - 69 CGT 7666
1744 Avatar
1744 Gold Member Bill Guzman
California, USA   USA
1974 MG MGB "Renegade"
And now......there is one that can be mounted in the trunk and uses the mini fuses.
It all depends on the kit and how long the wires are from the fues box. Most kits are design to be install in the driver side and some kits the wres are long enough to choose the either side.
Choose the location and talk to the manufacturer of the wiring kit and tell him that is where you want the fuse box, some of them will add some wire to the kit.
Thanks...I was hoping that I could find a place that was less exposed. Clumsy feet and all!
I purchased an Advance Autowire system for the MGB
avbates Avatar
avbates Tony Bates
San Jose area, California, USA   USA
I have the Advance harness and have mounted it immediately under the glove box. My car is a 74 CB roadster with a steel dash conversion.
Regards
Tony
would you happen to have a pictire of the mounting?
denvermgb Avatar
denvermgb Brad Carson
Aurora, Colorado, USA   USA
I picked up a Painless type kit, the fuse box was mounted above the driver's left knee position on a beam under the dash, easy to get to, solid place to mount.
Brad
79mgbv8 Avatar
79mgbv8 Silver Member Gil Price
Constable NY, USA   USA
1971 MG MGB GT
1976 MG MGB
1979 MG MGB V8 Conversion "Rumble Bee"
Cliff --I have an Advance kit in my car --installed under glove box in passenger foot well , its been there for 3 plus year with daily driving and lots of miles and has never been a concern for foot hitting or any problemsof the like.Its a great kit BTW Sorry Im out of the country and cant send you a pic --if youre interested and can wait about 6 weeks I can get a pic.--Gil
Thanks Gil - if you happen to remember when you get back, I would appreciate the pictures. Have a safe trip!
BMC Avatar
I have had little time to follow/post on the threads. Hope these pictures help.
MGB GT This one needs more pictures of where we installed the fuse panel. This panel was instatlled on the drivers side behind the radio council. Its tight and next time, this panel will be sitting out more to help clear the radio.
No clear shots for this one installed:
http://picasaweb.google.com/bmcautos/JimOhnstadS1973MGBGTV6#5213444349757510018
MGB GT Car #2:
Request for an exposed harness to keep our time to a minimum.
http://picasaweb.google.com/bmcautos/IanHodgsonS1973MGBGTV634LConversion#5213471371055235202
MGB #3, this was actually the first conversion. Lots has changed since then! Everything exposed but done nice enough:
http://picasaweb.google.com/bmcautos/JimMadsonS1978MGBV6#5214917473616536658
The back plastic cradle is for the stock PCM. The front box is the fuse/relay station. Hard to these but nice to use if in the engine bay.
http://picasaweb.google.com/bmcautos/JimMadsonS1978MGBV6#5214917376175490770
http://picasaweb.google.com/bmcautos/JimMadsonS1978MGBV6#5214918046041672306
MGB #4, shop car. Hidden harness with a bit of learning of what works well. If we were going for AC, maybe the fuse panel could move to the drivers side but that would actually take a bit more work because we are starting with the MGB harness and very little sheetmetal alteration.
http://picasaweb.google.com/bmcautos/BrianMcCulloughS1980MGBV6#5233744279846219858
http://picasaweb.google.com/bmcautos/BrianMcCulloughS1980MGBV6#5213421845511895250
http://picasaweb.google.com/bmcautos/BrianMcCulloughS1980MGBV6#5230812450959662482
http://picasaweb.google.com/bmcautos/BrianMcCulloughS1980MGBV6#5233738672735173058
http://picasaweb.google.com/bmcautos/BrianMcCulloughS1980MGBV6#5233738797951793570
http://picasaweb.google.com/bmcautos/BrianMcCulloughS1980MGBV6#5233739241306540482
-BMC.
chrisj Avatar
chrisj Chris Jones
Denver, Colorado, USA   USA
1967 MG MGB "Syd"
I built my own from aluminum angle and it is mounted against the firewall just under the glove box. see picture:
67 mgb photos 003.jpg    23.8 KB
brdave David Burstyn
Ontario, Canada   CAN
I installed Advance Auto Wire harness inside the map pocket in the passenger side footwell. Well protected and still accessable.
brdave
