Midget Tires
jyankus Jason Yankus
Crofton, MD, USA   usa
I want to start shopping tires for the Midget in hopes of getting her back on the road this spring. Where does the community go to buy tires? The tire rack website didn't have anything in 145/70-13.
Any suggestions? Does everyone else just go to the local tire store on the corner and hope they have something in stock?
-jason
Derek up North Avatar
Derek up North Derek Nicholson
Sherbrooke, Quebec, Canada   can
1961 MG MGA
I think everyone has gone to at least a 155 tire.
Staying with the 70 aspect ratio? Or moving up to 80? I can find a lot of 155/80-13. Is that the size everyone is using?
denns1989 Avatar
denns1989 Jeremy C
Hilton Beach, Ontario, Canada   can
1960 Austin-Healey Bugeye Sprite "Earl"
1967 MG Midget "Midge"
1974 MG Midget MkIII
1974 MG Midget MkIII "Bridget"
Yes I have looked into this as well, everyone seems to be using 155/80-13 (some even use 165/80-13's but you have to be aware of some possible "rubbing"winking smiley, think you may be able to special order 145's but I'm sure you will pay :-)
owlman Avatar
owlman Noah D
TX, Austin, USA   usa
How about 165/65r13? Those are a wider but I think almost the exact diameter as the 145r13.
autoist Avatar
autoist Tony Barnhill
Gurley, Alabama, USA   usa
1953 MG TD
1956 MG Magnette ZB
1959 MG MGA
1959 MG MGA Coupe    & more
I just got 4 Vredestein Sprints - 145R13 - from Coker Tire....total bill was $340 delivered to my garage in 2 days!
Edited because I hit the wrong key...
Tony Barnhill
Supplying Member: Used Parts for All MG's ~ New Parts for all LBC's
MOSS Distributor & VICTORIA BRITISH Dealer
MG's? YOU NAME 'EM, I GOT 'EM!
http://www.theautoist.com
In addition to the MG's listed on the left:
1971 VW Karmann Ghia
1972 Norton 750 Commando Motorcycle
1973 VW Bug
1982 Mercedes 380SL
1985 Jaguar XJ6
Edited 1 time(s). Last edit at 2008-02-04 03:57 PM by autoist.
Ok. A little more digging...
Using the calculator presented on this site:
http://www.1010tires.com/TireSizeCalculator.asp
I put in our three sizes discussed so far, and one more. It's unbearably hard to read in this format, but here's the data. Looks like 155/65-13 would be the best, but I can't find tires at tirerack.com for that size. 165/65-13 is next best, and there is a tire like that at tirerack. 155/80-13 is a bit out in terms of diameter but has the most selection at the tire website.
145/70R13
Section Width: 5.70 in
Rim Diameter: 13 in
Overall Diameter: 20.99 in
Sidewall Height: 3.99 in
Radius: 10.49 in
Circumference: 65.94 in
Revs per Mile: 990.9
Actual Speed: 60 mph
Speedometer Difference:
Diameter Difference:
155/80R13
Section Width: 6.10 in
Rim Diameter: 13 in
Overall Diameter: 22.76 in
Sidewall Height: 4.88 in
Radius: 11.38 in
Circumference: 71.50 in
Revs per Mile: 913.8
Actual Speed: 55.3 mph
Speedometer Difference: 8.44%
Slow
Diameter Difference: 7.78%
165/65R13
Section Width: 6.49 in
Rim Diameter: 13 in
Overall Diameter: 21.44 in
Sidewall Height: 4.22 in
Radius: 10.72 in
Circumference: 67.35 in
Revs per Mile: 970.1
Actual Speed: 58.7 mph
Speedometer Difference: 2.14% Slow
Diameter Difference: 2.1%
155/65R13
Rim Diameter: 13 in
Overall Diameter: 20.93 in
Sidewall Height: 3.96 in
Radius: 10.46 in
Circumference: 65.75 in
Revs per Mile: 993.7
Actual Speed: 60.1 mph
Speedometer Difference: 0.28% Fast
Diameter Difference: 0.29%
Thanks for the tip, autoist.
Here's a link to the product page for those tires: http://store.coker.com/prod/145r13-vredestein-sprint.html
autoist Avatar
1953 MG TD
1956 MG Magnette ZB
1959 MG MGA
That's them! We're sandblasting & painting my wire wheels right now while we wait for 5 new tubes to arrive from Moss. I thought about going with a larger tire but the 145R13 matches the original 5.20 tire in size.
Tony Barnhill
1973 VW Bug
1982 Mercedes 380SL
1985 Jaguar XJ6
roland Roland G
Calgary, Alberta, Canada   can
I had Cooper 155 80 sr13 tire put on mine. Nicer softer ride.
Mityfast Avatar
Mityfast Paul Beevor
Barrie, Ontario, Canada   can
I went with 175 70R 13 with Yokohama Avid T4...took a little modification (grinding and cutting around the inner rear fender opening) to keep from cutting rear tires on hard cornering...and only a few swings of a mallet to modify the front inner wheel well so that no rubs...and i am pleased with the ride and handling.
1975 Midget with Minilite clone wheels
owlman Avatar
owlman Noah D
TX, Austin, USA   usa
P.O. put Kelly 165r13 on mine, no problems on fit. I think speedo is off about 5%.
owlman Avatar
owlman Noah D
TX, Austin, USA   usa
Actually, I read that the stock eurometric sizes like 145r13 and 155r14 had an aspect ratio of 82. Is that true for us or was it 70?
cfrench Avatar
cfrench Silver Member Carl W. French
Alfred, Maine, USA   usa
Kelvin had written in a good article about MGs and tires that the true aspect ratio was 82
Carl W. French
Alfred, Maine
Southern Maine LBC welfare shelter
67B will be in our will
73BGT Daily driver
72 Triumph Bonneville
Many more that change often
http://s5.photobucket.com/albums/y183/leylandauto/
Virginia, USA   usa
Here's a question-- can the 155 80 r 13 be used on a wire wheel midget? Specifically, do any problems arise from pairing a standard sized tube with a slightly larger than stock tire?
Edited 1 time(s). Last edit at 2008-02-24 11:01 PM by superkaz661.
