Lowering a Late Midget (1500)
razoredge34 Avatar
razoredge34 Scott Perry
Simi Valley, California, USA   usa
1976 MG MGB
I'm wondering if it's (reasonably) possible to lower a late model 1500 Midget. I see the Moss kits apply to earlier cars only. I'm only talking a tasteful drop of an inch give or take.
Thanks,
Scott
IronHead71 Avatar
IronHead71 Billy Flanders
Silver Spring MD, USA   usa
Heat the springs!!! Or cut them!!! Haha don't do that, its not safe! Other than that useless piece of info, I have no idea. This is were it gets turned over to the crafty veterans.
Hound Dawg Racing Avatar
Hound Dawg Racing T2-- Hound Dawg Racing
Phoenix, AZ, USA   usa
You can custom order a set of springs with whatever weight ratio and probably up to a 2" drop. I think you can custom order springs through Moss as well. If not, Winners Circle should be able to do it.
owlman Avatar
owlman Noah D
TX, Austin, USA   usa
Yeah, Moss lists some different height front springs. The leaf spring lowering kit says thru '80.
I saw Victoria British has a 1/2" front lowering kit too.
moreso74 Avatar
moreso74 David Maples
Augusta, Georgia, USA   usa
The Winner's Circle has spring pans that lower the front. Then use lowering blocks on the rear springs. Don't cut the front springs, it's not necessary.
David
Greenville, SC, USA   usa
You can lower the front, by spacing the spring pans lower in the lower control arms down, in the rear spacer blocks between the rear end housing and leaf springs.
Edited 1 time(s). Last edit at 2007-12-15 07:45 AM by Speedracer.
razoredge34 Avatar
1976 MG MGB
Great, that is just the info I needed. I guess my Moss Spridget catalog is out of date or I (more likely) misread it.
Thanks,
Scott
owlman Avatar
owlman Noah D
TX, Austin, USA   usa
I hope it works out for ya! I've been thinking about doing this as well.
razoredge34 Avatar
1976 MG MGB
I'm planning it as my February (or so) project. I'll post some pics...
dcz Daniel Zeigler
USA   usa
I am also thinking about lowering my car. Can someone place up some links or part numbers to the parts needed? I am not familiar with Winner's circle as I am new to the whole MG thing.
Derek up North Avatar
Derek up North Derek Nicholson
Sherbrooke, Quebec, Canada   can
1961 MG MGA
www.spridget.com/
http://www.spridget.com/catalog/21.gif
http://www.spridget.com/catalog/22.gif
Edited 1 time(s). Last edit at 2008-04-06 06:53 AM by Derek up North.
Bill Young Avatar
Kansas City, MO, USA   usa
1952 MG TD
1959 MG MGA 1500
1973 Lotus Europa
Victoria British has the kits for the front and the rear shown on the page linked. You can easily make your own front kit from parts available at your local hardware store also and probably save a few bucks. Use grade 8 bolts just to be safe and some steel tube or spacers the length you want to drop the front, usually about 1" is the max recommended for this method. If you want to go lower then you need to look into shorter springs. The lowered pan method will not alter the ride where shorter springs may. In the rear it's probably just as well to purchase the kit. http://www.victoriabritish.com/icatalog/sm/full.asp?page=23
Bill Young
'73 Midget
'59 MGA
titus2669 Avatar
titus2669 Titus Popa
Sacramento, USA   usa
^^ So if I purchase the springs do I need to purchase the lowering front kit as well? Will I drop it even lower if I purchase both then just with the springs?
Bill Young Avatar
1952 MG TD
1959 MG MGA 1500
1973 Lotus Europa
Unless you have a race car IMHO you don't want to go more than about 1 1/2" lower on a RB car. Get much lower than a regular CB and you'll really start having problems negotiating speed bumps and man hole covers in the street. Consider your exhaust pipe as flat and expendable, it won't last long if the car is too low.
There's no magic formula for how a car will react to any given spring as far as ride height reduction. I tried heavy duty 1500 front springs in my V6 Midget and the front was lower and softer than with the stock 1275 springs and using one spring spacer. I wouldn't advise combining lowering methods until you've tried one and are sure that you need or want to go lower. The best method would be replacing the springs, both at the front and rear, but the lowering blocks and spacers in the front pans works well for a moderate drop and is much less expensive.
Bill Young
'73 Midget
'59 MGA
