Passenger side frame rail damage repair - mobile welder
L8RSK8R Ciaran W
LA JOLLA, CA, USA   USA
I doubt the mobile welder I have in mind, has repaired an MG Midget frame rail before.
Is there anything really complicated, or advise I can give him to correctly repair it?
Passenger side sway bar mount has ripped away from the rail. Should I have both sides worked on/reinforced while he's here?
L8RSK8R Ciaran W
Damaged sway bar mount
KIMG0227.JPG    25.4 KB
KIMG0226.JPG    24.1 KB
S1 Elan Kurt. Appley
Akron, Ia., USA   USA
Common problem if you fit anything more than the stock swaybar. Both sides need to be re-enforced.
L8RSK8R Ciaran W
Hopefully this holds up. Took him 2.5 hours = $180. He added side support brackets.
KIMG0235.JPG    51.6 KB
KIMG0244.JPG    26.8 KB
KIMG0242.JPG    25.4 KB
KIMG0240.JPG    28.8 KB
Fresno, CA, USA   USA
Liability insurance paid up ???
littlecars Avatar
littlecars David Bassett
Nashville, TN, USA   USA
1965 MG Midget MkII "Buffoon"
1966 MG Midget MkII "Swiss Cheese"
Nice jackstands! But, necessity is indeed the mother of invention. Looks like $180 well spent.
Fresno, CA, USA   USA
Work Looks Good. Even Harbor Freight has "Car Ramps" for like $30.00 ??????? A lot cheaper than Medical bills or WQRSE
GeorgeOhr Nonya Business
Yes, confused, USA   USA
In reply to # 3676713 by oleanderjoe Work Looks Good. Even Harbor Freight has "Car Ramps" for like $30.00 ??????? A lot cheaper than Medical bills or WQRSE
I'd trust those two rims over ramps. I've seen ramps collapse. Dad made some 45 years ago out of 5" angle that were MONSTERS; musta weighed 75# each. He finally cut them up to use for other things as there were so damn heavy. Held up the '69 F100 just fine though.
Fresno, CA, USA   USA
WELL; The first "ONE or TWO" just under the wheel, I have no problem with. , its 3, 4, 5, 6, 7, that worry me. ?? Ever see those Kung FU Dudes bust a stack like that. Breaks all the WAY to the BOTTOM
L8RSK8R Ciaran W
Maye a 7.5 earthquake would have shifted this Midget. Engine was already removed, welder was 300lbs +, needed all the room we could muster.
littlecars Avatar
300 lb welder and a Midget walk into a bar........smileys with beer
Fresno, CA, USA   USA
PERFECT David PERFECT ???????
L8RSK8R Ciaran W
Small welder.
midget welder.jpg    30.8 KB
1966 MG MGB MkI
