many posts back, comment on running vinegar in radiator
Chas 906 Avatar
Chas 906 Chuck Peterson
Iron Mountain, MI, USA   USA
When flushing the engine, I assume you remove the lower hose and let the crap drain out from that point? or is there another drain that works better? Does all the crap drain out of the radiator?
you are correct, remove the lower hose to drain the radiator and engine (and put a garden hose there to back flush the engine and then the radiator, though it is a loose fit)
to drain the heater core directly you can remove those hoses and back flush that too
Chas 906 Avatar
Thanks Norm.
