Need part number for firewall grommet
Toader73 Avatar
Toader73 Tim Cox
McKinney, TX, USA   USA
1971 MG Midget "Murder MG"
Anyone know the part number from Moss Motors for the firewall grommet where the water temp sensor feeds through?
Dutch 1960 Avatar
Dutch 1960 Mark Holland
San Diego, CA, USA   USA
240-515
Toader73 Avatar
Toader73 Tim Cox
In reply to # 3660868 by Dutch 1960 240-515
Thanks Dutch. Any advice on getting the sender unit back through the grommet? I tore it to hell trying to push it through. I don’t see how the big nut and the temp sender fit through without cutting it away some
ice Avatar
ice Gold Member Larry Ice
Lawrenceville, GA, USA   USA
Tim, cut through one side of the new grommet, slide the temp sensing wire through the cut and push the grommet back into the hole in the firewall and you're home! I bought an assortment from ebay and it does a pretty good job of providing a wide range to grommet sizes for your needs.
Iceman
Atlanta GA
60 AH MK1
62 AH MKII
67 Midget
71 Midget
Dutch 1960 Avatar
I generally use universal parts and adapt. In any case, Larry is correct. Cut one side and when you fit everything back together in the firewall, it will close up. A dab of silicone on the assembly will really seal things up, but in an open car, that last bit of sealing off the engine room is not so important. There are lots of pinhole leaks around the firewall and foot wells anyway.
Toader73 Avatar
Toader73 Tim Cox
Good call fellas. Thanks for the ideas.
Mojan Mojan Norouzi
Fremont, CA, USA   USA
Toader73 Avatar
Toader73 Tim Cox
Nice...I have to go up there today. Good looking out!!
