Mg Midget 1979 NO SPARK
GusRowell117 Gus Rowell
Barnard Castle, durham, UK   GBR
Hi all
Mg suffering with no spark problem. Tried changing the coil and the distributor but nothing!!! Cant work on it anymore today because of the rainsad smiley but have no clue whats happening. New to all this so can do with any help out there cheers!
ken472 Avatar
ken472 Ken Petersen
Luverne, MN, USA   USA
Did you check for voltage with switch on. Could be bad ignition switch. Need a test light or volt meter. I presume the starter works. Could be a bad coil wire to the distributor. I’ll say what everyone else says. Check all grounds. Hope this helps.
ice Avatar
ice Gold Member Larry Ice
Lawrenceville, GA, USA   USA
What kind of distributor?
Iceman
Atlanta GA
60 AH MK1
62 AH MKII
67 Midget
71 Midget
GeorgeOhr Nonya Business
Yes, confused, USA   USA
I show that you UK guys have points in '78 but no info on '79 models. I would imagine that year would have breaker points too. Clean with a nail file, emory board or sandpaper and gap to .014-.016. You can do a quick check for power to coil by watching points break as an assistant tries to start the car; watch for sparks.
66jalopy Avatar
Lake City, FL, USA   USA
Do you have 12v at the battery side of the coil with the ignition on? Place to start. If you don't it may be a bad connection or ignition switch. Take a jump wire from battery to coil and see if you get spark
Hidalco Co Duindam
Pukekohe, franklin, New Zealand   NZL
1/ turn ignition on. 2/ Remove distributor cap . 3/ Pull out high tension lead from cap leave other end in coil. 4/ Hold end of h/t lead to ground not touching. 5/ Open manually breaker point . You should get a spark!
no spark your problem is coil side , faulty coil or no power to coil. if you do get a spark must be distributor or leads or plugs. Good luck Co
Hi all thanks for feedback. So tried afew of your ideas this morning. Tested for spark at breaker points and NOTHING. Then went to test wire from coil to distributor and that is fine. Tested wires from coil to starter solenoid and thats fine. Discovered there is no power coming to the coil (tested coil and its fine also brand new). So i was wondering if you knew any ideas into why my coil isnt getting power. Cheers
ken472 Avatar
ken472 Ken Petersen
Did you do an ohm test on the large coil wire? Or the new coil is bad? Did you by any chance hook the coil up backwards?
Edited 1 time(s). Last edit at 2018-01-05 07:06 AM by ken472.
Checked large wire and it all looks good. Also checked the coild for continuity and all checks out too. Mystery and coils on fine also have a working but beaten up one that also isnt working.
Edited 1 time(s). Last edit at 2018-01-05 07:10 AM by GusRowell117.
ken472 Avatar
ken472 Ken Petersen
Do you have a ballast resistor on this car? If so it could be bad they burn out like light bulbs. I still think there could be a broken wire from the ignition switch to the ignition or the switch is bad. You could have the switch in the on position and try to jump start it from under the hood with a push button switch or just 2 wires.
Edited 1 time(s). Last edit at 2018-01-05 07:13 AM by ken472.
Dont have a ballistic resistor. Curious thing though, The wire that goes from starter solenoid to the coil doesnt have any power coming out of it? Will also double check the wires from ignition
Edited 1 time(s). Last edit at 2018-01-05 07:21 AM by GusRowell117.
ken472 Avatar
ken472 Ken Petersen
Solenoid bad?
Thats my thought. maybe another trip out to the parts dealersmiling smiley
Just got a new one so fingers crossed. Also turns oit the terminal for the coil is loose and wobbly.
Edited 1 time(s). Last edit at 2018-01-05 08:45 AM by GusRowell117.
Solenoid in but no differencesad smiley cant think now. Surely if it was the ignition switch the engine wouldnt turn over? Am i wrong
ken472 Avatar
ken472 Ken Petersen
You should not have any loose or wobbly parts
1973 MG MGB MkIII
