Moss Motors lower hinge mount.
rsvmgb1974 Avatar
rsvmgb1974 Silver Member Robert Vining
Capon Bridge, Capon Bridge, USA   USA
Economical repair if you don't need to replace the whole A pillar.
I ordered one for the right passengers side, but it seems that the holes for the machine screws don't align with the original holes. I would think the taper goes to the bottom. If I turn it 180 the holes would align but the taper would be wrong. Anyone ever used these?
ZS - T 028.JPG    29.2 KB
ZS - T 029.JPG    36.9 KB
ZS - T 030.JPG    36.4 KB
ZS - T 033.JPG    66.8 KB
tim65mgb Avatar
tim65mgb Silver Member Tim Guntly
Cherry Valley, IL, USA   USA
1960 Daimler V8-250 "SP250"
1967 Jaguar 340
1971 MG MGB GT
1973 MG Midget    & more
Could it be a LH side and be mis labeled?
I would call moss technical department. They will take care of you.
S1 Elan Kurt. Appley
Akron, Ia., USA   USA
Looks right to me. Just needs to be flipped over. I don't see a problem.
Kurt.
tim65mgb Avatar
1967 Jaguar 340
1971 MG MGB GT
Loking at it closer, just flip it around and all is well.
rsvmgb1974 Avatar
In reply to # 3641387 by tim65mgb Loking at it closer, just flip it around and all is well.
Thanks, got it figured. A fellow from Moss sent me to this link from 2012.
http://www.mgexp.com/phorum/read.php?3,2003166
Midget hinge plate 005.JPG    45.2 KB
hoggie Avatar
hoggie Mike Hogan
Oklahoma City, OK, USA   USA
This is one of those parts you can easily reproduce with some 20 gauge stock so you can easily modify the size of the patch to meet up with good weldable metal. Probably just needed a replacement screw plate because the originals rust out due to water seepage from the windshield and fender. When I repaired my A post, I added a hole at the bottom of the A post to provide a drain hole and increase air circulation to keep the A post dry inside. Also be sure to use a lot of weld thru primer when you close the A post to protect the inside as best you can.
