how do I get the radiator past the fan and cross member for removal?
mike3272 Michael Blanchard
Bridgewater Township, NJ, USA   USA
Trying to pull the radiator out of my 76 midget without removing the cross member or fan is it possible, without causing damage?
khallam Kurtis Hallam
Lincoln, CA, USA   USA
Very carefully. I know that isn't much help but I just pulled mine to switch out the water pump and it is a very snug fit. I think I accidentally hit the radiator against the fan a couple of times, luckily not too much damage. You can' gently bend the top of the (i'm going to call it a crossmember) metal that the radiator connects to in front. Take off all the hoses and it gives you a little more mobility in the slot. I had to slide it back and forth until I could get it just right and then slowly slid it out. Sorry if that isn't too much help.
please don't bend the top of the radiator shroud (most of our cars have had that done to them by at least one DPO), it creases it permanently
In a ratty old beater, sure, bend away, but it is a hack way to do it if your car is a cherished classic.
The correct way to remove the radiator is to remove the entire shroud with it. Unfortunately, that requires removing 6 (or is it 8?) fasteners, instead of just the 4 holding the radiator to the shroud. Each of them is a hassle to get to, and some require long extensions and removal of other parts to get clear access to.
this is why so many simply bend the top of the shroud instead
N
Sorry, to clarify I was not talking about the shroud. I DEFINITELY did NOT bend the shroud. I took the whole shroud out with the radiator. It is a patience game. Just keep slowly working at it and the radiator will come out. I did not bend anything taking the radiator out (even though I mentioned you can).
Floydinit Avatar
Floydinit Bob Rank
Waldorf, MD, USA   USA
1972 MG Midget MkIII "Silver Ghost"
1994 Chevrolet Silverado 2500 "Blue Beast"
1995 Chevrolet Corvette "Babs Toy"
Or you can put a hinge on it for easy access.....Bob
2014-09-14 12.04.28.jpg    41.5 KB
tomshobby Avatar
tomshobby Tom Smith
Windsor, WI, USA   USA
I altered this 1/4" drive socket so I could use it with an open end wrench and short enough to have the clearance needed to get on the fan screws and off again when the screws are loose. This allows me to install and remove the fan with the radiator in place. It works with my 74 not sure it would work with a later car. With the belt off or loose I can spin the fan to remove or install the screws.
Tom Smith
1974 Midget
1976 TR6
IMG_6587.JPG    29.5 KB
IMG_6588.JPG    30.1 KB
IMG_6589.JPG    24.5 KB
Wayne Burner Avatar
Chester, NH, USA   USA
CtMGDude John R
New Fairfield, CT, USA   USA
I'd take the fan off. Loosening a belt is no big deal. Bending those cooling fins is.
Colonel musturd 79 Avatar
Colonel musturd 79 Michael McKinney
Winchester, VA, USA   USA
1978 MG Midget 1500 "Colonel Mustard"
1987 Pontiac Fiero "SILVER BULLET"
On a 1500 the clearance between the clutch fan and the radiator is very tight , to remove the radiator with the least risk of damsge is to remove the water pump and housing then you have so much more room to get the radiator out of the body . I know it is the long way around but unless you have help it is the safest way.
Amore della Strada
For the love of the road
