hs4s
hs4s
  This topic is about my 1975 MG Midget 1500
mwoulbroun Michael Woulbroun
Sebastopol, CA, USA   USA
Changing to HS4's.
Is this the right fuel line config?
WIN_20170618_205023.JPG    29.5 KB
WIN_20170618_205035.JPG    28 KB
WIN_20170618_205056.JPG    34.8 KB
WIN_20170618_205349.JPG    33.6 KB
...can't tell from your photos (taken from too far away) if you've connected the fuel supply to the fuel ports or to the vent ports
Can you take a close up of one of each of the float bowl tops to be sure?
By the way, it looks like you have connected the two vents to each other with that stainless hose. That will not work. Those vents must be open to atmosphere (run a long hose from each down to the ground).
N
Left has fuel inline on top and carb to carb on bottom. Middle is a shorter. Right has carb to carb on longer inlet.
HS4..jpg    42.9 KB
HS4.jpg    38.7 KB
here, check out this current thread, with more photos:
http://www.mgexp.com/phorum/read.php?3,3460863,3535566#msg-3535566
from your latest photos I think you've got it right
The photos have different lines
You are correct, but only one thing is different: on his the fuel supply goes to the front fuel bowl first, and then to the rear. On yours it goes to the rear first, and then to the front. Either should work as well. I depends on which carb has the float bowl lid with the two fuel ports available and which one has the single port, which depends on which car the SUs came off of, originally, that's all.
Edited 1 time(s). Last edit at 2017-06-20 06:07 AM by Kerr.
bev sleet Avatar
bev sleet Bev S
your are correct Michael , my pics are not very good but will try to send some.
IMG_1241.JPG    48.6 KB
IMG_1244.JPG    35.9 KB
IMG_1240.JPG    48.9 KB
