wiper motor
2455 Avatar
2455 Bill Rogers
ocklawaha, FL, USA   USA
Is there a way to check a wiper motor i don't know if it's my motor or my switch ?
2455 Avatar
2455 Bill Rogers
Well guess no one knows or it so easy and i just don't see it lol
ice Avatar
ice Gold Member Larry Ice
Lawrenceville, GA, USA   USA
Run a jumper wire from the battery to the hot lead on the wiper motor making sure that the motor is well grounded. If it won't run after that you prob have a bad motor that needs to be pulled and cleaned along with cleaning the commutator.
Iceman
Atlanta GA
60 AH MK1
62 AH MKII
67 Midget
71 Midget
bev sleet Avatar
bev sleet Bev S
x2 what Larry said but if it dous run then it's your switch.
mgtonyditter Avatar
mgtonyditter Tony Ditter
Brookhaven, NY, USA   USA
That long teleflex cable gets gunky up too, disconnect it at the motor and see it it runs free
S1 Elan Kurt. Appley
Akron, Ia., USA   USA
On earlier cars the wiper motor is wired always hot with the wiper switch providing the path to ground. Be careful when hooking up a jumper that you are actually providing a bypass to the switch to ground if the later motors are wired the same way.
Kurt
