Finally done with the full suspension rebuild!
jrl9141 Avatar
jrl9141 Jason LeMaire
Church Point, LA, USA   USA
1974 MG Midget MkIII "Amy"
I finally had the time and parts to finish the full suspension job. As many have said what a difference!!
The car rides a drives much better!! Here's what I did.
New shocks all around curiosity of Peter at World Wide Parts (thanks)
340 lbs springs
Super Pro bushing
Rear lowering kit
Here's some photos
1974 Midget
Jason
IMG_0044.JPG    14.2 KB
IMG_0078.JPG    12.4 KB
IMG_0080.JPG    17.9 KB
IMG_0082.JPG    19 KB
bintopo Brian Thompson
Aurora, ON, Canada   CAN
Looks really good Jason.
smileys with beer
Brian
jrl9141 Avatar
Thanks!
1974 Midget
Jason
CtMGDude John R
New Fairfield, CT, USA   USA
Superb job!!! smiling smiley
taylorschone Taylor Schone
St. George, UT, USA   USA
Jason - Can you share the wheel/tire specs you are running? Also, did you only do the rear lowering kit or did you also do the front? Looks great!
1972 Midget - Aqua/Navy
trowe9 Avatar
trowe9 Gold Member Tracy Rowe
Baxter Springs, KS, USA   USA
Wow, thanks for sharing! You did an excellent job, it looks great!
Tracy
73midget Avatar
73midget Chris Edwards
Carrollton, TX, USA   USA
Nice! having a good fresh suspension revives a car in ways you didn't realize had slipped over time. It's a nice feeling.
jrl9141 Avatar
Thanks guys the handles much better you really don't know how bad the suspension can get until you fix the entire system. The wheels are 14 inch VTO with 185, 60 mounted. The 340 lbs return rate springs are an 1 inch lower then factory setup. So both the front and back have been lowered. At first I put a full front lowering kit but there was too much rubbing so I took the kit off. No issues since.
If you got with the 400 lbs return rate they are 1 1/2 inch lower..... has me thinking about making the switch. smileys with beer
1974 Midget
Jason
