Need some info please...
Posted by 73 MG Midget
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
Hi everyone Im a new member...
I just pulled the motor and trans on the midget
(it was my first time)
the clutch was not working...and had a leaking slave for the clutch..
and the throw out bearing was in 2 peices...
i have all the parts but when i was cleaning up i found a pin..
its about 1/4 inch round and 3/4 inch long....
it was clean (no oil or grease on it)
couls it be something for the shift leaver....
i had a frien helping me and he took the shifter off..
i think he said he droped something if anyone has a thought on what it could be
thanks for your time
its a 73 Midget with 73K
WayneW Avatar
Wayne Witgenstein
Nashville, Tennessee, USA   usa
If it looks like #4 in this pic, you should have 2 of them. They hold the throwout bearing to the shaft.
-Wayne
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
thanks for your reply Wayne...i was wrong about the size its about 1/8 around....
the throught bearing was still in place just broken
carcrazie51 Avatar
Steve Christiansen
San Clemente, CA, USA   usa
Bill,
Nothing like you describe is in the transmission or clutch system. Sounds like a roll pin. If it was in the clutch area, it could be why your to brg broke. Maybe that roll pin was used in place of a cotter pin on the clutch slave cylinder clevis pin.
I hope your friend was careful as there is a spring and plastic cup below the shifter that can easily be lost once the shift lever has been removed. The spring and cup sit in the shift rod. These keep the shifter from rattling when driving. Kind of important. Cup is white plastic and spring is about 3/4" diameter and about 1" long. This could be what he dropped.
Ol Phartz Partz   – San Clemente, CA USA We are car crazy people who enjoy preserving the automobiles of the past. Finding obscure parts new or used to help keep the cars of our past on the road is our goal. We also strive to find or produce uprated/modern parts for these vehicles to allow them to be more roadworthy. One way of keeping the past alive is to preserve automobile memorabilia and collectables. When we can find these items of nostalgia we will add them to our store
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
Thanks Steve...I been up most of the nite thinking about that pin...
it looks like a bearing from a U-Joint it took a long time to think of that
but i didnt do anything to the u joints...we had the car about 4 years...
or that pin thing could have been laying around on the floor
and I will make sure the spring and the plastic cup are in place
carcrazie51 Avatar
Steve Christiansen
WOO! The pin looks like it came from a U-Joint? Not a roll pin but a needle bearing pin? Check your crankshaft. The pilot(spigot) bearing on later 1275 is a caged needle bearing instead of a bronze bushing. A bad pilot bearing(missing a needle) will cause the input(first motion) shaft to jump on take off or shifts resulting in or could cause a broken TO Bearing.
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
thanks for the info...
im going back to the car in about an hour
and i will check it out
stevyn knox
isle of man, United Kingdom   gbr
hey bill! post a pic so we can see it!
dlrhine Avatar
Dave Rhine
South, Carolina, USA   usa
Yep, a picture's worth a bunch of words...
smileys with beer
carcrazie51 Avatar
Steve Christiansen
Bill,
Does the pin that you have look like one from the center of this pilot bearing?
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
the pilot bearing is solid not like the pic
i looked for what ever it is I found and it gone
i will have to ask my buddy where it got to
66jalopy Avatar
Phillip Jolliffe
Lake City, FL, USA   usa
Wish I had a picture. If it was 5/16 it may have been one of the positioning studs from transmission to engine fell out when you took it apart. One goes top center hole the other is left lower side.
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
i did take a pic of it today....
i will post it later
it must not be for the MG because
the clutch is done and the wife is out driving it...
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
here it is...
my wife said the car is running great
did they ever make a 5 speed for the midgets???
evry time she drives it she says "it needs another gear!"
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
here is the fleet except for my 1999 K2500 pick up
73 MG Midget
69 Olds Delts 88
01 Lincon
85 Caddy Fleetwood
the caddy and the olds are for sale
66jalopy Avatar
Phillip Jolliffe
If you can find a Datsun 210 5speed they make an adapter kit for it but it'll cost you. I posted that guide pin as 5/16 but I may be wrong because that sure looks like one. It can fall out because it is only pressed in and when transmission is bolted to engine has nowhere to go. If that is what is it don't worry car will run just fine without it. It basically holds the engine and transmission lined up so you can put the bolts in.
66jalopy Avatar
Phillip Jolliffe
Go to Victoria British midget catalog page 42 item 38 dowel. I think that is it. Don't worry you don't need it, nothing bad will happen.
73 MG Midget Avatar
Bill ~G
Mackinaw, USA   usa
Thanks for the info...
the car is running just fine...
now..if the wife will keep her foot off the clutch
i wont have to do it again for a long time cool smiley
Greenville, SC, USA   usa
1967 MG MGB "The Biscuit"
That,s a flywheel dowel pin for the clutch pressure plate, knock it back into the missing dowel pin hole on the flywheel, and you are good to go.
