Is it just a connector or what?
Posted by dlrhine
dlrhine Avatar
Dave Rhine
South, Carolina, USA   usa
What is the white connector looking thing with the large brown wires running to it? It's below the fuse block & above my relays in the picture below.
I haven't seen it on any parts page that I remember & the brown wires appear to be the start of most of the electrical system.
I've often wondered about it, is it a fuseable link or just a connector?
confused smiley
012 (2).JPG (38.3 KB) –
James E Avatar
Jimmy Campbell
Bedford, Va, USA   usa
I'm not sure of what it is but, Man that sure looks nice in there!!
dlrhine Avatar
Dave Rhine
Thanks...
Any idea on the electrical piece?
Edited 1 time(s). Last edit at 07/04/2012 02:23PM by dlrhine.
pacomb Avatar
Paco Moreno de Barreda
Madrid, Spain   esp
No idea as of course it´s not an original wieing harness.
Cant you just open it and see what´s inside??
dlrhine Avatar
Dave Rhine
I've done some mods, but the item in question appears to be factory original...
92spi Avatar
ron arnold
longview, texas, USA   usa
1974 Fiat 124 Spider 1800
1978 MG Midget 1500 "Topper"
1981 Datsun 280ZX "Silverbullet"
1992 Rover Mini "Peewee"
it's in my '78 midget also.
stevyn knox
isle of man, United Kingdom   gbr
brown wires ignition switch to fuse, light switch to control box, starter solinoid to control box. on my wire diagram which is for a 72 looks like there is a connector? see black dot in pic! anyone else know?
is your control box still wired?
Edited 1 time(s). Last edit at 07/05/2012 06:26AM by pants007.
oldag98 Avatar
Jeff and Brittany Brackenridge
Choctaw, Choctaw, Oklahoma, USA   usa
1965 MG MGB "B"
1976 MG Midget 1500 "Yellow One"
1977 MG Midget 1500 "Dunkirk"
Is that not simply a main fuseable link?
RKM Avatar
RKM
Richard Marcks
Palm Desert, CA, USA   usa
Disconnect it and see what doesn't work.
Jonathan E. Avatar
Iowa, USA   usa
1979 MG Midget 1500 "The Midget"
looks like it came for a control box, my 79 midget also comes with it, but I don't find any use to it.... and sure looks good on your car...
prop46 Avatar
Prop Black Hole Midget
Missouri, USA   usa
I wish i had persued automotive engieneering ... Cause i would have designed in wires and gadgets inot systems that go nowhere... Just to confuse and piss people off...good times aye
Prop
refisk Avatar
Rick Fisk
In reply to # 2111861 by prop46 I wish i had persued automotive engieneering ... Cause i would have designed in wires and gadgets inot systems that go nowhere... Just to confuse and piss people off...good times aye
Prop
Didn't Lucas already do that? devil smiley
prop46 Avatar
Missouri, USA   usa
Exactly....thats why I love the man and who he was
We all need role models
Prop
dlrhine Avatar
Dave Rhine
The more I look at the thing, the more I think it might be a fuseable link...
refisk Avatar
Rick Fisk
In reply to # 2112017 by dlrhine The more I look at the thing, the more I think it might be a fuseable link...
Just did some internet searching for "AMP 180909". It's simply a connector for 4 wires. Why was it used? Dunno. Might be an access point for testing circuits during the assembly process or it might be a way to isolate components when troubleshooting a problem. Your guess is as good as mine.
dlrhine Avatar
Dave Rhine
THANK YOU, now I know!
I was hoping it was a fuseable link because it supplies some unfused circuits, kinda scary...
eye popping smiley
jimmycoco Avatar
Noah H
Alberta, Canada   can
Im quite sure it actually is a fusible link. If you look at the centre of it, you can actually see the fusible part. I replaced mine with a maxi-fuse when i rebuilt my wiring harness.
refisk Avatar
Rick Fisk
In reply to # 2112142 by jimmycoco Im quite sure it actually is a fusible link. If you look at the centre of it, you can actually see the fusible part. I replaced mine with a maxi-fuse when i rebuilt my wiring harness.
Sorry, but it's just a dual terminal splice connector. Look it up.
http://octopart.com/180909-tyco%2Belectronics-1390921
It's shown but not identified on this wiring diagram just to the right of the solenoid - item #63.
http://1978mgmidget.com/78-80_Calif_spec_wiring_diagram.pdf
Norm Kerr
Ann Arbor, Mi, USA   usa
yup, just a connector
On earlier model Midgets, this same job is done by a soldered joint behind the dash, right after the harness passes through the big grommet from the engine room into the passenger compartment. The joint is protected by a heat shrink tube (closed off on one end) filled with a waterproof sealer.
Beside it is another big joint of several wires, a bunch of grounds joined together, with one wire going to the earthing screw just on the engine room side of the grommet.
Norm
jeffnoll Avatar
Jeff Noll
Western MA, USA   usa
Looks to me to be the dirtiest thing under your hood. Remove it, or redo you're engine bay to better match it color wise smiling smiley
