MG-2013 is only 26 days away! · Corvallis, OR · July 17–21, 2013 · Visit MG-2013.com or the MG-2013 Forum for more info
Frame Rails, sway bar mounts ripped out
Posted by Acropilot Ty
Acropilot Ty Avatar
Ty Frisby
Newport Coast, CA, USA   usa
1970 MG Midget "Ty's MG"
I've been putting this one off for a long time now but as the project list gets shorter and shorter I need to start thinking of how I am going to tackle my frame rails where the sway bar attach point is ripped out on one side and bent on the other. I see Moss sells replacement rails for $100 each but that looks like a big/expensive project. I'm leaning towards re-skinning the bottom of the forward portion of the rails to keep time/cost down... any thoughts or suggestions? Is there a source for just the pads with the threaded holes for sway bar attachment or will I need to have these fabricated?
TyFrisby.com
pixelsmithusa Avatar
Ty,
I think skinning the bottom will be much less work and at the same time, you can use heavier plate stock and/or reinforce the inner side. Fabbing those mounts isn't difficult. Simply get some bar stock and drill and tap the properly spaced holes. If you don't do welding yourself, fins someone who is good with sheet metal. There's some skill involved in the right temperature setting so you don't blow holes/burn it up.
Gerard
http://gerardsgarage.com/
purpleGT Avatar
Bud Osbourne
Pittsburgh, PA., USA   usa
1974 MG MGB GT "The Grape"
x2 Gerard. Re-skinning the forward section of the frame rails will be pretty basic stuff, for anyone competent in welding autobdy sheet metal.
Another trick you might look into is using longer mounting bolts, which go up through the top of the frame rail, through a doubler on top of the frame rail, with lock nuts on top. It's an old Spridget racer's trick and it sure does work.
In reply to # 2022023 by purpleGT x2 Gerard. Re-skinning the forward section of the frame rails will be pretty basic stuff, for anyone competent in welding autobdy sheet metal.
Nice tip. Hadn't heard that one before.
Gerard
Acropilot Ty Avatar
Ty Frisby
I like the idea of "improving" this area in case I go with an oversized sway bar in the future. I used to weld aircraft tubing and repair exhaust systems in high school shop class using gas but the majority of my welding was arc at a Gold Mine in Alaska where 1/4 stick was the "small stuff". I'll have to practice a bit but my co-worker has a mig machine so I'll plan to re-skin the lower surfaces with un-threaded blocks on the inside to serve as bushings and install the threaded blocks on the top.
TyFrisby.com
mark w
lost angy, USA   usa
In reply to # 2022049 by Acropilot Ty so I'll plan to re-skin the lower surfaces with un-threaded blocks on the inside to serve as bushings and install the threaded blocks on the top.
Thats exactly what I would do, to my car or a customers
metalhead Avatar
Andrew F
NSW, Australia   aus
I would sleeve the bolt holes (add a compression tube) if you are running the bolts through to the other side of the rail. Otherwise over time I would expect the bolts to compress the rail, bending it and loosening the bolts.
Acropilot Ty Avatar
Ty Frisby
Good idea.
TyFrisby.com
purpleGT Avatar
Bud Osbourne
In reply to # 2022583 by metalhead I would sleeve the bolt holes (add a compression tube) if you are running the bolts through to the other side of the rail. Otherwise over time I would expect the bolts to compress the rail, bending it and loosening the bolts.
This is why you thread the bottom plate and lock nut the top. If you've installed doublers giving sufficient bearing area, you really shouldn't need to use sleeves, although that's certainly not a bad idea by any means. If you fail to thread the lower/bottom plate, you put most of the working load (at least the part of it that's causing the original problem) on the top of the frame rail. The idea is to spread the load out, so that things don't get ripped apart, again.
While it pleases me to think of someone driving a Midget hard enough to create this problem in the first place, I think the sleeves would only be needed under extreme, competition conditions.
Oh, yeah....one more thing: keep in mind that there will be some electrolytic action going on between the doublers and the original frame rail, where they are lapped, especially if air/moisture can get in between them. So, protect the metal accordingly, as local climate dictates.
Acropilot Ty Avatar
Ty Frisby
In reply to # 2022675 by purpleGT
So the long bolts and holes on top just keep the lower attach point from rocking. I suppose that is all that is required. I may just go stock then seeing as I have a 9/16 bar. I could easily punch the holes on top if I go with a bigger bar in the future.
TyFrisby.com
purpleGT Avatar
Bud Osbourne
In reply to # 2022840 by Acropilot Ty
Well, yes, but in doing so, the newly added stuff on top effectively doubles the strength (more than doubles) the strength of the sway bar mounts. But, yeah, you should be OK with just rebuilding the bottom of the frame rail, if you are running the 9/16" bar. If in doubt, solid weld the bottom plate to the side flanges of the frame rail. That should give you more than enough strength.
metalhead Avatar
Andrew F
NSW, Australia   aus
Ah, I follow you now. I agree that doing it that way ought to be strong enough, though personally I think I would still sleeve the holes - more just to satisfy the engineer in me than anything else. I did the same when I built the replacement gearbox crossmember for my Toyota box, despite knowing that with the way I built it and the thick plate steel I used it would never really have been an issue.
As an aside, is this ever much of a problem in a car that's not rusty? Anyone can see that the factory design is not great, but my car is very solid, with no rust whatsoever in these areas and I have been running a 3/4" swaybar for some time without any issues so far... Is this something I should take pre-emptive prevention for, or is it normally only an issue on cars where this area is weakened due to rust or accident damage?
oldag98 Avatar
Jeff and Brittany Brackenridge
Choctaw, Choctaw, Oklahoma, USA   usa
1965 MG MGB "B"
1976 MG Midget 1500 "Yellow One"
1977 MG Midget 1500 "Dunkirk"
I have had a 3/4" inch bar on my car for over a year, with poly bushings, and have had no problems. This is a big thick heavy bar. I did have problems with the rear bar, as the included reinforcement tabs were too small to spread the load on the rear sheet metal causing some slight deformation/creasing. These need to be larger if you run a rear anti-sway bar
