MG Magnette Forum
Horn Problem... it's goes off on it's own!!!!
Posted by racedriver
racedriver Avatar
Andrew McGee
Holmfirth, United Kingdom   gbr
Title says it all really.
It happened to me yesterday afternoon as I was reversing onto my drive, I thought I'd caught the Horn Ring whilst turning the steering wheel whilst looking backwards but this morning on the way to a meeting it went off a couple of times again, I popped under the bonnet (hood?) and disconnected the thin brown cable from the thick brown cable with black trace (workshop manual to hand I'm pleased to say). I got back in and drove a little further and again the horn came on but stayed on for a long time whilst in a traffic queue. Not wanting to appear like a hooligan I dove under the front of the car and disconnected the horn totally and that's the situation it's in at the moment.
So by disconnecting the thing brown wire I can figure it's not the actual horn switch (steering wheel centre) or the wiring that is shorting out so it has to be somewhere after the brown/black wire. I've found the huge relay where the brown/yellow comes from. Are these suspect or am I jumping in at the deep end again and have missed something else?
Still loving it though.
We're off to our first MG Car Club evening tonight as it's our local area Pride of Ownership meeting and I'm looking forward to taking the Magnette with or without horn!
TIA
Andrew
Martin O'B
Carlow, Ireland   irl
1958 MG Magnette ZB "Phyllis"
It would be worth disconnecting the wire running from the relay to the steering column( brown/black) and running a temporary replacement. If the problem persists, then the relay is faulty.
The original relays are pricey, so worth ensuring it's not a wiring issue first.
Martin.
Wray Avatar
Wray Lemke
., South Carolina, USA   usa
It's a pretty good bet the the wire in the column (stator tube) is grounding. If you follow the wires where they come out of the stator tube in front of the steering rack you can find the bullet connection for the brown/black and disconnect it there. Or, do it the easy way that Martin suggested.
The relays can be serviced if you don't mind taking it apart.
racedriver Avatar
Andrew McGee
Wray, I'd already disconnected the thin brown from the thicker brown/black wire thinking that it must be the column switch or the wire inside the column, however it continued to hoot occasionally after that so could only assume it was something else in the circuit.
I think I may have found it though, it appears that the woven loom has been resting on the metal bar that is the pivot point for the accelerator and it does look like it has worn it's way through to a brown wire. I think I'll reconnect the horn at the horn and try to force it to hoot by touching the loom against the pivot bar and if it does then I know to bypass that section. There's a new loom on the list of things to do when it goes for the body work doing.
So far (apart from the clutch issue on my other thread) it's going to plan, just to get to know the car and it's foibles before we strip it down for it's rebirth.
A.
racedriver Avatar
Andrew McGee
Horn sorted, it had indeed chaffed through the woven and plastic cover and was causing the relay to activate, I could hear it clicking even without having the horn connected.
The loom in that section looks very generous, lots of curves that don't appear to be needed and a metal tab that obviously hold the loom to the shell that looks in the wrong place because of the generous loom.
Has anyone got a photo of how the loom should route on the bulkhead.
Thanks again.
Andrew
Wray Avatar
Wray Lemke
Good find! I love the sound of twin Windtones. I have a set I want to hang on the MGB, they really get people's attention.
racedriver Avatar
Andrew McGee
Mine has only got one, albeit it's a bloomin' big one at that. I notice the workshop manual states two but I can't see the second mount point and there doesn't appear to be another brown/yellow lying loose anywhere near the existing horn.
Should they be the same size as the ones found in MGBs and Midgets. Though I must admit I do like the quite deep sound of this horn, a proper horn it is not an airy fairy squeak as the ones in my Midget are.
It's on the list... this list is growing considerably now.
smiling smiley
A.
Martin O'B
Carlow, Ireland   irl
Here is a photo of the bulkhead area, hope it helps. This is a replacement loom from Autosparks in the UK. Well made and they will add extra wires/ alternative connectors as requested, Lucar connectors on my voltage regulator. Fitting the loom is not for the feint hearted!!
The car should have 2 large windtone horns, one on each side of the front chassis leg. They are much larger than the horns fitted to an MGB. Can photograph if you wish, each horn has an individual feed from the relay (brown/yellow).
photo (2).JPG (40.7 KB) –
racedriver Avatar
Andrew McGee
Thanks Martin.
That's certainly a much different layout to what's under my bonnet.
The regulator is is a different place,I can't see the fusebox in yours yet mine is between the two heater pipes.
I think this is another thing for the list so that it's tidier under the bonnet.
A.
davido Avatar
David Overington
NSW, Australia   aus
Andrew,
Your layout is from a ZA, not a ZB! Very odd.
David
racedriver Avatar
Andrew McGee
It's a 57 car first registered on 11th May.
It certainly has the varitone window in the back and has indicators.
I'm now wondering how early in the production run it is.
A.
