MG Magnette Forum
Gearbox ????
Posted by magnette1
magnette1 Avatar
Andrew Murdoch
Busselton, W.A., Australia   aus
Could some one tell me if the gearbox in the Magnette is the same as the MGA please?
enigmas Avatar
Vince Stok
Melbourne, Australia   aus
Physically No.
Wray Avatar
Wray Lemke
., South Carolina, USA   usa
The bell housing is a bit different and the front of the transmission is cast differently.
While you could probably make an MGA transmission work in a Magnette, it would be very difficult to make a Magnette transmission work in an MGA.
laverda Avatar
Steve Carroll
Irvine CA, USA   usa
1952 MG TD
1956 MG Magnette ZA
1959 MG MGA 1500 ~ For Sale ! ~
1959 MG MGA Twin-Cam Coupe
Actually the MGA Twin Cam used the magnette Casting, but had the slave in a different location And some were close ratio boxes. The internals on the Magnette transmission are the same as MGA depending on year. I have a spare Magnette transmision if anyone has a need for one.
bills Avatar
Bill Spohn
While puttering in my parts shed, I found a close ratio trans that I believe came out of a Magnette, but it has a tailhousing like an MGB and the early MGB front case, so when they set the Magnette up for competition, they must have modified it. Anyone converted from the large MGA style mount to an MGB twin pad mount (presumably installing a removable crossmember to boot?
West Vancouver BC
Gofanu Avatar
Fletcher Millmore
Titusville PA, USA   usa
Bil-
Magnette uses two pad mount, but has sliding propshaft splines like 1500 MGA. The MGA single bush "eye" mount is unique to MGA.
I do not recall the details of the bellhousing/starter location, might be the same as the high starter MGA, or even higher (starter is very close to dizzy). But, the Magnette has the top mounted slave cylinder, provision for which is incorporated in the TC bell but not machined.
FRM
bills Avatar
Bill Spohn
I thought the Magnette case also had the big eye on the back (whether it used it to mount or not) but its ben a long while since I've been under one.
I also found an original Twin Cam trans while digging, which as you say, has the Magnette case but without the holes machined for the Magnette slave.
West Vancouver BC
Gofanu Avatar
Fletcher Millmore
Right you are, by the books. Too long since I've been under one too, and the snow is too deep to go look! Can't recall just how the mount works, but it uses Spridget front engine mounts.
Also, Maqnette has no remote. Anybody playing with these needs to know that there was maybe a change of splines/propshaft early on. Stories re this are murky, and I have no personal experience with this.
FRM
Bruce Hopgood
Montreal, Quebec, Canada   can
"The MGA single bush "eye" mount is unique to MGA."
Not so unique. Early Riley one-point-five has same single bush eye mount, uses no remote as well, gear ratios as Magnette, (according to book). Clutch slave, Lockheed, as per MGA or other but smaller bore.
salut
Bruce
geezer Avatar
charles durning
Magee, MS, USA   usa
1958 MG Magnette ZB "Chick Magnette"
I was under my '58 Chick Magnette on saturday. My bell housing is machined such that it has a provision for the top mounted slave and a bottom mount slave.
Wray Avatar
Wray Lemke
Charles, the problem is that the bottom hole can't be used for the slave; the front cover over the 1st motion shaft would need to be rotated and it won't fit that way. I've looked longingly at doing that to get around having to use the unique clutch slave cylinder on top.
Gofanu Avatar
Fletcher Millmore
Bruce - Not fair bringing Riley 1.5 into it! Very rare here and even though I was working in a big Brits only shop in a big city in the 60s, I never worked on one. I knew of two on the streets, and I kept my eye out because I wanted one.
Wray- You need the MGA cover/fork/bearing/slave. Or early (3 synch) B parts for the MGB diaphragm clutch and flywheel.
FRM
geezer Avatar
charles durning
Magee, MS, USA   usa
Slightly OT
Here is a Riley 1.5 that is for sale. I know nothing about the car nor the seller.
http://www.classicandsportscarparts.com/classic_british_automobiles.htm
Bruce Hopgood
"Not fair bringing Riley 1.5 into it!"
Fletcher, nobody ever asked to be fair! You are right about rare, I have one in my drive.
Staying OT, interestingly enough the Riley bell housing is quite unique such that it has a lateral cutout in the top to allow clearance for the steering rack.
Quite amazing the combination of transmission front plates and throw out arms geometry that BMC came up with. Do you think make work projects?
Salut
