Best fluid to use in a clutch master cylinder
TravelGuy Avatar
TravelGuy Kelly B
Morrow, GA, USA   USA
What is the best fluid I should use in my clutch master cylinder for my '74 MG Midget? It's been awhile since I have had to put any in and my memory is in senior mode right now...lol
Thanks,
Kelly
topdoc56 Gold Member Charles F
Covington, LA - Louisiana, USA   USA
1956 MG MGA
1964 MG MGB
It is usually the same brake fluid that you have in your brake master cylinder.
Gary E Avatar
Don't mix and match...
ghnl Avatar
ghnl Eric Russell
Mebane, NC, USA   USA
1961 MG MGA "Calvin"
Generally, DOT 3 or DOT 4. First make sure there is not DOT 5 in there. DOT 5 is silicone based - it usually has a purplish hue (you can dip a strip of white paper into the reservoir to see to check that possibility). DOT 3 & DOT 4 are usually clear or slightly amber. When any of these fluids get old they'll become 'dirty' looking*. DOT 3 & DOT 4 are compatible with each other but neither is compatible with DOT 5.
Note that DOT 4 has a higher boiling point than DOT 3 (but adding DOT 4 to DOT won't raise the boiling point much). And, also note that the labels on DOT 3 & DOT 4 will likely say 'synthetic' but that does NOT mean they are silicone based.
And, to make it even more confusing, there is a DOT 5.1 which is NOT silicone based. It is also not very common so you may not see that on the shelf at the auto parts store.
* If you don't know what is in the system or how long it has been in there I'd suggest a full system flush. DOT 3 & DOT 4 are hygroscopic - they will absorb moisture (right out of the atmosphere). Over time this absorbed water degrades the brake fluid & lowers the boiling point. A full flush with fresh fluid every 2-3 years helps keep the system in good condition.
Eric Russell ~ Mebane, NC
Zur Avatar
Zur Silver Member Dave H.
Amarillo, TX, USA   USA
Especially worrisome in wet, humid climates.
Dave
