Vacuum advance mga
Kilcunda, Victoria, Australia   AUS
I have 2 very good restored carbies for my MGA1600. However both have vacuum advance ports and I will need to block one off preferably with a threaded plug to keep options open. Does anyone know what the thread is. I appears to be a little over 1/4 inch diameter with about 26tpi. 1/4 bsf is too loose.
Dandare Avatar
Dandare Danny H
Sydney, Australia   AUS
Should be 1/4 UNF I believe.
Danny
Slightly larger than 1/4inch. Thread is a bit coarser - about 26tpi
Ray
10MGA Russell Goebel
Wynnum, Queensland, Australia   AUS
Hi Ray,
I had the same issue of blocking off the vacuum port when changing to Mallory Dizy (without vacuum advance). Tried everything, in the end the best fit was 7mm screw (bolt). I am sure the correct thread is NOT metric, but this was the best possible fit.
Russell
jonathan in mass jonathan eagle
weston, ma, USA   USA
Just went through this sort of. You can buy the fittings from moss. The vacuum cables they sell are designed to fit into a 1600 carb. The 1500 carb had a larger threaded hole. My goal was different than yours, as I just wanted to install the vacuum cable. I think someone had replaced mine with 1500 carbs. In any case both of these fittings are available. You could solder closed a piece of tube to get what you want.
Jonathan
Thanks -would not be surprised to find out it was metric. BA - British Association is metric based??? 0BA has a pitch of 1mm and each finer pitch is 0.9 times the previous. The bolt that holds the choke cam is 0BA and the vacuum advance thread looks similar, but the diameter is a little larger.
Ray
weston, ma, USA   USA
I wouldn't mess with approximate threads. When you can just procure the correct pieces.
I would consider RTV. It might block the vacuum sufficiently and not damage the threads. Someday the future owner of the car will thank for it.
Jonathan
Hi Ray,
If it helps the 7mm screw fitted perfectly.....neither binding nor loose, just screwed in by hand then tightened, gently. Importantly, ensure the thread is short enough that it does not bottom out and damage the carby, instead tightening against the face of the vacuum take off.
Incidentally the thread is the same as the fitting on an Austin 1800 (Landcrab) carby overflow...if you can find one!
Russell
Dandare Avatar
Dandare Danny H
I have a feeling that this thread changed size on the H types somewhere along the line. A 1/4 UNF set screw fits perfectly in one of a pair of H4s from my Wolseley.
Danny
I have ordered a vacuum port plug from SU Burlen in UK but am not completely confident it will be suitable after all the various pieces of information I have been given. I will message when it arrives.
The vacuum plug Burlen sent (ABF110 which is 5/16 BSF) is too big for my 6020 bodies. It has the same thread as a double male union that I purchased some time ago thinking it would be needed. Previous message regarding changing of thread size seems correct - I have about five or six bodies and all have smaller diameter ports. I have located the remains of a vacuum advance with a diameter very close to the previously mentioned 7mm that fits perfectly. I will be able to block the hole with solder. Problem solved but I am still curious. I have included a photo of the union, the plug sent by Burlen and the end of the vacuum unit.
Ray
vacuumplug.JPG    16.4 KB
It appears that 7 mm x 1 mm is correct. This is an uncommon metric fitting and hard to obtain. This makes two metric fittings on this body. I managed to get a setscrew and it is a perfect fit.Ray
