Door post A template
beaton172 Jeremy Beaton
Ellershouse, NS, Canada   CAN
Hi everyone
I am in the process of replacing the sills on my 61 MGA. Was able to located a template for the B post, but nothing for the A post.
The bottom few inches is missing and this makes the alignment of the middle sill a problem.
any help would be great.
Thanks
Twofin David T
Would you like a measurement from bottom of hinge indentation to the flange that the sill will butt up to? I'm sure a fellow member is without cover sill/rocker and would be able to measure to the inner sill for you , then the outer part of the post is just a flap that goes on outside of the inner sill.
I have outers fitted so am unable to give you a dimension.
That would be great,
A measurement from any known point to the 90deg bend at the bottom.
Thanks
jeremy
