Pedal Washer
Pedal Washer
  This topic is about my 1959 MG MGA 1500
Richas Avatar
Richas Silver Member Rich S
Portland, Oregon, USA   USA
This is the extra thick washer that goes between the brake and clutch pedal on the pivot bolt. I am missing mine. I posted a request in the For Sale section in case someone had one laying around but maybe someone can measure theirs and I can kludge one together.
Part AAA4133
Nobody stateside seems to carry it.
Rich
Bandersnatch Avatar
Bandersnatch Larry Wheeler
Hillsboro, OR, USA   USA
1957 MG MGA "Rosie 2"
I ended up stacking some washers to approximate the appropriate thickness. After two years, they seem to be still holding up fine.
Do you know why chicken coops have two doors? Because if they had four, they'd be chicken sedans!
Richas Avatar
In reply to # 3513421 by Bandersnatch I ended up stacking some washers to approximate the appropriate thickness. After two years, they seem to be still holding up fine.
Sounds like a plan!
Rich
Gary E Avatar
I did the washer stack also.. You might find something at a hardware store in the little spacer box.
abowie Avatar
abowie Andrew Bowie
Adelaide, SA, Australia   AUS
1961 MG MGA 1600
1967 Jaguar E-Type "Rob's Car"
In reply to # 3513348 by Richas This is the extra thick washer that goes between the brake and clutch pedal on the pivot bolt. I am missing mine. I posted a request in the For Sale section in case someone had one laying around but maybe someone can measure theirs and I can kludge one together.
Part AAA4133
Rich
You need a lathe. Everyone needs a lathe.
Shall I tell your wife?
Andrew B, Adelaide SA
MGA 1600 and some Jaaaaags
www.projectetype.com
Don MGA 1600 Avatar
Rutland, Rutland, USA   USA
Rich,
The OEM pedal spacer measures:
1.00" outside diameter
.253 thickness of washer
.382" inside diameter
If you want, I can provide a picture of the entire assembly that takes a special Rubery Owens shoulder bolt.
Don
Richas Avatar
In reply to # 3513590 by abowie
yes. Also explain the addition to the garage.
Rich
Richas Avatar
In reply to # 3513691 by Don MGA 1600 Rich,
Don
Thank you so much!
JohnTyg Avatar
JohnTyg John Tygart
Syracuse, USA   USA
1959 MG MGA
Don,
Thanks for posting the measurements and please tell Andrew I have a lathe (bought it for my wife for her anniversary present).
Could you post the pic of the assembly?
Thanks,
John
Don MGA 1600 Avatar
John and Rich,
Here is a picture of the assembly. Three things to keep in mind when you are restoring/building the pedal assembly:
* Restore the running clearance between the M/C push-rod hole on the respective pedal and clevis pin. Note the clevis pin is .312 diameter
* Fit the bushing to the pedals so that the running clearance between the assembly spacer OD and ID of the bushing does not exceed .003" per side with a goal of .0015" per side.
* Make sure that the stack up of the assembly is such that the three spacers are clamped from rotation once the thru bolt is tightened so that each pedal if free to pivot between the ID of the bronze bushing and the OD of the clamped spacer.
With that said, it is a shame that so many other nicely restored MGA's lack the above detail during the restoration with the resultant are floppy pedals. My best recommendation if you do not have to tools or skill is to visit your local tool and die shop-not a shop that works on engines. A lot of these guys are car guys and often they will do this work for little or nothing since it is a break from their daily duties.
* 1.00" outside diameter
* .253 thickness of washer
* .382" inside diameter
The tubular spacers (X2) on either side measure:
* .752 long
* .375 ID
* .569 OD
The Rubert Owens bolt measures:
* 2.98 OAL
* 1" thread length
* 1.7" long unthreaded shank length
* .370 diameter of shank
I hope the above helps. Don
Edited 2 time(s). Last edit at 2017-05-19 07:11 AM by Don MGA 1600.
Clutch-Brake Pivot Assembly.jpg    7.9 KB
MC pushrods.jpg    35.5 KB
JohnTyg Avatar
JohnTyg John Tygart
Syracuse, USA   USA
1959 MG MGA
Don,
Helpful and thanks for the measurements.
Very usefull info that maybe belongs on Barney's site.
bikermga Avatar
bikermga Peter Tilbury
Surrey, BC, Canada   CAN
Cecilia lists it in the SF catalogue - p/n M7, spacer.
Peter.
3066james Avatar
3066james Jim Cheatham
Amelia, VA, USA   USA
Let me look in my stash of old misc hardware. I may have what you need.
Richas Avatar
In reply to # 3519382 by 3066james Let me look in my stash of old misc hardware. I may have what you need.
Jim,
Thank you for the kind offer but I have found one.
Rich
