1957 MGA 1500 engine number
hathors Avatar
hathors Harald Thorsen
Sande, Sande, Norway   NOR
1957 MG MGA
Hi
Im restoring a beautiful MGA 1500 and can't find anything regarding the engine number
The VIN is: GHNL 74440 and the title says 1957 MGA 1500
Can anyone help me to find someting regarding the engine number on my MGA
copernicus Avatar
copernicus Nick Kopernik
Western, CT, USA   USA
Harald, your VIN # is associated with an MGA 1600, first introduced in May, 1959 (VIN #68851) so your car was probably built in the later part of 1959. You may need to do a bit of investigation to find out how and why it is registered as a 1957. As for the engine number, there should be a metal plate attached to the right side of the engine block, just under the center plugs. Is the plate on the block?
hathors Avatar
1957 MG MGA
Hi
Yes it says BP15GB 57674.
mgaex189 Avatar
mgaex189 Platinum Member Giovanni Delicio
1955 MG MGA 1500 "C2"
1955 MG MGA 1500
1955 MG MGA 1500 "C1"
Hi Harald,
could you post a pic of the engine tag ?
The highest number with prefix BP15GB is 23000.
Thanks
Giovanni
copernicus Avatar
Harald, the engine is definitely for a 1500 MGA, but your number does not correlate to the VIN. Could you also post a photo of the tail lights as this may also help identify the base model you have.
hathors Avatar
1957 MG MGA
Hi
The tag is almost unreadable but it seems i got the letters wrong its GB15UH-57674
Bil 2007 300.jpg    49.2 KB
hathors Avatar
1957 MG MGA
Here is the tag on the heater..
IMG_0037.jpg    60.5 KB
copernicus Avatar
Harald, that's a very nice looking MGA you have there, not sure what there is to restore; your car really looks good! Your car's tail lights indicate a 1500 model, yet your VIN # shows it to be a later 1600 series car; could it be your VIN plate was replaced somewhere along the way? The engine number you last provided is "GB15UH-57674"; are you sure that it's not "15GB-U-H 57674"?
The VIN number is also stamped on the right side cross member inside the car. Many times this area can rust out and the number may be illegible, but you can try to see if you can find it. See attached link for more info:
http://mgaguru.com/mgtech/buying/buy101c.htm
Edited 1 time(s). Last edit at 2017-04-06 04:08 PM by copernicus.
Blueosprey90 Avatar
Blueosprey90 Jeff Sienkiewicz
New Milford, CT, USA   USA
Update your registry information on your home page, and you will eventually end up here.
http://www.mgaregister.nl/browseregisterresult.php?a=70000&b=80000
RJBrown Avatar
RJBrown Randy Brown
Queen Creek, AZ, USA   USA
This is a 58 MGA coupe engine tag. Could you post a picture of your tag?
As Nick above noted the numbers start 15GB not GB15
Edited 1 time(s). Last edit at 2017-04-06 04:24 PM by RJBrown.
IMG_3441.JPG    48.3 KB
Gary E Avatar
Also the screws that are holding the vin plate are not original. the originals were slotted stove bolts. (screws with nuts)
hathors Avatar
1957 MG MGA
I think it´s somthing not right with this MGA.
The tag found on the engine had different letters than this.. on your pic the lerrers where reserved in the one taken off my engine was put on from the outside.
I took it off and manage to brake it,but it says GB15UH-57674 when I put the pices together.
This tells me that I have to investigate a bit arround the VIN and Engine number
hathors Avatar
1957 MG MGA
The number is not visible du to rust...
I found a number on the body,but i dont know what that means...
IMG_0093.JPG    19.5 KB
mgaex189 Avatar
1955 MG MGA 1500
Hi Harald,
your body# 56071 is for a car with VIN 46124-46435.
You should look at the rail on the passenger site.
Please reassemble the engine tag and take a Picture and post it.
It was also possible to have "non-raised" letters on the tag.
We 're trying to help you find the real history about that car hot smiley
Gio
hathors Avatar
1957 MG MGA
Thanks for all information so far!
I`ll put the pieces together later today and poste a pic.
I found the old title from the US
Here it says MGA 1500- date 01.01.1958 VIN HDR43-46337 - Color: Withe
Engine 15GBUH/36608
I think maybe this is the original Title....
