Is this an MGA ignition lock?
MGARuss Avatar
MGARuss Silver Member Russ Sharples
NJ, USA   USA
1960 MG MGA 1600 "Bonnie"
1993 Mazda MX-5 "Bombita"
From what I can tell, this is a legit Lucas ignition lock. FP style key, screw terminals, works nicely. Does anyone know if it is from an MGA/other MG or what year it might be? It's not exactly like the one Barney shows on his website (the screw posts don't stick out of the back like they do on that one).
Russ
P.S. Anybody have any thoughts about cleaning the terminals? I'm thinking inside. Looks like I would have to grind the rivets off to open the lock up. Anybody tried that? Hate to ruin it. The reason it might be necessary is that my ohm meter reads 0.5 ohms across the terminal vs. 0.1 when the ohm meter leads are shorted together, so there is some internal resistance there. Given that this could easily have 15A flowing through it, half an ohm is a lot of resistance. Obviously I have to check the ohm meter leads were making good contact with the screw terminals but I am concerned.
Edited 1 time(s). Last edit at 2012-10-25 10:56 PM by MGARuss.
ignition-lock-1.jpg    17.8 KB
ignition-lock-2.jpg    18.4 KB
ignition-lock-3.jpg    23.2 KB
Bandersnatch Avatar
Bandersnatch Larry Wheeler
Hillsboro, OR, USA   USA
1957 MG MGA "Rosie 2"
It looks very similar to the repro one Moss sells with the exception of the Lucar terminals on the back of the Moss unit.
Unfortunately, mine had an after-market replacement switch installed. I saw the exact same switch as mine at Auto Zone when I was picking up some dielectric grease.
I guess that wasn't much help, sorry.
barneymg Avatar
barneymg Barney Gaylord
A later (cost reduced) model I suppose, but it may work very well. These switches have gross motion contacts inside, as you may see on one of my web pages. This makes the contacts self-cleaning by friction and scrubbing during normal operation. Put your ohm meter probes in the slots and tighten the screws for good positive electrical connections. Then cycle the switch on and off about a hundred times and see what you get for internal resistance.
mgageoff Avatar
mgageoff Geoff Howard
Ashburn, VA, USA   USA
Well, according to info from Pete Groh at British Car Keys (http://www.britishcarkeys.com/), my '58 is supposed to have a key in the range FP 626-750. Yours is in that range but I don't know his source for that info to determine if the same range applies to your year or not. I'd just email him.
He also has a link to a PDF of the Lucas part numbers on cars of our period including MGA that I think should cover the switch body (different from the tumbler insert). http://www.rroc.org.au/wiki/images/7/7b/LUCASEquipment19481962Cars.pdf
I can't see a Lucas part number of the switch in your pics, but that might be a way to get what you're looking for.
Geoff Howard
http://mgaexperiment.blogspot.com
Now Playing on the Blog (8/8/2013): Don't Blow Your Top
mgageoff Avatar
Oh, and I was going to suggest using DeoxIT spray instead of disassembly but I see Barney has suggested an even cheaper method to clean up the guts.
Geoff Howard
JackMG Avatar
JackMG Gold Member Jack Lindler
PO had "upgraded" mine to electric relay start and installed a 3-position switch...confused smiley
Gary E Avatar
I'm not sure mine is original.
images.jpg    7.4 KB
Neil MG Avatar
Neil MG Neil McGurk
Cumbria, UK   GBR
1956 Morris Minor
1958 MG MGA
1960 MG MGA
1961 MG MGA    & more
Interesting!
All five of my MGAs had exactly the same ignition lock as Russ shows and I know for sure that one (a Mark II) was original. Never seen one like the one in your picture Barney (on the top left of http://mgaguru.com/mgtech/electric/et124.htm right?), maybe that was from an early car? I collect any NOS or good used lucas parts, if they are cheap enough, and I have a box full of ignition switches.
The answer to the range of keys is easy, all FP keys are numbered between 626 and 750! I don't know the model years but I suspect FS (876 to 955) and possibly FA (501 to 625) keys were also used in the MGA.
RJBrown Avatar
RJBrown Randy Brown
Queen Creek, AZ, USA   USA
My 1960 MGA has a ignition switch that looks like the one pictured. The date code on the back identifies it being made in 10 of 59. It is an FP 719 keyed lock. There should be a date stamped on the bakelight opposite where it reads LUCAS ENGLAND. Looks to me like an original MGA switch.
DSCN2473.JPG    27.6 KB
DSCN2470.JPG    20.7 KB
barneymg Avatar
Sorry about that, Neil. The picture top left on my web page illustrating screw post connections was the back end of a 3-post lighting switch. Fixed now. Yes, the flat-back 2-post configuration is correct for the MGA ignition switch.
MGARuss Avatar
NJ, USA   USA
Randy,
I found a number on mine: "3 59" with "31449 E" above it but not on the Bakelite, its in the metal on the side.
lock-1.jpg    16.4 KB
mgageoff Avatar
That PDF of Lucas parts I linked to shows on p 48 that 31449 is the part number for MGA (except Mark II) for "Lighting Starting and/or Interior". I am not sure why they call it that, but it is the only part in the booklet that maps logically to the ignition switch.
So, looks like a confirming data point that what you have is original.
Geoff Howard
RJBrown Avatar
RJBrown Randy Brown
Same part# 7 months apart marked in different places. Now I have to look at my others.
benro Ben Rollo
Australia   AUS
The original thin bezel is a bit of a give away too. All the reproduction ignition switches and many period ones have a thick bezel (some a hexagonal one). I've been trying to track down a thin bezel for a while...
I'll give you $1000 for that bezel!
mgaex189 Avatar
mgaex189 Platinum Member Giovanni Delicio
1955 MG MGA 1500 "C2"
1955 MG MGA 1500
1955 MG MGA 1500 "C1"
Ben,
are you talking about AUS$ or US$ ??confused smiley
You guys must be crazy !!!
Regards
Giovanni
