coil for Pertronix
Posted by geezer
geezer Avatar
charles durning
Magee, MS, USA   usa
1958 MG Magnette ZB "Chick Magnette"
I just got a new Pertronix dizzy for my 1600 engine to replace the warn out Lucas dizzy. In reading the instructions there is mention of a specific coil to use with the new dizzy. I've installed many Pertronix products without experiencing any problems. I just don't remember reading this precaution. Since my coil could be very well 55 years old, replacing the coil might be a good idea. Since the Pertronix coil is not available locally and a Bosch coil is, what Bosch coil should I use?
57Coupe Avatar
Andy Bloom
Grand River, Ohio, USA   usa
1957 MG MGA 1500 Coupe "1957 Coupe"
You can get the Pertronix coil from Summit Racing.
michalakmj Avatar
Mark Michalak
Chicago, USA   usa
1958 MG Magnette ZB "Hilda"
1958 MG Magnette ZB "Mr. Belvidere"
1960 MG MGA 1600 Coupe
You just need a 3 ohm coil. They recommend you use a pertronix coil but I assume that's a marketing gimmick.
lmazoway Avatar
Larry Mazoway
York, Maine, USA   usa
1958 MG MGA
Hello,
I purchased the complete set from Advance Distributor last year. Rebuilt distributor, plug wires and coil. It was a Pertronix coil that failed after 2 months.
He replaced it with a Bosch:
the Bosch Box has a tag on it that reads:
First Line: 00012
Second Line: 9 220 081 083 - 74U
So far so good with the Bosch.
I carry a spare for safety.
Hope this helps.
Cheers.
Larry
geezer Avatar
charles durning
Magee, MS, USA   usa
Thanks for the input. After some convincing, and hearing "they're all the same", I was able to find the Bosch coil.
BTW I have heard stories about the Pertronix coil being short lived but I don't know of anyone who had any problems with the coil.
Gone, /, Kiribati   kir
To echo, the Bosch coil will work perfectly! A Bosch blue coil works best, an aluminum casing works equally as good.
The Bosch coils need a resistance wire in place of a ballast resistor to work their best. Any un-ballasted 40,000 volt coil works perfectly with the Pertronix module. We've had them in multiple cars, even the 356 Porsche, without a problem and will be using one in a stock '67 289 Ford distributor for the 5.0 engine transplant for the Coupe.
Keeping the original points set-up/rotor/condensor in a plastic bag in the trunk wouldn't be a terrible idea though. The modules are more apt to fail than the coil.
Luck,
T
Edited 1 time(s). Last edit at 08/01/2012 12:53PM by TeamEvil.
