Engine runs rough
Posted by Suelzle
Suelzle Avatar
Bruce Suelzle
Raymond, Alberta, Canada   can
1958 MG MGA
When starting the car after sitting for a few minutes after a long run, it stumbles and backfires for a few minutes and then runs just fine again. The car was not overheating and all seemed well. I've checked the float bowls and they are full.
Any Ideas?
-Bruce
Bob Agar Avatar
Robert Agar
Green Valley, AZ, USA   usa
1953 MG TD "Myrtle Anne"
1957 MG MGA 1500 Coupe "Miss Scarlett" ~ For Sale ! ~
1974 MG MGB "The Mistress"
Sounds like that old gremlin, vapor lock. Low boiling point of modern fuels contributes. Gas is likely boiling in the carbs or fuel line. I use about half choke to clear this until the engine smoothes out....or just let it work itself out as you describe.
1974.5 MBG Tourer with Weber 32/36 mod and AC.
1957 MGA 1500 Coupe - Stock and original except paint
1953 MG TD - Original car with no mods
neely Avatar
Gary Neely
Heber Springs, Arkansas, USA   usa
Do you have the 4' duct on the drivers side installed in front on the slam panel, and a short piece of 4" behind the panel directed towards the carbs. This may help a little.
Suelzle Avatar
Bruce Suelzle
1958 MG MGA
I do have the duct in front of the panel but not behind, I believe a have a short piece left, I'll try adding it to the back side.
peter d Avatar
peter h
yorkshire, United Kingdom   gbr
1958 MG MGA Coupe
1977 MG MGB "Abomination"
Hi Bruce
Dont know if this is related,Just looked at the picture of your engine and noticed that the fan blade is on the wrong way (i think)Is it still on that way? Someone may confirm this.Could this cause high temps in the engine bay.
Suelzle Avatar
Bruce Suelzle
1958 MG MGA
Hi Peter, Yes that's an old picture, I've since corrected the fan. The engine is running around 190 F when shut off and I do have a good carb shield (non original).
Gary E Avatar
Gary Edwards
Kernersville, ,N.C., USA   usa
All the MGs I ever owned have done that. After sitting a short while the engine will heat up due to no water circulation. When it gets hot enough it will cause vapor lock as Bob mentioned. The best solution if it bothers you that much is to installed a thermostatically controlled electric fan that will continue to run until the engine cools down. The water will circulate some through convection.
Suelzle Avatar
Bruce Suelzle
1958 MG MGA
Thanks Guys,
Not a big worry for me, but I thought there may be a simple solution
-Bruce
barneymg Avatar
Barney Gaylord
Naperville, Illinois, USA   usa
There is a simple solution. Open the bonnet and let it vent for 10 minutes after shut down. Maybe not convenient or practical, but real simple, and it works. I used to do that regularly when autocrossing in hot weather.
Barney Gaylord
1958 MGA with an attitude - http://MGAguru.com
Notice: - Do not leave a PM for me on the forum server. Send any private message to my personal e-mail address barneymg@mgaguru.com
Suelzle Avatar
Bruce Suelzle
1958 MG MGA
Your right Barney,
As it turns out we just got finished a parade, where of course the car overheated. I parked it with the bonnet up for few minutes, it started and ran just fine.
TX, USA   usa
Just H2O and Water Wetter. Not everyone agrees but works for me...plus a shroud and baffle above the radiator. I'm down 15 degrees and it is plenty hot here 95+ everyday.
