body sub-structure showing through: A survey of your bodies please?
Posted by hunts
hunts Avatar
H. Landon Hunter
central PA '75 RB to CB, HS-4's., USA   usa
1974 MG MGB GT
1975 MG MGB
Hey folks.
The area of the A's body that I think is called the rear tonneau...the outer surface cowling that is above and just behind the seatbacks...has two of the corrugated struts/braces running under it...the same braces where folks retrofit the third points for the seatbelt?
To use a term often heard when speaking about flooring, where one vinyl flooring sheet is installed improperly on top of an existing other...
Are any of your unmolested bodies showing those braces telegraphing through to the outer skin of your rear cowl/tonneaus?
Mine are and I know it will be worse when she gets shiney new paint someday. So this is either an expectant vintage characteristic, or somehow I may have nipped, tucked or pulled too hard somehow.
So I either build up the area like I am doing drywall joints, or perhaps yank downwards on the struts to relieve(?)some pressure maybe, or this is normal.
The area I am speaking of is (see photo)
Landon
Edited 1 time(s). Last edit at 04/18/2012 09:45AM by hunts.
telegraphing areas.jpg (32.3 KB) –
Neil MG Avatar
Neil McGurk
Cumbria, United Kingdom   gbr
1956 Morris Minor
1958 MG MGA
1960 MG MGA
1961 MG MGA
1966 Jaguar Mark 2   → more
What wonderful patina! I have not seen anything like that on any of my cars. I would suspect that there has been a very heavy load (someone standing?) on that area at some point. The braces have then marked the sheet steel with the lines still visible after the surface sprang back?
ghnl Avatar
Eric Russell
North Carolina, USA   usa
Has the body ever been sandblasted? Done improperly it will warp sheet metal. And if/when the underside is sandblasted the metal around the braces will be affected but the metal behind the braces will not and it will result in the effect you describe.
Or someone sat on the tonneau panel.
Eric Russell ~ Mebane, NC
1960 MGA, 1981 Alfa Romeo GTV6, 1984 Alfa Romeo Spider, 1991 Honda ST1100
dfriswell Avatar
David Friswell
BOCA RATON, FLORIDA, USA   usa
1960 MG MGA 1600 "The G"
Maybe something like this happened along the way...
HL Miller Avatar
Henry Miller
Chair City, NC, USA   usa
The '57 Eric & Mike & I did was like that. I just treated it like a dent and straightened it out. The front also had some telegraphing ( good term, btw) as well. The '60 parts car that is now a project car is the same way.
hunts Avatar
H. Landon Hunter
1974 MG MGB GT
1975 MG MGB
In reply to # 2043497 by ghnl Has the body ever been sandblasted? Done improperly it will warp sheet metal. And if/when the underside is sandblasted the metal around the braces will be affected but the metal behind the braces will not and it will result in the effect you describe.
No sandblasting that I can verify, I am the second owner. Good thought though. Which makes me think I should be describing this as oil-canning.
Landon
jclars Avatar
John Larsen
Lynden, WA, USA   usa
Monkeys on your back will do that.
dfriswell Avatar
David Friswell
R.I.P. Davy Jones...
Gone, /, Kiribati   kir
I had three trunk lids with the same symptoms, but I haven't looked closely at the rear clip yet. I had a post about it and nobody would believe that the lines were even there for the most part. Nice (I mean BAD ! !) to see someone showing up with something similar and pics to go along with.
Don't know what causes it, but I THINK that it might be the packing, felt, or sound deadening hardening up over the years. Becoming impregnated with metal and rust from inside and that material becoming wet and possibly enlarging in size. Body movement and stress, now against a solid surface, would cause that kind of impression to form.
Not sure, but with the trunks, I gouged the hardened sound deadening out from between the trunk lids and inner bracing and managed to coax the outer surface back into shape, skimmed with fiberglass, then added new deadening material. Of course alumiunum is much easier than steel. You'll need a metal shrinking wheel on a drill or right angle grinder to accomplish this on your rear clip, but it can be done.
Luck,
TC
Orting, Wa, USA   usa
My boot lid had the same too. Not bad, but when blocking them, there were a couple of high spots and that is when I noticed they were right on top of the support ribs.
I haven't stripped the back tub yet so it will be interesting to see how that comes out.
