Aluminium Cleaning
Posted by peter d
peter d Avatar
peter h
yorkshire, United Kingdom   gbr
1958 MG MGA Coupe
1977 MG MGB "Abomination"
Im just experimenting with electrolysis cleaning of small parts.Have try ed Soda ash an now trying Caustic soda.Work in progress.
Just a question can i put Aluminium parts in either of these solutions? Or will it attack the Aluminium ending up in an ingot at the bottom of the bucket!
Are there any other ways of passive cleaning (No grinders/wire etc)aluminium?
JimNH Avatar
Jim Mail
Nashua, New Hampshire, USA   usa
"Light" metals such as aluminum, zinc, white metal or other alloys break down much quicker than steel, cast iron or brass. I think it's because at the molecular level, there is a weaker bond, but I am not a chemist. A smooth aluminum surface that has light surface corrosion can still be cleaned with electrolysis, but only immerse the material for short periods (15 minutes) and clean with a soft brush. Longer periods will discolour, badly pit or even completely dissolve aluminum etc.
Above from this website;
http://users.eastlink.ca/~pspencer/nsaeta/electrolysis.html
JIM in NH
John Terschak
Kill Devil Hills, NC, USA   usa
1930 Ford Model A "Jenny"
1959 MG 14/28 "Jessie"
1974 MG MGB "Oooops"
Peter,
What aluminum parts are you trying to clean. If it's the SU's don't. Some chemicals will stain the metal and you'll never get them to shin again. If you like I can PM you my son's email address for more info on the chemicals. He holds a PhD and teaches Chem at I.I.T. In Chicago.
If your working on your SU's and need the pots brighten I can tell step by step on how to bring them up to looking new.
John
peter d Avatar
peter h
1958 MG MGA Coupe
Jim i read your post on plating with great interest.I plan to have a go myself.In the thread on door skins a link was posted about Electrolysis to remove the rust on the frames. after messing about with the setup i find i need a better Anode i think (pure Zinc but may try Stainless steel) please correct me if im wrong.
The reason i ask if Aluminium can be cleaned this way and to answer Johns question, I was wondering if i could clean the skins up this way. Would a Zinc anode work on Aluminium?
John any info on the chemicals or the best anodes to use would be much appreciated
Thanks for the link as it answers many of the questions.I suppose its down to trial and error.Plus im having fun playing the mad scientist.
The mad bit comes easy the science a little bit harder
Thanks
Edited 1 time(s). Last edit at 03/24/2012 12:05PM by peter d.
2mgs4doors Avatar
Harry Rathvon
Akron,Penna, USA   usa
I use a 4 1/2 " angle grinder with round scotch brite type conditioning pads on a velcro pad for final buffing on Alum
hunts Avatar
H. Landon Hunter
central PA '75 RB to CB, HS-4's., USA   usa
1974 MG MGB GT
1975 MG MGB
1. It was my understanding that the SU's are not aluminum at all.
2. Easy off oven cleaner does a great job of cleaning aluminum. It was the main too I used to get the anodizing off of my MG B window screen frame prior to polishing.
Landon
Gary E Avatar
Gary Edwards
Kernersville, ,N.C., USA   usa
Carbs and other small alum parts may be cleaned with a glass bead blaster. Then use the little wire brushes on a Dremel tool to brighten the crevices and a buffing wheel for the open areas. Those little wire brushes also do a good jobs of cleaning small areas of chrome. They are too soft to scratch if you are careful.
John Terschak
Mr. Hunter
The SU's are indeed aluminum. Oven cleaner is made from lye and I would not use any on the pots of the SU's. I too have used oven cleaner to clean aluminum. But this was on the transmission casings to clean all that grease and grim off. I also use it to clean out old gas tanks but prefer Draino Which is a drain cleaner made up of lye also.
Gary has the right way of cleaning up the bodies. He'll also see pictures of the last set of SU's sold.
Peter I'll PM you my boy's email address and I'll let him know your going to contact him. You can thank me by buying me a plowman's and a pint of Murphy's.
John
Ex Buckeye
peter d Avatar
peter h
1958 MG MGA Coupe
John can you ask him if Lead would be a good Anode.
If i ever come over there it would be my pleasure to purchase said ploughman's and copious amounts of Murphy's.smileys with beer
John just seen your email.Will contact him.
Thanks
Edited 1 time(s). Last edit at 03/24/2012 03:17PM by peter d.
hunts Avatar
H. Landon Hunter
1974 MG MGB GT
1975 MG MGB
In reply to # 2021179 by 59mgaguy Mr. Hunter
John
Ex Buckeye
Ploughman's.
smiling smiley
paddyreardon Avatar
Paddy Reardon
Calne, Wiltshire., United Kingdom   gbr
I find the dishwasher is perfect for cleaning aluminium parts.
it even did a fair job on a cylinder head.
While the wife is out!!
Edited 1 time(s). Last edit at 03/24/2012 03:24PM by paddyreardon.
neely Avatar
Gary Neely
Heber Springs, Arkansas, USA   usa
It seems like I am constantly cleaning aluminum bits. I am down to pretty much using scotch brite pads and Brasso. I always do it by hand.
Basil Adams Avatar
About 12 miles from Sears Point, USA   usa
Never use sodium hydroxide on aluminum. I was a chemist before I figured out there was no money in it and I recall one night back in school using aluminum foil and sodium hydroxide to generate hydrogen gas which we pumped into a balloon. We then tied a tail of magnesium ribbon (about 30 feet) to the balloon and let it float up. Before releasing the last inch of the magnesium ribbon, I lit it on fire and let go. The balloon drifted up and the magnesium ribbon burned brightly. Then the flare touched the balloon and there was a beautiful explosion and nothing was left. Quite spectacular. Anyway, here's a video of aluminum and sodium hydroxide:
Basil C. Adams
1956 MGA Coupe (Show Car)
1957 MGA Roadster (Driver)
1958 MGA Coupe (Racecar)
1959 MGA Coupe (unrestored)
1960 MGA Coupe (unrestored)
1960 MGA Roadster (Driver)
MKIII Elva Courier (E1056)
1967 427 Cobra
1972 Alfa Romeo Montreal
A coupla late MGBs
1960 Austin Healy BN7
More Cars than Brains
John Terschak
Mr. Hunter
You really know how to hurt a man. I miss the cheese, bread and pickle.
Peter,
I hope you email Andrew for further info. As for buying, Wife and I might be in Reading next year for a wedding.
John
bills Avatar
Bill Spohn
Be very careful with dashpots. The interior clearance between the dashpot and piston is critical to proper operation - so much so that you are well advised top keep track of which is which when removing them, as swapping can result in too fast or too slow drop. I'd never clean them except externally and mechanically.
Basil - sounds like we were of similar mind. I got in trouble in the lab for making nitrogen triiodide, dissolving it in alcohol and painting it on doorknobs and toilet seats (it is a contact explosive that goes off with a bang - well, more of a loud snap - and leaves a purple stain on whatever set it off).
West Vancouver BC
HL Miller Avatar
Henry Miller
Chair City, NC, USA   usa
In reply to # 2021679 by Basil Adams Never use sodium hydroxide on aluminum. I was a chemist before I figured out there was no money in it and I recall one night back in school using aluminum foil and sodium hydroxide to generate hydrogen gas which we pumped into a balloon. We then tied a tail of magnesium ribbon (about 30 feet) to the balloon and let it float up. Before releasing the last inch of the magnesium ribbon, I lit it on fire and let go. The balloon drifted up and the magnesium ribbon burned brightly. Then the flare touched the balloon and there was a beautiful explosion and nothing was left. Quite spectacular. Anyway, here's a video of aluminum and sodium hydroxide:
Cool video- thanks. I found out about the danger of sodium hydroxide and aluminum when my teenage nephew was visiting and making drano bombs -. He kept increasing the amounts, narrowing his window of opportunity to get away. The lady at poison control was so professional, stayed on the line for half an hour, kudos to her... Thankfully, no lasting damage after the long lukewarm shower to rinse off the splatter- memorable day. I didn't get uncle of the year for sure, but mom took it very well.
