MG-2013 is only 51 days away! · Corvallis, OR · July 17–21, 2013 · Visit MG-2013.com or the MG-2013 Forum for more info
A couple of body work questions.
Posted by TeamEvil
Gone, /, Kiribati   kir
Just started working on the front clip, TONS of surface rust, a bit of rot, and a damaged/dented nose. The top surface of the cowl and most of the mid-side areas have very large, very deep pits in the sheet metal, I was wondering what some of you folks recommend to filled them? The technique and materials used?
Also, towards the middle of the of the clip the metal seems to be thin. Thin enough that I can push on it and it "pops" in and out again, almost 'oil canning" in a way. Is this normal on the MGA or has the metal possibly been rusted away to a thinner gauge?
Wondering. Could use some help.
Thanks,
TC
HL Miller Avatar
Henry Miller
Chair City, NC, USA   usa
For the pits, a couple of options pop to mind - a filler with aluminium, like allmetal or alumifill has good moisture resistance, easy to spread, works well. A polyester putty spreads and sands easily. For smaller pits over a larger area, a sprayable polyester like slicksand can do a decent job.
jclars Avatar
John Larsen
Lynden, WA, USA   usa
I also had a lot of surface rust on mine, although pits were to a much smaller degree. I used a rust converter like RustMort, following instructions and then polyester putty.
Orting, Wa, USA   usa
In reply to # 2021552 by jclars I also had a lot of surface rust on mine, although pits were to a much smaller degree. I used a rust converter like RustMort, following instructions and then polyester putty.
I am working on my panels and that is what I am doing. My pits are at the edges of the wings where they bolt onto the tub. I am using Mar Hyde rust converter (I tried Loctite but I like Mar Hyde better) and I like the the Dolphin brand filler too.
Jonathan-AZ Avatar
Jonathan Baney
Mesa, Arizona, USA   usa
I blasted the entire body and filled most pits with a skim coat of rage gold filler. Once I'm done with the major dings that I couldn't hammer out, I'm going to hit the exterior pieces with Evercoat's SuperBuild, a sprayable poly filler/primer/surfacer. It's supposed to be like slicksand but easier to sand. The brochure says it should build up to 8 mils per coat and you're supposed to hit it with 3 wet coats, then block, so those pits and any waviness should disappear.
*Note, I use all of the right buzzwords in the above message but I have never used an air gun before, so we'll see what happens. smiling bouncing smiley I do love the rage gold though, sands so well and is very forgiving to make up for my lack of skillz.
Thanks gang, I'll do as most of you have. Sounds easy, and ought to work out. The pits sort of scared me, somehow I thought that I was gong to have to melt lead or aluminum into them, maybe use a waxed paddle or something. Nice to learn that modern materials will do the job well.
TC
jclars Avatar
John Larsen
Lynden, WA, USA   usa
Wow Jon, I was impressed. You must have been studying the topic during your down time! You made me recall that I used the filled polyester primer as well. So,I second that approach for the pits and rough surfaces.
I did two coats x2 and it smoothed the surface nicely after blocking. When they say wet coat, though, they mean wet coat. But dont be shocked if the first try comes out like lizard skin. It sands down pretty easily. (Leslie can probably finish it easy on a weekend.) Also be aware that some of the high build polyesters arent meant for direct application to bare metal and so you would need to spray epoxy or other compatable primer first.
John L.
