brake bleeding problems.
Posted by cpjim
jim patterson
indiana, USA   usa
i replaced the wheel cylinders, front and rear, and brake shoes on my 1500 because of a couple of leaky wheel cylinders. i can't seem to get the pedal to feel right. it goes all the way to the floor and takes 10 or 12 pumps to feel right. when i bleed the brakes it appears all the bubles are gone but it seems like there is not enough flow coming out of the bleeders. i do get more flow from the front. the brakes seemed to work ok before i started and the master cylinder is not leaking. i built a pressure bleeder from mg guru plans and that does get more volume through the lines, but no real help. all the brake shoes are adj all the way in for maximum stroke. does anyone have any ideas? thanks in advance--jim
revans Avatar
Richard Evans
Hampshire, United Kingdom   gbr
Not sure on this Jim, but I thought that the brake adjusters should be all the way out for max stroke.
Richard
revans Avatar
Richard Evans
I may have confussed you with my statement.
What I meant to say is that when I bleed my brakes I position all the adjusters all the way out.
Richard
Chuck Schaefer
West Chicago,IL, USA   usa
Do you turn the brake adjusters to 1 click off lock to test the pedal? It is a must.
Edited 1 time(s). Last edit at 02/12/2012 04:08PM by cschaefer.
jim patterson
indiana, USA   usa
the brake adjusters are all the way out. that is, the brake shoes are as far from the drums as possible.
ron neal Avatar
South Carolina, USA   usa
1962 MG MGA MkII
1968 MG MGC
1969 MG MGC
1969 MG MGC
1969 MG MGC GT   → more
Adjust your brakes as Chuck said then try it again.
Ron
jim patterson
indiana, USA   usa
so i guess you're saying adjust all 4 till they are tight against the drums, back off 1 notch, work the pedal a few times and then bleed again in that posistion or rebleed with the adjusters all the way away from the drums?
Wray Avatar
Wray Lemke
., South Carolina, USA   usa
In reply to # 1983273 by cpjim so i guess you're saying adjust all 4 till they are tight against the drums, back off 1 notch, work the pedal a few times and then bleed again in that posistion
You need to do it like that. You'll never get firm pedal any other way.
jim patterson
indiana, USA   usa
thanks for all your help. i'll try it that way this week end and re-post.---jim
RJBrown Avatar
Randy Brown
Highlands Ranch, Colorado, USA   usa
When adjusting brakes you turn the adjusters as tight as you can then back off one notch. Then you hit the brakes to re center the shoes and adjusters. Then you tighten as tight as possible and back off one click again. Doing this twice guarantees that shoes are centered on the adjusters and in the drum. Often the second time makes no difference but do it to be sure. if you turn the adjuster all the way and the brakes don't hold the drum tight you have a problem. Address this issue first. Brakes should be pruporly adjusted before you bleed them.
Chuck Schaefer
If you've already got the bleeding of air taken care of, just adjust the brakes to the operating position and test your brakes. No need to bleed again unless you still feel soft brakes. Pumping the brakes to get a braking action is normal for adjusters set too loose.
Regarding Randy's post. I doesn't hurt to rock the car (or wheel if you've got it up in the air) back and forth after hitting the brakes. This helps a bit to center the shoes too. cdentering the brakes is very importatnt after you've done a complete cylinder/shoe replacement. Not so much for routine adjustments.
RJBrown Avatar
Randy Brown
In reply to # 1983386 by RJBrown When adjusting brakes you turn the adjusters as tight as you can then back off one notch. Then you hit the brakes to re center the shoes and adjusters. Then you tighten as tight as possible and back off one click again. Doing this twice guarantees that shoes are centered on the adjusters and in the drum. Often the second time makes no difference but do it to be sure. if you turn the adjuster all the way and the brakes don't hold the drum tight you have a problem. Address this issue first. Brakes should be properly adjusted before you bleed them.
jim patterson
indiana, USA   usa
thanks again for the responses, i'll give it a try this weekend and re-post---jim
jim patterson
indiana, USA   usa
it took me a while to get back to the A. after adjusting all 4 brake shoes properly, the pedal pressure came back right away. i bled them 1 more time and everything appears to be ok.thanks for all your help----jim
jclars Avatar
John Larsen
Lynden, WA, USA   usa
This post solved the same problem for me with my 1500 coupe. I had brakes, but it always took a second pump to feel solid. This post made me recall that I had somehow skipped past the adjusters after bleeding. I resolved to give it a try before taking it out this season. I took a test run today after adjusting and was pleased that I wont have to look any further for the problem.
Thanks for the post!
John L.
