6-speed tranny for MGB's
Starbuck Monte johnjulio
Greensboro, North Carolina, USA   USA
1967 MG MGB GT "Toaster"
1974 MG MGB "The B"
1979 Triumph 1500 ~ For Sale ! ~
1979 Triumph Spitfire 1500 "Shitfire"
I was just wondering if there were any 6-speed conversions kits available for MG's or at least which 6-speeds would be the right size to fit in a B?
I am considering doing the Rivergate 5-speed but I wanted to know if anybody here has ever attempted to put a 6-speed in a B.
Not too kosher for an MG I know, but when mine gets to be a daily driver again at least 80% of the miles travelled will be on 70-mph highways and I think that a 6-speed would make that a lot easier.
"...They say that a man with two restoration projects is a poor man...I now have three...WTF was I thinking!?!?!?!?!?!?!"
1967 MGB-GT,1979 MGB roadster, 1979 Triumph Spitfire 1500 1974 MGB Roadster (retired, giving its life to be a parts car)
My 1974 MGB restoration at: http://mgbproject.blogspot.com/
My 1979 Spitfire restoration at: http://spitfire1500project.blogspot.com/
My 1967 MGB-GT restoration at: http://mgbgtproject.blogspot.com/
NOHOME P P
O, Ontario, Canada   CAN
Sizewise, Miata or S2000 would be the obvious choices.Your chance to blaze a new path?
I think the horrible gear ratios on the MGB are something that we can all agree on. The car never does feel real happy in any situation unless it is overdrive at 65 mph.
Pete
sshack Avatar
sshack Steve Shack
Victoria, Canada   CAN
With a 4speed overdrive gearbox, 90mph is 3157rpm. How fast
do you need to go? Does your commute involve a Le Mans race?
Derek up North Avatar
Derek up North Derek Nicholson
Sherbrooke, Quebec, Canada   CAN
1961 MG MGA
A friend of mine who owns one of the Montreal LBC garages has mated a Honda S2000 6-speed to a 'B engine. He's waiting for a gap in his work schedule to fit it to his 'B.
I don't really see the benefit to it. Unless highly modified, to me, the 'B engine is all about torque. It's not a high revving Japanese revver that has a narrow power band. 80% 70mph highway? I'd put in an O/D and be done with it.
Edited 1 time(s). Last edit at 2008-11-19 06:19 AM by Derek up North.
Gerald O Avatar
Gerald O Gerald O'Docharty
1978 MG MGB
sshack Wrote:
That would be about 70mph (indicated) at that RPM on mine ('78). Still plenty low enough.
1961 MG MGA
Steve's allowed to make a mistake. He posted at about 4 am local time!
B-racer Avatar
B-racer Jeff Schlemmer
Shakopee, Minnesota, USA   USA
2014 Dodge Charger
Glen Towery who hits this forum onoccasion used to have a V8 conversion with a 6 speed, if I'm not mistaken. Either that or he was working on assembling one. Hopefully he'll chime in on this. I thought it was some form of Rover derivative he used, along with a 4.6L engine.
jeff@advanceddistributors.com
JoeReed Avatar
JoeReed Gold Member Joe Reed
Cordova, Tennessee, USA   USA
1978 MG MGB "Kermit"
Many MGs already have a 6-speed trans....it was a factory option grinning smiley
PAMidget Avatar
PAMidget Thomas Reimel
Philadelphia, USA   USA
Yeah, but more gears is not necessarily just about speed, but the ability to keep the ratios closer, while climbing to a low (numerically high ratio)--the less torque available, the more closely spaced gears you want--think 10- or 15-, or 18-speed bike.
Baxter Tim Baxter
Kansas City, USA   USA
But here's the real question: what six-speed? The most obvious choice would be the Miata six, but that would be a big step backwards. The miata six speed doesn't feel or shift nearly as nice as a B box, and it's actually geared lower than the 5-speed. I believe the S2000 box is similar.
Six speeds are mostly only good for bragging rights. I wish, in retrospect, that I'd bought a miata with a 5-speed instead of a six.
NOHOME P P
Joe beat me to the correct answer. Note that all the nay-sayers advocate an overdrive transmission as the solution, in fact, a six speed transmission. Also, lets be honest, how many use the six speeds available wwith the overdrive? I found that the same applied to the sis speeds I have driven (M3 and S2000) I was more annoyed than entertained by the extra gear and the need to keep factoring it in to the equation. 1-2-3-4-6 was the new math!
Finding an MGB overdrive tranny is not a trivial matter in NA. Once you find it, it should be overhauled. If it is a three sync, it is still a weak(er) tranny that makes a horrible sounds in first. Charming and "period correct if you enjoy the sound. If it is a later unit, you are now two grand into the show and running a finiky old OD unit that baffles most people. It is not really complicated, just unknown by mechanics.
Myself, I think the Datsun swap is the laymans solution to easy cruising. Moneywise, Rivergate has priced it as equivalent to an OD conversion. For some odd reason, I THINK the gears are a better fit to the MGB powerband than the original factory choices. I have not driven the conversion so I can not speak to this as fact.
Interesting fact is that the Miata 5 speed tranny has more overdrive (o.81)than the 6 speed (0.84). The Miata used the two overdrives to get away with a taller rear gear, hence it works out. The Honda comes in at 0.81, same as the Miata 5 speed. I know the Datsun has two overdrive ratios available, and I am pretty sure that one of then is in the 0.73 range (I am getting old, memory not that great!) this would put it ahead in the relaxed highway cruiser contest if keeping the stock rear end.
I find that the MGB is happiest just under 4,000 while cruising along the highway. In Ontario, I need to be moving at 75-80 to keep up with traffic. That would put me into the Datsun tranny if I were looking for a new tranny.
Pete
purpleGT Avatar
purpleGT Gold Member Bud Osbourne
Pittsburgh, PA., USA   USA
Starbuck Wrote:
Quote: I was just wondering if there were any 6-speed conversions kits available for MG's or at least which 6-speeds would be the right size to fit in a B?
To me, the simplist, most cost-effective solution would be to just put an MGB overdrive transmission in it. It's pretty much a bolt-in installation. While they are not nearly as common as the non-O/D boxes, they are still not too difficult to find, and parts are still readily available for them.
The one I have in my GT I got for $300....in 1979winking smiley......with 52,000 miles on it. I just plugged it into my GT and put another 50,000 plus miles on it. When I took the car off the road, to restore, it was still working beautifully and had never given me any trouble whatsoever.
You should still be able to find a good O/D box for $800-$1200. I see them every year at Import Carlisle, for example. That's a whole lot cheaper than any other alternative, I beleive.
Bud Osbourne
bobmunch Avatar
bobmunch RK Muenchausen
PC, Oregon, USA   USA
Ditto Peter and Bud, but with the recognition that a 5-speed tranny like the Rivergate, et al, does not involve some of the problems of the electric O/D the MG tranny has tacked onto it, things such as clutches, solenoids, etc.
The MG tranny is still a pretty sturdy unit in my experience and if one takes care to do the routine maintenance, the 'problems' I mention are not a huge factor.
MGB GT cutaway car photos site by Paul Hunt can be found here >>> http://www.mgb-stuff.org.uk/cutaway/cutaway.htm
Ryan Reis Avatar
Beatrice, NE, USA   USA
1968 MG MGB
I'm all for the idea on the "gee whiz cool" basis, but in reality its not going to make driving your car any better. Like Derek said, the 'b has a wide torque range that doesn't really need close ratios to keep it "on the powerband". My OD keeps up with freeway traffic just fine. If you fit a transmission with a deeper overdrive ratio you might not use it much.
Ryan
Citron Steve DeGroat
SC, USA   USA
I have a 5 speed in my BGT. I really do like it, but still feel the engine could pull a taller gear. I live the flat lands of SC.
I had an overdrive in a 78 B one time that hung in overdrive. I could start off just fine in overdrive first.
Now, Could I just go to a Ford 8 in. with a 3.55 gear and get along fine?
Just wanted to know if that is a option for B's. Maybe even do that instead of an overdrive trans.
Steve
