Lead Additive! Who uses it?
cfowler Avatar
cfowler Craig Fowler
CBS, 74 Bracken MGB Roadster 28k miles, Newfoundland, Canada   CAN
1974 MG MGB "Bracken B"
I have been adding lead to my fuel fearing the car might have problems without it.
How many of you use lead additive in your fuel?
Is there a particular year/engine that no longer requires the additive?
My car is a 74 but the motor is from a 72.
Engine code: 18V-584-Z-L/10959
Craig Fowler
74 Bracken MGB
Email: Craig.fowler@nf.sympatico.ca
Web: http://www.cardomain.com/ride/662911
Jack Long Avatar
Forest Hill, Maryland, USA   USA
1955 MG TF 1500 "Harriet"
1974 MG MGB "Lucy"
My 74 has a very early head (no smog ports) so I use it religiously. Its pretty cheap and a bottle lasts me 2 years.
rbobrowski Avatar
rbobrowski Bob Bobrowski
Livonia, Michigan, USA   USA
There has been a lot of discussion on this whether or not we need to use lead additive or not. I figure if it was designed for leaded gas, why not use it. It's cheaper to put it in now, then to find out later you should have.
Naomi Avatar
Naomi Naomi C
Between Greensboro and Roanoke, USA   USA
1964 MG MGB "Kirby"
1979 MG MGB "Bandit"
1980 MG MGB "Robbie"
1995 Mazda Miata Special Edition    & more
I've never used it but now that you've brought it up should I on my 64? Interesting smiling smiley
"1964 MGB" (Kirby) All original pull handle MGB, 3 main, with overdrive, but a daily driver with all the dents and dings to prove it -- Titled in 1965~~
"1980 MGB" (Robbie) Even though it's a RB it does have overdrive, a Weber Carb, and is my favorite MGB. We have logged thousands of happy miles together ~~
Rod H. Avatar
Amity, Oregon, USA   USA
1964 MG MGB
1968 MG MGB GT
Are you talking about actual lead, or lead substitute?
'63 MGB
'68 MGBGT
'80 VW Vanagon Kombi
Limey Avatar
Limey Eric Marshall
Pentwater, Michigan, USA   USA
Rod H. Wrote:
Quote: Are you talking about actual lead, or lead substitute?
I didn't think you coul buy actual lead! Isn't it all lead substitute?
I put it in the roadster before I had hardened seats put in the head. I have no idea if it had any effect or not, but it is (relatively) cheap insurance (or peace of mind)!
Eric Marshall
Bits4Brits
OldBloke Avatar
OldBloke Gold Member Jim Legg
Napa, California, USA   USA
1970 Rover 3500
1971 MG MGB GT
1972 MG MGB V6 Conversion
1973 MG MGB "Tagalong"
Never used it in either car. Rdstr motor last rebuilt in 93. GT never rebuilt pushing 80K.
"Not all who wander are lost." -J.R.R. Tolkien
ekafant Avatar
ekafant Emmanuel Kafant
Winston-Salem, N.C., USA   USA
I found a place, www.batterystuff.com that sells genuine tetraethyl lead. FWIW
Naomi Avatar
Naomi Naomi C
1964 MG MGB "Kirby"
I just asked the hubby why one would add lead to the gas and he said "lead is a lubricant". He ain't right is he ???
Steve S Avatar
It's all lead substitutes these days. I don't think real lead is legal to use in a motor car in any state but I could be mistaken.
If your engine has been rebuild in the past 25 years, it should have hardened valve seats and related non-lead hardware. If it's a high-mileage original engine then your seats are hardened by now anyway, and you shouldn't suffer any ill effects from running unleaded. This is theory and speculation of course, so you should investigate what is in your engine and make your own choice.
Limey Avatar
Limey Eric Marshall
Naomi Wrote:
Quote: I just asked the hubby why one would add lead to the gas and he said "lead is a lubricant". He ain't right is he ???
Partially! In an auto engine it works as a lubricant and a cushion. It formed a thin "coating" on the valve seats that "cushioned" the valve as it contacted the seat - it also lubricated that interface as well as (slightly) lubricating the valve stems! It also made the inside of your tailpipe a nice shade of light grey!
It also fouls sparkplugs and makes oil stink like cats pee! IMHO, we are better off without it!
Eric Marshall
Bits4Brits
cfrantz Avatar
cfrantz Gold Member Chris Frantz
Mississippi, USA   USA
1957 MG MGA
1964 MG MGB
I use a lead substitute in by B.
cfrantz Avatar
1957 MG MGA
1964 MG MGB
snoski Avatar
snoski James Blackledge
Lake Norman, NC, USA   USA
1970 MG MGB
I just put some old fishing weights in my gas tank........no, not really...
Limey Avatar
Limey Eric Marshall
snoski Wrote:
Quote: I just put some old fishing weights in my gas tank
So THAT's what the rattle is when you go round a corner... winking smiley
(It would probably keep the tank nice and clean though!)
Eric Marshall
Bits4Brits
