MGB alignment
mbb765 Mark Brown
Near Kansas City, Missouri, USA   USA
I have read some posts on this subject and I would like some input since I want to align my B with someone that knows what they are doing.
Toe-In is the only adjustment made on the later B's. I understand.
But buying that tool to align it yourself comparing the rear and forward rim distances= toe-in??..Should not a proper toe-in involve having the two wheels pointing to a common center point first? Truely you must make everything square and give it a reference to a common center before making any toe-in corrections. That tool is only a large vernier caliper and does not account for distortions along the logitudinal access.
What happens if both wheels are to the left or right and the toe-in is performed based on the distances? Spec. caster and camber must affect the angles and turning the wheels will cause unequal toe in from left to right. We are taking about 0.010" increments here...
There must be some alignment gurus out there that can explain?
Cheers.
Naomi Avatar
Naomi Naomi C
Between Greensboro and Roanoke, USA   USA
1964 MG MGB "Kirby"
1979 MG MGB "Bandit"
1980 MG MGB "Robbie"
1995 Mazda Miata Special Edition    & more
mbb765 Wrote:
Quote: I have read some posts on this subject and I would like some input since I want to align my B with someone that knows what they are doing.
Toe-In is the only adjustment made on the later B's. Cheers.
And I just paid $59.00 for an alignment on my 80 MGB today. Sure wish I had know there is not adjustment. Guess I got took huh? Sorry about jumping in your thread but I just had to get that out after reading what you wrote. I'm sure the experts will jump in with the answers you need smiling smiley
"1964 MGB" (Kirby) All original pull handle MGB, 3 main, with overdrive, but a daily driver with all the dents and dings to prove it -- Titled in 1965~~
"1980 MGB" (Robbie) Even though it's a RB it does have overdrive, a Weber Carb, and is my favorite MGB. We have logged thousands of happy miles together ~~
underdog Avatar
underdog Jim Underwood
Pittsburgh, USA   USA
1980 Triumph TR8 "Fabulous Trashwagon"
1999 Chevrolet Corvette "Darth Vader"
1999 Chevrolet S10 "Spare Change"    & more
Basically all that is done is center the rack, lock the steering wheel straight and set the toe equal amounts left to right. This is provideing the steering wheel hasn't been removed and put on off center. This can be checked easily by starting with the wheel straight and counting the turns left to right. Should be the same. The caster & camber don't effect the toe in. Hope this helps.
ingoldsb Avatar
Toe-in is always set with the wheels straight ahead. Of course, it is a valid question how to know when the wheels are exactly straight ahead. The tolerances are loose enough that as long as the wheel is in the position where the car drives straight it is close enough.
Bear in mind that toe-in is 1/4" to 3/16" (if memory serves me correctly).
Something I've always wondered about is whether the measurement should be from the wheels or the tires. The professional gauges (which you drive over as you mount the alignment rack) clearly measure the tires.
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
Kelly Engstrom Avatar
Stanwood, WA, USA   USA
1971 MG MGB GT "Bedouin"
1972 MG MGB GT
Toe-in setting is 1/16" to 1/8"
BruceH Avatar
BruceH Bruce H
Norwell, MA, USA   USA
I centered the steering, and then took two yardsticks, one on each wheel parallel to the ground pointing forwards, and at a height of the center of the wheel. I measured the distance between the yardsticks at the front of the wheels, and at then at the back of the wheels. I adjusted toe in until the front wheels measurement was 3/16" less than the measurement taken at the back of the wheels.
Not sure if this is correct procedure, but the wheels are now toe in.
underdog Avatar
Pittsburgh, USA   USA
ingoldsb Wrote:
Interesting question. I've done it both ways. When I was a teen, I used to work in a garage where we would chalk the center of the tire and use a tool to scribe a line all the way around. Then another tool (sort of a tram gauge) would be used to check the diff from front to back. Really primitive but it worked WAY back then. After trade school, I had a job in an auto center and did alignments on a Hunter machine. It had projectors that clamped to the rim and shot a beam onto screens. They still use the beams but the newer ones are computerised.
gjoakes Silver Member Greg Oakes
Cornfield, Illinois, USA   USA
1958 Morris Minor Traveller "Bridget"
1972 MG MGB "Buttermilk"
Here's the sequence that worked for me:
Step 1. Find the rack center (close to 3 turns lock-to-lock as I recall). Mark the steering shaft and the pinion housing so you know where the point is.
Step 2. Go for a drive and determine where the steering wheel is pointed when the car is going straight down the road. Somehow mark and remember this steering wheel position. Note that it may or may not be aligned correctly.
Step 3. When you return from the drive compare the noted position of the steering wheel (when going straight) with that of the rack center. If you are lucky they will correspond. If not then start adjusting the outer ball joints (rotate both in the same direction) to correct. As I recal one complete rev of the ball joint equals about 3-4" of steering wheel rotation. Go for another drive to check. When you have the steering rack centered with the direction the car wants to drive then you are done. And still, the steering wheel may not be aligned.
Step 4. Now adjust the toe-in to 1/6 - 1/8" using tool of choice.
Step 5. If necessary pull the steering wheel and rotate so that it is properly aligned.
SURFIT Avatar
SURFIT Gold Member Mike Schultz
Zionsville, IN, USA   USA
"What happens if both wheels are to the left or right and the toe-in is performed based on the distances? Spec. caster and camber must affect the angles and turning the wheels will cause unequal toe in from left to right. We are taking about 0.010" increments here..."
Then, your steering wheel will be off - - not centered - - that's it.
Make sure, when you adjust toe-in / toe-out, that you adjust both left &
right tie rod ends equally.
Mike
'73 MGB
Wiley1 Avatar
Wiley1 Alan Carpenter
Seattle, USA   USA
I have a stick (1x2). I installed 4 screws with washers under the heads of the screws. 2 screws about 6 inches apart at each end. I took a coat hanger cut it in half and straightened the pieces.. Then I bent the hanger pieces in an L shape. Attach the coat hanger pieces to the 1 x 2 wood by inserting the hanger pieces under the washers under the screw heads. The idea is to have a long piece of wood with "pointers" (coat hanger ends) at each end. The put a piece of masking tape across the tread of each tire. Make a mark on the tape approximately at the center of the tread/tape. Place the stick under the car running side to side. Set the pointer ends so that they are directly in line with the marks on the tape - bend the "pointers" to get them to point at the right spot on the tape. Carefully slide the stick out from under the car without moving the "pointers". Roll the car forward so that the tape on the tires is now at the front. Place the pointers/stick across the front and the adjust the tie rod bars in or out to get the marks on the tape equally the same amount of toe in about 1/16 to 1/8 less than the measurement that was taken at the rear , first time around. REcheck. All done.
mbb765 Mark Brown
Thanks for the input.
All this tells me the car could still be "aligned" with the steering rack centered and toe correct...even though the front end components could be off. I will feel better with the whole system aligned...to compensate for the inconsitancies of the front end components even though I am tempted to do it myself and beat those potential money taker aligmnet shops.
Anyone know of a good alignment centre Houton? I got a quote of over $120 from a MG specialist. I said to myself "you have got to be kidding!!"
Thanks!
Edited 2 time(s). Last edit at 2008-01-10 06:59 PM by mbb765.
bk Avatar
bk Bill Kiger
Thomasville, NC, USA   USA
1974 MG MGB GT    & more
Mark before you go spend any money check out this thread
http://www.mgexperience.net/phorum/read.php?1,469804,469818#msg-469818
Bill
ingoldsb Avatar
Quote: Toe-in setting is 1/16" to 1/8"
Well, so much for my memory smiling smiley I guess the 1/4" is the piston to cylinder wall clearance.
Quote: After trade school, I had a job in an auto center and did alignments on a Hunter machine. It had projectors that clamped to the rim and shot a beam onto screens.
That seems to settle it - the toe-in is supposed to be measured from the rims, not the tires.
Terry Ingoldsby
PurplePeopleEater Alex Redding
Fredneck Md, USA   USA
A driveover alignment checker reads the tires & give you a 'PASS' or 'FAIL'. If it fails it needs to go on an alignment machine to be checked & adjusted properly.
Setting the toe by itself was acceptable technology in the 50s & 60s but is obsolete now. Think about it, if you just set the front you're assuming that the rear is square to the front. That can be a bit of a leap in a 30 year old car. You could have the toe set perfectly but if you're not tracking properly the steering wheel can be off center, the car could be pulling, & the tires wearing unevenly. For those reasons you want a 'Thrust' alignment that looks at the relationship between all 4 wheels. It's also not a bad idea to have someone who knows what they're looking at inspect the little darling for worn bushings & suspension parts. Before the horror stories begin, I'm not telling you to have it done @ a major retailer. Take it to a specialist who's familiar with our old cars.
Disclaimer; I work for Hunter Engineering though I dont sell alignment equipment
comart45 Avatar
comart45 Peter Cummins
Lansing,MI, USA   USA
Around 2000 I bought the toe in gauge tool from Moss. Works great except you just can't pass it under the car to measure the tires from the rear. I had to modify the cross bar to a "U" shape so it would clear the exhaust, engine etc. You have to lay it on it's side, pass under the car then flip it back upright. I figured that the cost of $30.00 was reasonable since having the toe in set at a shop cost about the same. Well off to work.
1965 MG MGB MkI
