Sun Visor installation help
tedjr Avatar
tedjr Silver Member Ted R. Schneider Jr.
Akron, Ohio, USA   USA
1974 MG MGB "Ruby"
1974 MG MGB GT "The Orphan"
OK, I know the large majority of you take the visors off. Ruby came with a set, but were not attached and I do like them off when on the road. But, I’d like to put them on when I go to the car show this weekend, as I believe it’s good to show a car as complete as possible.
My dilemma is: HOW do you attach them securely to the pivot bracket? First, there is slop where shaft fits in the pivot bracket and second, the threaded screw is not long enough to get a nut on (see photos). Vicky Brit even shows a clip washer and a spring washer and then the nut. No way is that going to happen.
Any advice?
Also the rivets on one pivot bracket are a bit loose, is there a way to tighten them with out drilling them out and replacing them, I don’t own a rivet gun.
(click on photo to enlarge/hosted offsite)
ted
1974 MGB "Ruby" and 1974 MGB GT "Orphan"
Ruby (MGB) Photos
Orphan (MGB GT) Photos
MGExperience Journal
ENMGR
twigworker Avatar
twigworker Jack Austin
Blowing Rock, NC, USA   USA
Like mammary glands on a boar hog. Just ditch them, remove the riveted brackets, fill the holes with JB Weld and smooth with a Dremel tool.
Jack
robgeskey Avatar
robgeskey Rob Geskey
Streamwood, Illinois, USA   USA
Ted,
I have a set of new visors that will not fit either and never did mount them, but I do put them and angle them up for wind deflectors at times. Of course the only thing really holding them on is the clip and the too short threaded rod just sitting in the hole. I always thought of boring them out a bit to get a nut on them, but I always seem to take them off when top up driving. They cut down the already short view through the windshield!
Jack... Not sure you want to tell that to a bore hog. Haha The last time I met a wild one was in a forest in Berlin, Germany it chased me up a tree. The darn thing just stayed there for about a half an hour before it left. Sure are nasty creatures to tangle with. I wish I had an M16 with me back then.
Rob
Keep the rubber side down and the shiny side up!
Ralph Yingling Avatar
Monroe, WA, USA   USA
1973 MG MGB "Molly"
I do the same as Rob. Drop them in the outside bracket and clip to the inside bracket, no nuts or washers This works for shows and at 65 mph. I take them off for town driving so I can see the lights................
Ralph
'73, SUPERCHARGED! tubeless wire wheels, OD, Advaced Dist. recurved dist. w/Pertronix, de- smogged, ANSA
GILMGA Avatar
CHATTANOOGA, TENNESSEE, USA   USA
1962 MG MGA
1974 MG MGB GT
My GT has visors but they are as limp and honey. The fome is gone inside. I may try to put piece of plastic inside to stiffen them up. Outside looks good and they work fine
Gil
tedjr Avatar
1974 MG MGB "Ruby"
OK,
I'll just set them temporarily in without securing them for the show.
Thanks guys.
But it still begs the question as to how do they really secure in the pivot posts? Anybody out there use them and have them installed properly?
ted
Ruby (MGB) Photos
ENMGR
jdeluke137 Avatar
jdeluke137 John English
Jefferson, Georgia, USA   USA
1976 MG MGB
My wife gave me a set to replace the nasty ones that were on the car. I used a small socket on a driver handle with a small nut inside it as a spacer so the nut that fit on the visor would be flush with the end of the socket. Then I very carefully insert the socket into the hole in the pivot post, insert the visor threaded end from the top, and turned the driver. It took a couple of times to get things aligned properly, but eventually I was able to tighten them down.
John English
1976 MGB
HIF44 carb on late manifold, Schlemmerized 45D w/Pertronix, Limey's relay kit, solid state voltage stabilizer.
Luke 1:37
bdev Avatar
bdev Bruno DeVuono
Washingtonville, Orange County NY, USA   USA
Without going into my garage and removing a nut from my set of visors, I believe the "correct" nut has a round collar that fits into the round recess. When screwed onto the visors threaded section, it "seats" itself between the threaded rod and the housing. I'm going by memory so I'm not positive. Before the night's out, I'll probably head out to the garage and snap a pic. I'm too curious now.
1971 MGB New Racing Green - Dayton Chrome Wires 72 spoke; General Altimax RT 175/70/14; Pertronix; audiovox cruise control; Moto-Lita 15" wood wheel; Limey relays for headlights, high beams and horn; factory hard top; Clark & Clark seat belt guide clips, upgraded alternator.
1974 Triumph Spitfire
2005 Scion TC - daily driver
2005 Toyota Sienna - my wife's ride, and mine when I need to go to Home Depot.
bdev Avatar
bdev Bruno DeVuono
Here's two pics of the visor nut.
visor nut 1.JPG    72.1 KB
visor nut 2.JPG    61.8 KB
tedjr Avatar
1974 MG MGB "Ruby"
Bruno,
I was thinking the same thing. I makes more sense for the fastener to take up the slop in the fitting and secure it. Where would you find such an animal?
ted
Ruby (MGB) Photos
ENMGR
bdev Avatar
bdev Bruno DeVuono
You can actually make one by finding a long nut and grinding it round on its top half.
tedjr Avatar
1974 MG MGB "Ruby"
Thanks, I may give it a try. Now to find a long #10/32 thread nut.
Ruby (MGB) Photos
ENMGR
Edited 1 time(s). Last edit at 2007-07-24 10:30 PM by tedjr.
