tuning the zenith-stromberg 175-cd2 su carburetter
09191941 Bruce Price
Kentwood, Michigan, USA   USA
My friend has a 1978 MGB equipped with the Zenith-Stromberg 175-cd2 SU carb. As of this moment it runs rough, loses power when a load is placed on the engine, stalls on occasion, and idles rough. The spark plugs are covered with black soot and the interior tail pipe is covered in black soot. This tells me that the car is running with too rich of a mixture, well at least from past automotive repair experience anyway. I have attempted to locate a tech manual to help me troubleshoot the carb so I could adjust (?) it; alas no luck. I am familiar with SU carbs as I owned a Datsun 240Z and worked on the Hitachi SU carbs, but this Zenith carb is unfamiliar territory. For one thing, I've noticed it doesn't have the moving piston, but has a diaphram instead; thus much of the information I have found has to do with the carb that has the moveable piston. Has anyone out there had experience troubleshooting, tuning up, rebuilding this carb?Can it be adjusted to a leaner fuel mixture?
Thanks for any input.
.......Bruce Price
mick Avatar
mick Michael Deering
granada hills, california, USA   USA
these are zs not su carbs. don't know where you're looking but these do have a piston. haynes manual isbn 1 85010 019 5 is a good reference
http://www.amazon.com/Haynes-Owners-Workshop-Manual-Carburetors/dp/1850100195/ref=sr_11_1/103-9484251-0825426?ie=UTF8&qid=1184191989&sr=11-1
or maybe on ebay
more than likely the auto choke.
B lover, Beer Geek
Shadetree mechanic and backyard brewer
Mick
Lost Angeles CA
'67B BRGdk
'70B BRGdk
'71B Inca Yellow
'76B Citron Yellow
15 gallon homebrewery
"a gentleman does not motor about after dark"
Joseph Lucas, 1923
"Of all tyrannies, a tyranny exercised for the good of its victims may be the most oppressive. It may be better to live under robber barons than under omnipotent moral busybodies. The robber baron's cruelty may sometimes sleep, his cupidity may at some point be satiated; but those who torment us for our own good will torment us without end, for they do so with the approval of their own conscience."
C. S. Lewis
That which does not destroy me . . . .
. . . . just leaves me shakin' my head.
Friedrich Wilhelm Nietzsche and Me
fleshy1 Avatar
fleshy1 Eric Triplett
Monrovia, CA, USA   USA
1978 MG MGB
2005 Audi S4 Avant "The Sled"
This should help:
http://www.sterlingbritishmotoringsociety.org/files/zenith%20stromberg%20tech%20tips.pdf
Sounds like it needs a slight rebuild, the rubber diaphragm should be replaced as well as the o-ring in the damper oil reservoir http://www.mgexperience.net/article/zenith-oring.html . BTW the oil reservoir is also where one can adjust the idle mixture (similar to the SU) with the proper tool.
Oh and what Mick said!
Oh forgot about this article on the water choke adjustment: http://www.theautoist.com/zs_water_chokes.htm
Eric Triplett
"Electronic ignition, the greatest thing that ever happened to carburetors."
1968 High Compression Engine, Dual SU HIF-4 Conversion, Peco Header and Exhaust, Pertronix LU-147, MSD Blaster 2 Coil. Advanced Distributors Re-Cruve 45DM
Edited 2 time(s). Last edit at 2007-07-11 05:43 PM by fleshy1.
Thanks, Mick for the info. See, I thought the Z was an su carb, thanks for steering me straight as that helps.
Bruce
Eric; The carb has been rebuilt (new diaphram, autochoke cleaned and recallibrated, carb cleaned). Where is the oil reservoir located? For lack of better term, the dipstick at the top of the carb housing is attached to the diaphram (I think) as it doesn't seem to come all of the way out. Not sure where to put oil. I know we have to break down and buy a manual.
Thanks,
Bruce
mick Avatar
09191941 Wrote:
Quote: I know we have to break down and buy a manual.
Thanks,
Bruce
yes better that and before you break down and require roadside assistance.
B lover, Beer Geek
Mick
Lost Angeles CA
'67B BRGdk
'70B BRGdk
'71B Inca Yellow
'76B Citron Yellow
Joseph Lucas, 1923
C. S. Lewis
mbgator Avatar
mbgator Mike Butts
DeWitt, Michigan, USA   USA
1980 MG MGB "Baby"
Bruce=
if all else fails, you being in Kentwood could run over to Ada and visit University Motors, he's located on M21 just west of the Amway campus. He literally wrote the book on ZS carbs
Mike
Mike Butts
"Restoring a car yourself makes you feel like a doctor of orthopedics with x-ray vision. While others admire the patients hat, all you can see is that badly healed fracture of the left clavicle." - Peter Egan
Jazz and Blues, Aged Scotch, Good Cigars, LBC's - Ain't life grand..
fleshy1 Avatar
1978 MG MGB
09191941 Wrote:
Quote: Eric; The carb has been rebuilt (new diaphram, autochoke cleaned and recallibrated, carb cleaned). Where is the oil reservoir located? For lack of better term, the dipstick at the top of the carb housing is attached to the diaphram (I think) as it doesn't seem to come all of the way out. Not sure where to put oil. I know we have to break down and buy a manual.
Thanks,
Bruce
It should in fact come out because that is where the oil should go, try some 20-50.
Damper rod (dipstick) out:
Oil goes here:
Edited 1 time(s). Last edit at 2007-07-11 07:25 PM by fleshy1.
Thanks for the pics and info, Eric. The dashpot is drier than the Sahara...no oil at all! This leads me to suspect that the lack of oil in the dashpot is contributing to the rich air-fuel mix. Is that logical? I'm detaching the autochoke from the carburetor to see how the engine runs. I'm going to add oil to the dashpot first, however; how much oil do I put in? I imagine there is a fill mark on the damper, right? Thanks again,
Bruce
fleshy1 Avatar
1978 MG MGB
There is no fill mark and according to John Twist (University Motors) you can't overfill the dashpot. The oil in there will help with the idle and acceleration problems. It basically smooths out the operation of the piston in the carb which makes for better acceleration and smoother idle. It probably won't correct the rich running problem. I would suggest you check out the links I posted above on servicing the auto-choke.
Eric Triplett
mick Avatar
dashpot oil slows the rise of the piston on accelleration giving a richer mixture while speed is increased. no oil aloows the piston to rise quicker making the mixture leaner on acceleration. piston should reach the same height with or without oil, just how fast it reacts is affected by the oi or lack thereofl.
B lover, Beer Geek
Mick
Lost Angeles CA
'67B BRGdk
'70B BRGdk
'71B Inca Yellow
'76B Citron Yellow
Joseph Lucas, 1923
C. S. Lewis
cfmoore Charles Moore
Texas, USA   USA
I'd recommend checking and cleaning up the ignition system before tinkering with the carb. I played with my ZS for months and couldn't get it right. Then I installed a rebuilt dizzy from Jeff and all my problems went away--literally. Idle smoothed out, acceleration smoothed out. The difference was amazing.
Chuck
Chuck; I've wondered about the ignition, especially the timing. I'll check the distributor points as I have put in new plugs and plug wires. I'm now wishing I had a strobe to check the timing....dang! Anyway, thanks for the suggestion as I'll follow through on it.
Bruce
Eric; Well, the car runs much better. I found two stripped screws that held the mass cover to the choke body. I drilled and tapped those holes, got the appropriate sized screws, insterted them and snugged them down. The idle rpms suddenly rose when the car was started, it idled much smoother. However, taking it out on a test drive it still lugs a little bit when the engine is under a load and acceleration is sluggish, but much better than before the "repair". Your suggestions were very helpful and much appreciated....thanks. I had a suggestion about checking the ignition and I'm going that route to see what happens (the car already has new plugs and new plug wires). Incidently, I did pull out the damper and it did come out....I was afraid to pull too hard as to wreck something...I added oil (20-50 as you recommended) and all is well. Thanks for that too.
Bruce
jdeluke137 Avatar
jdeluke137 John English
Jefferson, Georgia, USA   USA
1976 MG MGB
Bruce, if it has the original distributor for the late model cars, it may only have mechanical advance, and the mechanism may be sticking. You may want to lubricate it good, or better yet, send it to Jeff Shlemmer at Advanced Distributors and have him add vacuum advance to it. I have a new carb that runs really well, but the down side is I can tell just how bad my original distributor is now! smiling smiley I'm talking to Jeff about a replacement, if he can help me figure out how to hook up the vacuum line.
John English
1976 MGB
HIF44 carb on late manifold, Schlemmerized 45D w/Pertronix, Limey's relay kit, solid state voltage stabilizer.
Luke 1:37
