Dashpot Oil
Phantom R K
Cobourg Ontario, Canada   CAN
1966 MG MGB
I tried buying SU dashpot oil at a local MG parts supplier and was told just to buy straight 20W as he didn't stock the actual dashpot oil anymore.
I tried to buy 20W locally but found out that no one seems to stock it anymore. Any other suggestions?
Also when adding the oil, to what level are the dashpots actually filled?
RK
twigworker Avatar
twigworker Jack Austin
Blowing Rock, NC, USA   USA
Many opinions to come, but IMHO use whatever you are using in your crankcase. If you use your B in severely cold weather perhaps MMO would be better, but you prbably already know that.
Jack
JMoore Avatar
JMoore John Moore
Clifton Park, NY, USA   USA
I was using ATF, but recently switched to the heavier 20W50 so it doesn't lean out under hard acceleration.
John Moore
'70 MGB, '68 MGBGT, '99 Land Rover Discovery II, '61 Austin Healey Bugeye Sprite
ourmg Avatar
ourmg Silver Member George Heissenberger
Victor, New York, USA   USA
1973 MG MGB "Parts"
1973 MG MGB MkIII "OUR MG- The Old Girl"
2006 Mini Cooper "Greta's Mini"
2014 BMW MINI Countryman "Maxi"
I was told years ago by the then BL dealer to just use what is in the crankcase and I have used 10W30 for 20+ years in two different MGB's.
Fairfield, CA, USA   USA
I switched from ATF to rear end 70W-140 (a few drops of Redline left in a bottle was plenty for the purpose) weight stuff yesterday. That's also John Twist's current recommendation.
At the same time I put in a set of AAA needles, replacing the AAEs in my AUD405 HS4s. Car ran super on a 230 mile jaunt. And I didn't even retune the jugs, though I should have.
I think I'm gonna put the AAEs back to see what diff the 70 had by itself.
I was getting slight stammering at cruise, indications of a bit of leaness. The combo solved that. Now I'm curious to see if the oil itself might have fixed it.
ingoldsb Avatar
I hadn't thought of trying rear-end oil. Although the numbers make it look awfully thick, they apparently use a different rating scheme than engine oil. So 70w-140 isn't three times thicker than 20w-50 despite the numbers.
Now, it is a good question whether to use multi-grade oil or straight weight. Multi-grade oils maintain their viscosity regardless of temperature. So, damping effect will be the same whether the weather is cold or warm. On the other hand, straight weight oils are thicker at colder temperatures. That might give some added dampening when it is most needed.
I've always run crankcase oil (currently 5w-50) and have no complaints.
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
Peter7307 Peter Thomas
Victoria, Australia   AUS
RK,
This one has been debated more times than I can recall.
If you want to trawl the archives there are a lot of pro's and con's being chewed over.
The general trend is to use whatever is in the crank (normally 20W-50 of your favourite brand) since there is bound to be some of the same in the garage somewhere.
From personal experience I have used ATF , Shell 20W-50 , machine oil ( a lightweight general purpose oil about 15W or so) and a few others and found no discernible difference for a road car.
Fill the carb dashpots to about the level of the outside bell top where it flares into the neck.
Pete.
Basil Adams Avatar
A zillion opinions tells me that there aren't any bad answers. I've tried many of them and they all seem to work. Marvel Mystery works (and it's my forst choice). Hydraulic tool oil works. ATF works. Motor oil works. Castor oil works. In the race car, I run without oil but I take the tops off the carbs and clean them 2-3 times a weekend - ending with a light spray of WD-40. Enjoy!
Basil C. Adams
1956 MGA Coupe (Show Car)
1957 MGA Roadster (Driver)
1958 MGA Coupe (Racecar)
1959 MGA Coupe (unrestored)
1960 MGA Coupe (unrestored)
1960 MGA Roadster (Driver)
MKIII Elva Courier (E1056)
1967 427 Cobra
1972 Alfa Romeo Montreal
A coupla late MGBs
1960 Austin Healy BN7
More Cars than Brains
Phantom R K
1966 MG MGB
Thanks for all the answers...it almost sounds like you can use whatever your preference is and be fairly safe.
RK
GILMGA Avatar
CHATTANOOGA, TENNESSEE, USA   USA
1962 MG MGA
1974 MG MGB GT
Jon Twist recommends 80/90 gear oil
bout the same viscosity as 20 50 motor oil
Gil
chris Avatar
Pendleton, OR, USA   USA
Pretty much. The purpose of the oil is to regulate the lifting speed of the piston in the carb. So, weather conditions local to you will determine which choice is best.
Used English car parts.
mgbjockey Avatar
mgbjockey Frank Patton
Eastern Shore area of Maryland, USA   USA
1969 MG MGB "Sapphire"
2010 Mini Cooper S "Hot Pepper"
The rebuild video says the closest thing to dashpot oil and readily available is 20W motorcycle fork oil.
Frank
MGBJockey
Shinsen774 Avatar
Shinsen774 Jim '64MGB
Glen Allen, Virginia, USA   USA
1964 MG MGB
2003 Mazda MX-5 NB "Shinsen Version #774"
mgbjockey Wrote:
Quote: The rebuild video says the closest thing to dashpot oil and readily available is 20W motorcycle fork oil.
Which you can get at your local Honda motorcycle dealer. You also use this in your dampers/lever shocks.
Edited 1 time(s). Last edit at 2007-05-07 03:12 PM by Shinsen774.
max71 Avatar
max71 Gary Alpern
Portland, Oregon, USA   USA
1971 MG MGB "Max"
I was about to chime in with ATF. I tried the moss stuff and it slowed acceleration. I did 20/50 - same. I like ATF. I'm interested in trying fork oil. Interesting.
ourmg Avatar
1973 MG MGB "Parts"
So the opinions range from just about any kind of oil you can name to none at all except a little WD-40. Amazing.
