Lowered Cross member to remove oil pan! Piece of Cake
danc Avatar
danc Dan Cramp
Menifee, Ca., USA   USA
I had to replace the oil pan gasket and thought i would lower the front suspension instead of loosening the motor mounts. Piece of cake! I will do this all the time in the future. It gave me at least 2 inches of space to get to the front bolts and there was no problem returning it to the original location. It's sort of scary the whole front end is held on with only 4 bolts.
1971 MGB
1967 MGB GT
Edited 1 time(s). Last edit at 2007-01-10 01:30 AM by danc.
vmaxwell71 Avatar
vmaxwell71 Vic Auletta
Annapolis, Maryland, USA   USA
1971 MG MGB "Brooklyn"
Thanks for the tip. I may need to replace the gasket on my car in the near future and this seems to make my decision a bit easier......Vic
GILMGA Avatar
CHATTANOOGA, TENNESSEE, USA   USA
1962 MG MGA
1974 MG MGB GT
I may have to remove cross member to clean and paint it. I think ill strip the suspension first. I wondered if it could be done with engine installed.
Gil
Tom Bedenbaugh Avatar
Memphis,Tn, USA   USA
If you use a 1/4" drive wobble socket with an extention the front bolts aren't difficult to remove and replace with the crossmember in place.
http://www.importandsports.com/
danc Avatar
danc Dan Cramp
yes, I have gone that route but this way was much easier to get the bollts started with 2 fingers.
1971 MGB
1967 MGB GT
mgb4tim Avatar
mgb4tim Tim N
South Fayette, Pittsburgh, PA!!!, USA   USA
1996 Jaguar XJ6 (X300) "Big Green"
I took mine out to rebuild,and ended up taking the whole darn car apart. BE CAREFUL!!
~Tim
morSpeedPerformance@gmail.com
danc Avatar
danc Dan Cramp
I Knew that could happen so I only lowered it a few inches. Its very tempting to remove it and service it.
1971 MGB
1967 MGB GT
71EmmaG Avatar
71EmmaG Bryan Kearse
Raleigh, N.C., USA   USA
1971 MG MGB "EmmaG"
Good to hear this went smooth for you, Dan. I did this when I replaced rod bearings and it was much easier than unbolting the engine.
EmmaG - 1971 MGB with O/D - British Racing Green
Family member since 1984.
Engine Mods - Kent mild race cam, P&P'd non-smog head with SS valves, Balanced bottom end with +0.030 deep-dish pistons, Crane XR-3000 with PS-91 Coil, Fiesta alternator, HS4s with K&N filters and ported intake, 2" exhaust with ported stock manifold.
Suspension - Stock Levers all around, 14" Minators, 195/70-R14 BFGoodrich Traction T/A - H-rated.
Dad's Ride - 1962 TR4 - Viper Red
3 year restoration completed in 1998.
Engine Mods - Balanced motor with 87mm Piston Kit, Mallory dual-point dizzy, Monza sport exhaust.
Suspension - Koni shocks - Front, Stock levers - Rear, 15" Minators, 195/65-R15 Michelin X-one - H-rated.
