Weber 45 MCHH MGB Conversion Kit - Any Good?
magohn Avatar
magohn John H
Woodinville, WA, USA   USA
1978 MG MGB
Hello All,
New to the forums and previously posted about options to fit a weber to my 78 MGB. It appeared that I would have to ditch the ZS 'all in one' manifold and pick up an earlier exhaust manifold and a carb manifold for the weber. Then I would have the problem of the new downpipe having two couplings that do not match up to my single exhaust coupling on my 78.
Well, I just came across this conversion kit for $300 or so that claims to bolt onto the stock ZS manifold. How good of a carb is this? Does it compare well to other Weber options? I'm simply looking for a replacement to my finicky ZS carb with a little more punch...
details:
http://www.racetep.com/mgbmcch.html
Thanks, John
yesiownanmgb Avatar
yesiownanmgb Zack A.
Grand Coulee, WA, USA   USA
That is interesting. I've never seen that before.
Jon Zaremba Avatar
Victorville, CA, USA   USA
1979 MG MGB "Brian"
Wow! I am wondering if that would be acceptable for emissions testing here in CA? The retailer is in North Hollywood...
I've never seen this before either.
Has anyone used one???
Jon Zaremba
mrkenmgb Avatar
mrkenmgb Ken DeLEEUW
Ormond Beach, FL, USA   USA
1996 MG MGF "Green Machine"
I wonder if they offer an electric choke? For some to install the manual might require the dash to be removed to install the manual choke. I had a water choke on my 76 and no need for the manual choke in the dash.
JoeReed Avatar
JoeReed Gold Member Joe Reed
Cordova, TN, USA   USA
1978 MG MGB "Kermit"
No need to remove the dash to install a manual choke. I drilled a hole just below the bonnet release and ran the cable through there - with the knob installed in place of the useless dashlamp dimmer switch. You could just as easily install it using an underdash bracket.
magohn Avatar
magohn John H
1978 MG MGB
Hello All,
Well I hope I dont live to regret it but the same exact kit was just listed on eBay for $200 'Buy It Now'. I 'made an offer' of $175 and the seller took it. Supposedly, the seller only used it for a month on his MGB before selling the car. As new condition with all fittings. Back to a manual choke smiling smiley
Im just happy to be getting rid of my ZS carb. I have nothing but trouble with the ZS and the water choke from day one. I was also hesitant about the extra work of fitting a different manifold setup and the expense.
Question: do i just pick up a new lower hose with no water choke bypass as I dont have a water choke anymore?
I will report back how it goes. Thanks for the input.
John
Jon Zaremba Avatar
1979 MG MGB "Brian"
John,
I'm in the same boat as you. Please let us know as many details as possible once you get the kit and start driving.
Jon Zaremba
JoeReed Avatar
You can just run a heater hose direct from the radiator hose to the heater and eliminate the water outlet on the rear of the head as well. You CAN just cut and plug that hose, but a blanking plate is much neater. Just cut one out of a piece of metal using the water outlet base as a pattern - and cut a gasket to match. I used aluminum stock the same thickness as the base on the outlet. Dab a little black paint on it and no one will know it's there...
fleshy1 Avatar
fleshy1 Eric Triplett
Monrovia, CA, USA   USA
1978 MG MGB
2005 Audi S4 Avant "The Sled"
Check with rattlecanb on this one. He did the conversion and just recently had a whole custom intake made up for it.
I understand that there are some clearance issues with the air filter and brake master cylinder/booster on this conversion and that you must route the PCV pipe from the tappet chest to the air filter.
Eric Triplett
"Electronic ignition, the greatest thing that ever happened to carburetors."
1968 High Compression Engine, Dual SU HIF-4 Conversion, Peco Header and Exhaust, Pertronix LU-147, MSD Blaster 2 Coil. Advanced Distributors Re-Cruve 45DM
magohn Avatar
magohn John H
1978 MG MGB
Thanks all. John
JohnCleirigh Avatar
JohnCleirigh John Cleirigh
CO, USA   USA
1977 MG MGB "Ernie"
Hi John H,
How did your 45 MCHH install go? I'm about to pull the trigger on this as well, and I'd love to hear about your experience first. Thanks,
john
gatorbrit Avatar
gatorbrit Richard W
Raleigh, USA   USA
JohnCleirigh Wrote:
john
Hi John,
There are several of us who have installed this carb, although it is a newer one on the market and there is not much collective knowledge so far about it. I installed one a month ago because I wanted a low cost and simple replacement for the stock ZS.
Here is what I have learned from my experience and that of others.
Overall the installation went well, but I do have a couple of pointers.
1. Earlier posts on this carb talk about an issue with the carb not fitting with the brake cylinder. This is not an issue now as the most recently shipped versions have an aluminum block that changes the angle of the carb slightly and makes it fit nicely.
2. The most important thing is to ensure that the carb is installed without any vacuum leaks. These are most likely to occur between the aluminum mounting block and the heat shield plate and between the plate and the manifold. A leak will result in VERY inconsistent idle and racing of the engine at certain times. So pay very close attention to getting this part of the install done right. Make sure that the aluminum block is bolted on very tightly to the manifold.
3. Pictures of the kit include an O ring washer that is supposed to go between the carb and the aluminum block. This is no longer included in the kit and it has been replaced by a thick cardboard gasket.
4. There are only two screws to adjust. One adjusts the idle an is pretty easy. The other, the idle mixture screw takes a bit more finessing. About 4-5 turns from its lowest point seems to work pretty well.
5. My car benefited from 2/3 of a can of sea foam drawn through the manifold. That really helped.
Overall I strongly recommend this carb if you want a simple and low cost alternative. If you want something that will significantly change the power of the car then this carb may not be for you, although there is no doubt that it did increase the power quite a bit.
Finally, you will end up with a lot of excess vacuum hoses that you have to figure out what to do with. There are posts that will tell you how to handle these or you can post and we can offer suggestions.
Good luck and let us know how it works out.
Richard
My Blue 77 B is gone after being totaled in a wreck. But the blog is still here...
http://1977mgb.blogspot.com/
magohn Avatar
magohn John H
1978 MG MGB
What Rich said ... smiling smiley
However, I had less of a gasket issue as I did not refit the heatshiled. My setup went:
Manifold->Gasket->Adapter->O-Ring->Carb - no gasket goo, just used what pieces came in the kit.
I also plan to fabricate my own heatshield.
Performance: I love it. The big thing for me being getting back to a manual choke ( I used the useless dimmer switch location to mount it). Very reliable carb so far and does give a nice punch upgrade over the ZS. Very easy carb to setup if this is your first weber. Just bolts right on.
I paid $175 for mine on eBay as it was only used for a month n the sellers car. (He sold the car apparently)
HTH
John
JohnCleirigh Avatar
CO, USA   USA
1977 MG MGB "Ernie"
Thanks guys! Richard, I actually found your 'blog before I found this forum thread. And John, I've worked on carbs for 20 years...(foreign, domestic, aftermarket) this design and application seemed almost too good to be true. I'm really glad to hear good results with it...and also glad to hear Weber worked out the brake booster kinks already.
I'm really done with the ZS! My first car was a '71 Volvo wagon with dual SUs. The ZS is so not an SU. And I've played with DCOEs enough to know I really don't want that headache on my 77 B.
I changed my distributor a while back and already eliminated the 4th gear vacuum line, so cleaning up the rest of the vacuum lines will make me happier. I have a manual choke already. On the ZS, the choke is not an air flap tho, it richens the mixture by adding fuel rather than eliminating air. Does the MCHH have an actual choke flap?
I have a hard-to-find exhaust leak somewhere around the cat that continues to clog the stock air cleaner, making for very rich running, and I'm a little worried about this open-element foam-type filter, so I guess the exhaust is my next project. Maybe it's time for a header?
Thanks again for the responses,
john
Craig in Niagara Avatar
Craig in Niagara craig smallman
Niagara Region, Canada   CAN
1975 MG MGB
I just did this carb conversion from the ZS on my 75 MGB. All in all, it went very well, and the kit fit like a glove. No issues at all with clearence. Like many posts here, I used the redundent dimmer in the dash to mount the manual choke. Routing the choke cable was a challange that would have benefited from smaller hands.
One thing I'd like to underscore. John C spells out the woes of not getting the carb sitting tight and the resulting vacuum leaks. My idle is rough, and the engine races at times during idle. I have sealed all the hoses in the manifold, so I suspect the carb mounting is leaking. I like the idea of doing away with the heat shield to reduce the number of gasket joints between the carb and the manifold. (This may be a silly question, but how critical is the heat shield?)
As for the end result; I could not be happier. The throttle response is greatly improved, and there is a nice little punch up in the horsepower. Even the sound of the car has improved.
