Heat Shield Material
fleshy1 Avatar
fleshy1 Eric Triplett
Monrovia, CA, USA   usa
1978 MG MGB
2005 Audi S4 Avant "The Sled"
I'm refurbishing a set of HIF-4s for my dual carb conversion. I have an old heat shield that I'm also cleaning and painting. One of the heat reflective pads on the back side is gone and the other was barely hanging on. What should I replace the material with? Can I buy it at my local hardware store?
Thanks!
Eric Triplett
"Electronic ignition, the greatest thing that ever happened to carburetors."
1968 High Compression Engine, Dual SU HIF-4 Conversion, Peco Header and Exhaust, Pertronix LU-147, MSD Blaster 2 Coil. Advanced Distributors Re-Cruve 45DM
cfrench Avatar
cfrench Silver Member Carl W. French
Alfred, Maine, USA   usa
Someone here has made up these pads and they look good. I think it is projectMGB"??
The old pads are asbestos and NLA. Worth a search here.
Carl W. French
Alfred, Maine
Southern Maine LBC welfare shelter
67B will be in our will
73BGT Daily driver
72 Triumph Bonneville
Many more that change often
http://s5.photobucket.com/albums/y183/leylandauto/
showroomgarage Mike Sumner
Graham NC, USA   usa
Eric has the material. He's on the forum as ProjectMGB.
Edited 1 time(s). Last edit at 2006-10-26 10:16 AM by showroomgarage.
fleshy1 Avatar
1978 MG MGB
Eric, seems to be MIA, hasn't posted since August and his website talks about the material but is short on details of the manufacturer, or name of the product. I'll send a PM to see if he's still around.
Eric Triplett
cfrench Avatar
Here is the thread;
http://www.mgexperience.net/phorum/read.php?42,341076,341632,report=1
Carl W. French
Alfred, Maine
73BGT Daily driver
Greenville, SC, USA   usa
The new B Hive/Moss ones come with two strips of header wrap riveted on them.
dwengdahl Avatar
dwengdahl David Engdahl
Henrietta, NY, USA   usa
Eric - I believe that Eric Sorosiak also sells his heat shield material on Ebay. I was quite pleased with the way the new pads fit (that is my HIF4 heat shield pictured on the May 4 post referenced above). You are lucky if your shield is not cracked. I had to have mine welded.
Dave E.
1972 MGB GT RED
"Every path has a few puddles"
davegt David Allen
Maine, USA   usa
Hi : I've had this problem before and used a thick nomex/fiberglass tape made for wrapping
exhaust pipes. I found rivets with big heads at a hardware store to secure the
tape.
Dave '79 MGB
John D. Weimer Avatar
Cape Girardeau, MO, USA   usa
This works and can be cut to any shape.
The stuff is Fel-Pro "Fel Ramic". I think it's ceramic fibers with a metal backing and it looks sort of like exhaust manifold gasket material. P/N 3009, A 12" X 28 1/2" sheet 3/64" thick. There are other thicknesses shown in the catalog and they are all four didget numbers beginning with 300.
71EmmaG Avatar
71EmmaG Bryan Kearse
Raleigh, N.C., USA   usa
1971 MG MGB "EmmaG"
I used two layers of adhesive-backed air duct insulation wrap you can find at Home Depot or Lowes. I then used a top layer of High-Heat Copper Silicone and Heavy-Duty aluminum foil. I ran each layer completely across the the back of the shield. Thus, the heat transfer is spreadout more evenly and there are no hot spots across the shield. Plus, you have something to dissipate the heat from the center exhaust branch which is of course hotter due to the siamesed exhaust design.
The result is a much cooler shield (verified by IR temp. guage) for very little money. I also attached a piece of the insulating wrap to the underside of the intake manifold cross-tube since it is directly above the center manifold branch. Anything to keep the intake temp. lower...
EmmaG - 1971 MGB with O/D - British Racing Green
Family member since 1984.
Engine Mods - Kent mild race cam, P&P'd non-smog head with SS valves, Balanced bottom end with +0.030 deep-dish pistons, Crane XR-3000 with PS-91 Coil, Fiesta alternator, HS4s with K&N filters and ported intake, 2" exhaust with ported stock manifold.
Suspension - Stock Levers all around, 14" Minators, 195/70-R14 BFGoodrich Traction T/A - H-rated.
Dad's Ride - 1962 TR4 - Viper Red
3 year restoration completed in 1998.
Engine Mods - Balanced motor with 87mm Piston Kit, Mallory dual-point dizzy, Monza sport exhaust.
Suspension - Koni shocks - Front, Stock levers - Rear, 15" Minators, 195/65-R15 Michelin X-one - H-rated.
dsc Silver Member Don dsc
Virginia, USA   usa
Where does one get High-Heat Copper Silicone and Heavy-Duty aluminum foil?
71EmmaG Avatar
1971 MG MGB "EmmaG"
You can get High-Heat Copper gasket sealant at Advance Auto, Napa, etc. It's made by Permatex and is readily available. The heavy duty aluminum foil can be found at any grocery store. HTH! smiling smiley
Virginia, USA   usa
Oh. Somehow your first description sounded more exotic than that.
Thank you.
Edited 1 time(s). Last edit at 2006-10-27 01:30 PM by dsc.
ProjectMGB Avatar
ProjectMGB Eric S
Cincinnati, OH, USA   usa
1967 MG MGB
As a few members have already stated, I have replacement insulation available for both HS4 and HIF4 setups. The ceramic-based insulation is very similar to the original insulation in thickness and color. Also, the brass rivets that I include with the HS4 sets are nearly identical to those originally on my heat shield.
I have details at:
http://www.geocities.com/project_mgb/heat_shield.html
Unfortunately, this link often doesn't work if several people have tried to access the website within a short period of time (the free Geocities site has a data transfer limit). However, you can check out the MGBE post:
or email me with any questions at project_mgb@yahoo.com
Thanks,
Eric
1967 MGB roadster (restoration in progress)
1984 Mazda RX-7 (daily driver)
Edited 1 time(s). Last edit at 2007-02-15 04:58 PM by ProjectMGB.
insulation_3.jpg    23.6 KB
