remove headlight rings
chuckw2 Avatar
chuckw2 Chuck Williams
SoCal high desert, USA   USA
1967 MG MGB
anyone have a good method for removing the chrome trim from the headlights? I thought this was going to be an issue when i put them on.
67 mgb
Edited 1 time(s). Last edit at 2006-10-15 10:10 AM by chuckw2.
JMoore Avatar
JMoore John Moore
Clifton Park, NY, USA   USA
I got mine on and off with a paint can opener. Good luck! It's a tough job to do with out scratching the paint.
John Moore
'70 MGB, '68 MGBGT, '99 Land Rover Discovery II, '61 Austin Healey Bugeye Sprite
Gerry Avatar
To dio it without scratching the paint, but a rubber or plastic spreader or spatchuler(SP?). Use the rubber under the screwdriver when you pry the ring off to protect the paint.
chuckw2 Avatar
1967 MG MGB
thanks for the tips!
cdncapt Avatar
cdncapt Kirk Bauer
New Brunswick, Canada   CAN
I use a spring puller. the puller i use has a T-handle on a shaft with the end formed in a small hook. I slip the hook under the chrome ring and yank.Pops right off.
Paul J Avatar
Locust Grove, ok, USA   USA
cdncapt Wrote:
Quote: I use a spring puller. the puller i use has a T-handle on a shaft with the end formed in a small hook. I slip the hook under the chrome ring and yank.Pops right off.
Chuck, I use a tool that I made that looks like a spring puller as Kirk uses. I wraped it with one layer of tape. I pull from the very bottom of the ring. Also I slide a very thin piece of cardboard between the tool and the paint. No paint damage! Works for me. PJ
mg4sale Avatar
mg4sale Bastien Macia
Maisons Laffitte - Ile de France, France   FRA
1967 MG MGB GT
Hello there,
Since I twisted a rim with a screwdriver, i no longer use any tool to remove the headlamp rims, I only use my hands !
The only way I know is to press firmly on the top of the rim with one hand, and then pull slowly the bottom of the ring once it can jump over the retaining spring.
You may eventually put a cloth on the bodywork when the paint needs to be protected.
Removing/replacing the headlamp itself from/on its retaining coil spring is by far more painful !
B Macia
