zenith stromberg carb oil?
gccch Greg Heitman
Chalfont, PA, USA   usa
Hi all,
Quick question (I think). I did a search but didn't find the answer.
I heard the ZS carb needs to be oiled every 3k miles. I don't have a manual. Would someone mind posting the type of oil and anything critcal about topping it off (such as over filling, how much is required, etc.)? The car is running fine but I want to be sure it stays healthy.
Thanks,
Greg
Chalfont, PA
1980 MGB LE
mowog1 Avatar
Saint Joseph, Illinois, USA   usa
1969 MG MGC "Vicky"
1972 MG MGB "Mallard"
I always used Castrol 20/50 when I still had a Zenith on the B...some think that may be too thick. Overfill is generally blown out.
1968 MGC - 1969 MGC - 1972 MGB - 1974&1/2 MGB/GT V8 conversion - 1978 MGB
mowog1@aol.com
ddibiase Avatar
ddibiase Dan DiBiase
Dayton, NJ, USA   usa
1976 MG MGB
Yeah, engine oil is fine, as Rick notes. If you overfill it, it will flow out when you put the piston back in.
Dan D
Central NJ, USA
'65 B Project
'76 B Driver
http://dans65b.blogspot.com
http://dans76b.blogspot.com
twitter: dandibiase
locolobo85 Avatar
locolobo85 Brad Batchelor
North Carolina, USA   usa
1975 MG MGB "Abbigail"
I use engine oil. The correct amount in the dashpot gives you resistance when re-installing the plunger equal to 0.25" from the top edge of the carb cover to the bottom of the removable plunger. D
If your o-ring in the bottom of the air piston is shot, the oil will leak right past the needle assembly and you will have to top it up often prior to replacing the o-ring.
gccch Greg Heitman
Thanks, guys. The stuff in there now is red like trans fluid.
Greg
Chalfont, PA
1980 MGB LE
mowog1 Avatar
1969 MG MGC "Vicky"
It probably is...some guys use Automatic Transmission Fluid...or real light weight oil in the hopes of increasing acceleration by decreasing the reistance the oil puts on the piston while being raised under a heavy pedal....
This was a big racer trick...with a Zenith, I don't believe you're going to see a significant increase in performance.
smiling smiley
mowog1@aol.com
gccch Greg Heitman
Oh, so I can use the left-over trans fluid I have from the Mustang and no worries!
Thanks,
Greg
Chalfont, PA
1980 MGB LE
tylerwatkins Avatar
tylerwatkins Tyler Watkins
North Myrtle Beach, SC, USA   usa
I ask:
Is is possible to replace this O Ring??
zeenithman Avatar
zeenithman Dan Olson
Spokane WA, USA   usa
1975 MG MGB
Get the "O" ring in the Moss catalog. I just went thru this on my 75 and you also have to buy their mixture adjusting tool to change the ring. Dan
zeenithman Avatar
Spokane WA, USA   usa
1975 MG MGB
If you want to read the procedure, refer to my post "Giving back to the forum" you can find this using the search function. Dan
locolobo85 Avatar
Yep, it's pretty easy to replace. Remove the carb cover. Remove the piston. Remove the needle assembly. Then insert the tool of your choice and drive the adjuster and star washer out through the top of the piston. Install the new o-ring and drive it back in making sure to seat it at the very bottom of its travel. Put it all back together, tune it up and enjoy. No more leaking dashpot oil.
philipE philip williams
Oregon, USA   usa
DONT use transmision oil .. use 30w engine oil.
Edited 1 time(s). Last edit at 2011-12-10 09:28 PM by philipE.
feathercraft1952 Avatar
feathercraft1952 ric boles
kentucky, USA   usa
1974 MG MGB "Junkyard Dog"
1976 MG MGB "Penellope"
i read 20w nd somewhere - works fine for me
ironpony Avatar
ironpony Dan Howland
Park Rapids, Minnesota, USA   usa
1977 MG MGB "The "G"
My son and his father-in-law, for over 20 years, owned and operated a company that specialized in rebuilding imported carbs. I ask their advice on what oil to use in my ZS carb. They used ATF and over 20 years never encountered any problems caused by this choice of oil. My Driver's Handbook, that came with the car, says to use the same oil as your using in the engine crankcase. I don't think it makes a whole heck of a lot of difference.
Dan
Harper Bob Harper
Jensen Beach, Florida, USA   usa
If you're loosing oil in the ZB will it burn up in the cylinders and show up as bluish white smoke in the exhaust?
