Overdrive conversion LH type
  This topic is about my 1977 MG MGB
buzzda Buzz Davies
Erwin, TN Tennessee, USA   USA
Where can I find out details about the shifter lever and shifter knob? Is the knob just hollowed out to allow the switch to fit in it?
Do the wires run down thru the gaiter to the transmission connections or are they routed out thru the firewall and down from the front of the transmission?
My Haynes Manual makes reference to only having the OD Switch work in 4th gear --- Yet my OD Switch works in both 3rd & 4th. Is there another isolation switch missing from my transmission?
bawest47232 Avatar
bawest47232 bruce west
houston, tx, USA   USA
1980 MG MGB "Maggie"
This is from my 80mgb
1980 MGB on blocks in the garage.
Emission free engine with Weber Carburetor
One ticked of wife who hates my new girlfriend Maggie... Sometimes, I wish I'd never seen her face either.
15185755822542095426800.jpg    20.1 KB
bawest47232 Avatar
My camera on the phone jacked up but there are 2 wires that feed through to the transmission. But it depends on the year. Some had overdrive switches in different places
Noble66 Avatar
Orlando, FL, USA   USA
1964 MG MGB "Black Betty"
1969 MG MGC GT
1974 MG MGB "Whitey"
The knob and gear shift lever are different. There is a channel in the lever for the wires. I’m not sure where the wires go on the Mk. 3 & 4 cars.
The black label LH transmission worked in both 3rd and 4th. The blue label only worked in 4th. Your car may not have originally had OD and one of the PO’s added a black label. I’ve also heard there’s a way to switch a blue label to work in 3rd but I don’t know anyone that’s done it.
Other than the blue or black label on the OD the other way to tell which OD you have is if it has a dipstick it’s a black label. If it has a plug on the right side it’s a blue label.
In reply to # 3680900 by buzzda Where can I find out details about the shifter lever and shifter knob? Is the knob just hollowed out to allow the switch to fit in it?
Early 77 (june 76 to feb 77) was blue lable still overdrive in both 3rd and 4th gears.
After feb 77 dropped 3rd gear overdive operation.
Donthuis Avatar
Donthuis Don van Riet
Not having OD in 3d is not a great loss, I almost never use this feature. It is really only relevant for long stretches on winding country roads, where 4th gear is just too high and 3d rather low eye rolling smiley
Over the years there were times I forgot having it available at all, maybe now that France reduced its max speed on country roads from 90 to 80kmh (the same value we have here) I will use it even less.
PS There is one disadvantage with how BL arranged OD activation and blocking: if left on after downshifting automatic OD upswitch will follow after leaving the next traffic light stop
Astley contains a circuit diagram for preventing this from happening automatically, but I find it rather complicates the basic circuitry of the simple solenoid activation
Edited 1 time(s). Last edit at 2018-02-14 03:38 AM by Donthuis.
I drive on plenty of winding country roads, comes in very handy.
Takes but a few times to learn switching off and back on after upshift.
It one needs a modification to switch it off than they arent paying attention.
You do now... cool smiley
In reply to # 3680925 by Noble66 The knob and gear shift lever are different. There is a channel in the lever for the wires. I’m not sure where the wires go on the Mk. 3 & 4 cars.
buzzda Buzz Davies
Having never driven an MGB with OD before, would you recommend an automatic disengagement switch arrangement if you drop below 3rd to prevent automatic re-engagement?
mgbanthony Avatar
Gananoque, ON, Canada   CAN
1962 MG MGB
1962 MG MGB
1970 MG MGB GT
The 77-80 stock shifter and knob are the same for both OD and non-OD. The cap, switch and small harness can be purchased from the usual suppliers.
The OD transmission has an isolation switch which prevents engaging OD in gears other than 3rd and 4th, or 4th only in the later year cars. It is best that it be hooked up and working. Power runs from the switch in the knob, to the isolation switch on the transmission, then to the OD.
Steel dash cars have the OD switch on the dash and 68-76 padded dash cars have the switch as part of the wiper, washer stalk on the column.
