MGB Hubs
Ally cat Allen Holida
Shelby, NC, USA   USA
I have a 1970 MGB with wire wheels, wanting to convert over to bolt on rostyle wheels . I have the rear axles. Do I need to change all 4 hubs? If so does anybody have them for sale?
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Install the bolt on rear axle and replace the front WW hubs with ones for a bolt on car. Available from Moss and others. RAY
ghnl Avatar
ghnl Eric Russell
Mebane, NC, USA   USA
1961 MG MGA "Calvin"
Just to be clear - the axle shafts for WW & bolt-on wheel cars are slightly different lengths. You can swap the entire rear axle assembly but you can't simply swap the axle shafts.
The front hubs are a direct swap.
Eric Russell ~ Mebane, NC
mgv8glen Avatar
mgv8glen Glenn Towery
Dover, DE, USA   USA
Allen, I have been doing this swap for 35 + years. Like what has been posted the front axles are a swap, no problem. The rear W/W axle is 1.5 inch's narrower than the steel wheel. What I have done is run a set of the Nissan 280ZX 14" wheels on my MGB, there is a different off set on the Z wheel & with the Z off set the Z wheel sets dead center on the MGB, rear axle. You HAVE to run a 185-70 14 tire, any larger the front, with the extra off set on the front the tire will rub the inner front fender lip. I sell the 4 hubs off a S/W car to put on a W/W car & I have a set of the Nissan wheels also, I can sell. If you go to a 15" wheels, Acme Speed Hap can set you up with the right wheel off set.
Edited 1 time(s). Last edit at 2018-02-12 09:24 PM by mgv8glen.
IMAG1034.jpg    22.2 KB
"Available from Moss and others"
Well it'll have to be others for Moss are like M-E - front hubs NCA.
Sonett7 Mats K
HÄRSLÖV, Skåne, Sweden   SWE
According to John Twist in this video the difference between the two types of axles are not 1,5 inches, more like 3/4 inch...
I'm planning to do this swap myself on a BGT -67 and I really want to know what is right.
This viedo also claims that the difference isn't that much.
lewisrn Avatar
lewisrn Gold Member Bob L
Danville, IN, USA   USA
1980 MG MGB "The "B"
In reply to # 3680357 by Sonett7 According to John Twist in this video the difference between the two types of axles are not 1,5 inches, more like 3/4 inch...
This video also claims that the difference isn't that much.
Whatever difference in rear axle width there is can easily be counteracted with wheel spacers.
When I converted my 80B, I had to use only one 1/4" spacer on the left side and none on the right side, due to the common off-center axle mount of MGB's.
I mounted new 15" Minator wheels from Moss with 195X60X15 tires and I've had no rubbing whatsoever from any of the 4 wheels.
IMG_1215.JPG    59.9 KB
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kinggsport, TN, USA   USA
Well, 3/4" per side does equal 1.5". winking smiley As measured here in post #13.
http://www.mgexp.com/phorum/read.php?40,1603499
Hot4aB Avatar
Hot4aB Silver Member Richard Gray
Phoenix, AZ, USA   USA
I am doing the other thing - disc wheels to wires - so have all the disc wheel parts. Shipping a rear axle would be ridiculously expensive, but the front hubs will fit in a flat rate box. PM me if you're interested.
Richard Gray
