time for some detective work IYI
Do you know what this is and where it goes? I know the second but I'm not sure of the first. It's about as thick as a rocker shaft shim and it measures 37 x 19 (that's mm spinning smiley sticking its tongue out )
P1010575.JPG    21.8 KB
Daz1945 Avatar
Daz1945 Darrell Martin
Burrum Heads, Queensland, Australia   AUS
1958 MG MGA 1500 "The A"
1968 MG MGB GT "The GT"
1969 MG MGB MkII "The B"
Hi,
Not sure, but about the same size as those sometimes supplied with castor correction kits to adjust the steering rack angle back to standard after the crossmember has been rocked.
No far from it. It is as far as I could tell OEM.
mike.l mike l
tillsonburg, Canada   CAN
1954 International L-Series
1954 Nuffield PM-4 Tractor
1957 Morris Tractor (Nuffield) "Little Brother"
1974 MG MGB "Paddington Bear"
Hi Barry not up on metric measurements but its a information tag like found on the su carbs mike
Approx 1.5" long and .75 wide. SU carb tags are about twice as thick. But you and Darrell are cold grinning smiley
I'll concede information tag - well that's what I think it is but where?
Edited 1 time(s). Last edit at 2018-01-10 07:22 AM by MGB567.
B-racer Avatar
B-racer Jeff Schlemmer
Shakopee, MN, USA   USA
2014 Dodge Charger
I've seen something like that on the differential. .
jeff@advanceddistributors.com
Give that man a cigar - do you know what it's meant to signify as I don't? It appears to be stamped 0358 second line A468.
B-racer Avatar
2014 Dodge Charger
No idea but with American iron it would signify the gear teeth count and production date, as well as a posi unit if it had one. Unless your car has a 4.375 and was made in '58, I'd say that's not the case.
melbaver Avatar
1968 MG MGB "Moneypit"
Is it a panel shim?
Chris Howells
Nah. Jeff got it.
I'm still interested in the why/what for.
BumbleB74 Avatar
BumbleB74 William Milholen
maybe a part number for the axle assembly?
IanFife Avatar
IanFife Ian F
Inverkeithing, Fife,Scotland, UK   GBR
It's a shim for fitting beneath the rocker shaft pillars. From memory just the middle two, and fitted to later engines.
Ian F
MG Midget MK1 (1961)
MGBGT (1972)
IanFife Avatar
IanFife Ian F
In reply to # 3659931 by IanFife It's a shim for fitting beneath the rocker shaft pillars. From memory just the middle two, and fitted to later engines.
Ian F
Alternatively, a shim for aligning the steering box.
MGBGT (1972)
No you're missing the answer - it's at #6.
It was held on by one of the bolts holding the diff cover on - but IDK what it signifies not that it really matters as I was originally just setting a challenge to those MGEsters interested. I recall that M-E catalogues reckoned on there being a vehicle identifier stamped into the Banjo diff housing - maybe this was the final iteration; a tag bolted to the Salisbury?
IanFife Avatar
IanFife Ian F
Thanks Barrie, well that's another challenge I've failed!! I have three Salisbury axles but can't recall seeing any tags. I'll take a look this morning and if I find anything I'll post it here. As you will know the axles are supposed to have a number stamped on them, but can't say I've ever noticed that either
MGBGT (1972)
