re-inforcing firewall
New Haven, Connecticut, USA   USA
Hi All,
A few days ago I asked a few questions about removing heater shelves and modifying cross members. Thanks again for all the helpful info I received. Some people who have done this have moved the engine further back than I had anticipated, and I can think of a few good reasons for doing so. BUT doing so means that a significant area of the firewall is also removed.
QUESTION: How have other guys re-inforced the engine wall once they've chopped a good bit out? I'm looking at working with a B GT, so the monocoque gives more rigidity, but I still want a sound underside, particularly if I am going to feed the bhp from a 2JZ with turbos.
I have loads of other questions, but I'll go one at a time.
JH
Well I suggest you pose your question on the Swaps forum. OTOH I've stuck a 5litre Rover in mine and not cut anything - but now the engine's out I'll do a little BFH work around the area the bellhouse sits. Advice on Swaps was no need to reinforce seams.
Edited 1 time(s). Last edit at 2017-12-07 07:02 AM by MGB567.
Steve64B Avatar
Steve64B Steve Opitz
Phoenix, AZ, USA   USA
1966 MG MGB
Jon... while they remove metal to get the contours they need, they always add metal back to close off the holes they open up. With that, integrity for the most part, is returned.
Have you seen the Youtube videos of the BGT with the duel turbo 2JZ motor... it's fast enough to take on motorcycles!
tvrgeek Silver Member Scott S
I guess it is fortunate the B being one of the earliest uni-bodies from BMC that it was built "strong enough". Modern cars with-the extensive finite element analysis might be far more susceptible to structural issues than the B. Basically, it is built like a tank. I offer it's weight, which is more than a Mustang as proof.
